    Heater fault and shutdown @ 260
    • Sinkundefined
      Sink
      Trying to use XT-CF20 Carbon Fiber filament and have run into a perplexing situation..
      I preheat to 260, E3D hotend, extrude a bit, all ok .. and then I get a heater fault and the board disconnects heater and refuses to react without a power down-power up.
      It refuses to accept a 275 degree temp, just ignores it, but allows 260, all through web interface ..
      Can't find any commands in config files to limit temp, but probably just not seeing it ..
      The heater fault though is making me a bit crazy ..
      Any thoughts
      • Sinkundefined
        Sink
        Error: Temperature reading fault on heater 1: temperature above limit
        Seeing a bunch of these and then shutdown ..
        I am hoping there is a limit setting somewhere in config files?
        • Dougal1957undefined
          Dougal1957
          there is see http://reprap.org/wiki/Gcodes#M143:_Maximum_heater_temperature
          • Sinkundefined
            Sink
            Tried adding that to config, but no change.. It still will not let me set a temp above 260.. is this a firmware thing?
            • Sinkundefined
              Sink
              Trying to run a M303 H1 300, is that correct ?
                Dougal1957
                you need to add a M143 S300 (or whatever figure you want the hotend to reach) you can do it temporarily useing the GCODE Console but it will revert to the default of 260 after a reboot if you want it to be a permanent change you need to add it to the Config.g file
                • Sinkundefined
                  Sink
                  Thanks that did it .. did'nt have the S in front of the temp ..
