    Configuring SK 6812RGBW LED while 12864mini is connected
    Using Duet Controllers
    567
    • o_lampeundefined
      o_lampe @Sn1kk3r5
      @sn1kk3r5
      For 4 LEDs you could use internal 5V from an empty connector. Just have to wire the strip to it and only use GND + NP_out from the NP-header.
      Sn1kk3r5undefined 1 Reply Last reply Reply Quote 0
      • Sn1kk3r5undefined
        Sn1kk3r5 @Gixxerfast
        @gixxerfast
        Yeah probably I do misunderstand the guide in this matter. Never the less a 5V PSU is on it's way, I'll report tomorrow or the day after.
        • Sn1kk3r5undefined
          Sn1kk3r5 @o_lampe
          @o_lampe
          MY example was just to start the configuration on a working example rather then just start writing a macro.
          So from what I understand from your and Gixxer's answers
          is, the 5V will get passed from 5V_EXT to the NEOPIXEL connector. The only limit then is coming from the PSU itself, right?
          Gixxerfastundefined 1 Reply Last reply Reply Quote 0
          • Gixxerfastundefined
            Gixxerfast @Sn1kk3r5
            @sn1kk3r5 max. 60 LEDs though according to the docs.
            Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
            Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
            Ender 3 Pro with BTT SKR-2 + RRF
            • Sn1kk3r5undefined
              @gixxerfast
              Guideline stated begining from FW 3.3 it's 80, but this would fit no matter if 60 or 80
                dc42 administrators @Sn1kk3r5
                @sn1kk3r5 said in Configuring SK 6812RGBW LED while 12864mini is connected:
                Hi there,
                I require help, please.
                My 12864 mini is working fine with config:
                M918 P2 R6 C30 E4 F2000000 			  		   ; connect a display directly C= Contrast
                M150 X2 R0 U0 B255 P200 S1 F1 			  	   ; display led R= Green U= Red B= Blue
                M150 X2 R0 U255 B0 P200 S1 F1 			   	   ; left encoder led
                So I connected my LED stripe to the NP_LED connector and added the following to my config:
                M150 X4
                M150 X4 R255 U0 B0 W0 P100 S1 F1
                M150 X4 R0 U255 B0 W0 P100 S1 F1
                M150 X4 R0 U0 B255 W0 P100 S1 F1
                M150 X4 R0 U0 B0 W255 P100 S1 F0
                I as well disabled the display with comments to try some kind of stand alone. Nothing I tried worked so far...
                It's always changing the colors of my display and the stripe won't even turn on, no matter if the display is configured or not.
                That's as expected:
                X1 = RGB Neopixels connected to NP_OUT
                X2 = RGB Neopixels connected via the display
                X3 = RGBW Neopixels connected to NP_OUT
                X4 = RGBW Neopixels connected via the display
                So X2 and X4 both address the display.
                • Sn1kk3r5undefined
                  Sn1kk3r5 @dc42
                  Thanks for the reply.
                  I changed my config to X3 but this doesn't changed anything...
                  Is it because of missing 5v on 5v_EXT? Or should the work even without 5v_EXT until a limit of 1A?
                  Cheers and Thanks!
                  • o_lampeundefined
                    o_lampe @Sn1kk3r5
                    It's 60 RGBW or 80 RGB LEDs, but at eg. 50% brightness it can be doubled.
                    I'm currently playing with Arduinos fastLED library, which has amazing features. There you can set max. Watt limit for all strips connected and the brightness of each LED is controlled automatically. Very handy for animated strips or matrix's
                    Currently I'm working out how to control the LEDs on the Arduino from Duet or Slicer-generated gcode
                    • Sn1kk3r5undefined
                      Sn1kk3r5 @o_lampe
                      @o_lampe
                      That's by far more then I need. But thanks for the information.
                      Currently I'm trying to get used to the coding, which seems to have some strange effects....
                      Just to ensure I understood yesterdays conversation right.
                      I now have an external 5V 18A 90W PSU. Can I connect this one to the mini 5+ and power about 60 LED'S from the NEOPIXEL connector
                      or do I have to connect the LED'S to the PSU directly cause of the power drain?
                      Thanks in advance.
                      Cheers
                      Cris
                      • o_lampeundefined
                        o_lampe @Sn1kk3r5
                        That's what I would do. Just connect the Duet over GND and Data-in to the strip.
                        • Sn1kk3r5undefined
                          Sn1kk3r5 @o_lampe
                          @o_lampe
                          Sure that's what I will do in case it'S the only possibility.
                          But to have a nicer cable management it would be good to have one pair from the PSU to the mini and one from the mini going to the strip
