Connecting Lerdge Power Monitoring Module, did I do well?
    FrankV
    At first I connected my Lerdge connecting power Monitoring module and button to PSON to my Duet3. One disadvantage is when resetting or emergency stop I needed to walk to my printer and put it on manualy.
    So I thought about other wirering to the Duet3 board and came up with this idea. I tested it and it is working.
    Define io3 with M950 command and I can switch it of with M42 P3 S1 or put this at the end of my GCode to turn the printer off. With a reset the printer stays on and at start I don't have to wait untill config.g with M80 is initialized.
    Is this the way to to so or are there other ways or remarks?
      FrankV
      It did work but I noticed io3.out got influenced by my superPinda. This prope is connected to io3.in. When it probes io3.out is influenced and my power was shortly cut off. I put everything on the free io0 and used io0.out for the power module. Now it's working fine.
      undefined 1 Reply Last reply 20 Feb 2023, 19:19 Reply Quote 0
      • undefined FrankV referenced this topic 17 Dec 2021, 23:36
      • undefined FrankV referenced this topic 17 Dec 2021, 23:38
        kostea33 @FrankV
        @FrankV I have the same setup but my print doesn't stay ON after pushing the momentary button. Any clue? Thanks.
        2 out of 3
