    Panel Due Bad Command Error From CNC Pendant
    Accessories and Add-ons
    • dhusoloundefined
      dhusolo
      I have:
      Duet 3 with RRF 3.3 ran off a RPI 4 as SBC
      FYSETC PanelDue 7i clone with
      Arduino Nano CNC Pendant from here
      To be clear the pendant works if It's connected to a Duet 2 WiFi or Duet 3+ Mini
      When I connect the pendant to use the PanelDue pass through I receive numerous "Bad command" errors. I have it wired as the webpage says.
      Arduino TX w/ 6k8 resistor > Duet Io0.in
      Arduino RX > PanelDue DOut
      PanelDue DIn > Duet Io0.out
      1k resistor on the back replaced with 10k
        dc42 administrators @dhusolo
        @dhusolo I can see a few possibilities:
        1. Do you definitely have the PanelDue set to the same baud fate as the pendant, normally 57600 baud?
        2. The Arduino Nano really needs a 5V signal level from the PanelDue, however PanelDue outputs a 3.3V signal level (that is why I reworked the pendant to use a Arduino Pro Micro or Leonardo, because those Arduinos are happy with 3.3V signal levels even when run from 5V). So perhaps the signal level is the problem. What did you mean by "1k resistor on the back replaced with 10k" ?
        dhusoloundefined 1 Reply Last reply Reply Quote 0
        • dhusoloundefined
          dhusolo @dc42
          @dc42 Yes the Pendant is 57600 as well as the PanelDue.
          In one of the original posts I saw that with a CH340 on the Nano clones you might need to replace the 1k resistor so the PanelDue can override the RX signal from the USB.
          Sounds like I might need to incorporate a logic level shifter
            @dhusolo thanks, I remember now about changing the 1K resistor t 10K, in order to improve the signal level from the PanelDue data out pin into the Arduino.
            • dhusoloundefined
              dhusolo @dc42
              @dc42 To confirm the logic level shifter is wired Paneldue side is 5v and Arduino side is 3v? or do I have that backwards.
              Also is the 1k resistor swap on a nano really needed?
                @dhusolo PanelDue uses 3.3V signal levels, Arduino Nano uses 5V. If you use a level shifter then you probably don't need to change the resistor.
