    Ender 3 RRF v1.1 setting up BLtouch
    4.2k
    • re_tourundefined
      re_tour @Gixxerfast
      @gixxerfast Not really
      Creality Ender 3 | BIGTREETECH E3 RRF V1.1 Wifi | BLTouch | RepRap 3.3.0_11
      • re_tourundefined
        re_tour @Gixxerfast
        @gixxerfast okay so I raised the head and tried again, now the probe is extended and the red led is not on at all.
        Sent out the M280 P0 S90 command, now the pin went back to its place and the red LED glows constantly.
        Gixxerfastundefined 1 Reply Last reply Reply Quote 0
        • Gixxerfastundefined
          Gixxerfast @re_tour
          @re_tour Good, then that works.
          EDIT: Not needed as you did it above ^ Retract the probe with
          M280 P0 S90
          Then when the probe is above the bed, do a
          G30
          Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
          Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
          Ender 3 Pro with BTT SKR-2 + RRF
          re_tourundefined 1 Reply Last reply Reply Quote 1
          • re_tourundefined
            re_tour @Gixxerfast
            @gixxerfast After doing a G30 the probe extended, the head started going down on the Z axis very slowly until the probe pin reached the bed, when that happened it retracted the probe and the whole rig went up a bit faster.
              Gixxerfast @re_tour
              @re_tour Great. Then all works as it should and what you now want is to configure your homez.g and your homeall.g
              Look here for examples of that:
              https://teamgloomy.github.io/skr_rrf_e3_bltouch.html
              Just make sure to modify the x and y coordinates so that you probe wherever you want. (middle of the bed)
              I am now assuming you have working homex.g and homey.g in your /sys directory
              • re_tourundefined
                re_tour @Gixxerfast
                @gixxerfast Yeah, about that, I already did that.😁
                Here's my homez.g:
                ; ################# Home Z Preparation ################
                G91 															; Relative mode
                G1 H2 Z5 F6000													; Lower the bed
                G90																; Back to absolute positioning
                G1 X117.5 Y117.5 F10000 		 								; Move to the center of the bed. Adjust to the co-ordinates required for the centre of your bed
                M558 F250 				 										; Set the probing speed
                G30					 											; Probe a single point
                M558 F30 				 										; Set a slower probing speed
                and my homeall.g:
                ; homeall.g
                ; called to home all axes
                ; generated by RepRapFirmware Configuration Tool v3.3.1-LPC-STM32+2 on Tue Dec 28 2021 01:07:55 GMT+0100 (közép-európai téli idő)
                G1 H2 Z5 F6000          ; lift Z relative to current position
                G1 H1 X-240 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                G1 H2 X5 Y5 F6000       ; go back a few mm
                G1 H1 X-240 Y-240 F360  ; move slowly to X and Y axis endstops once more (second pass)
                G1 H1 Z-265 F360        ; move Z down stopping at the endstop
                ;G91                    ; relative positioning
                ;G1 Z5 F100             ; lift Z relative to current position
                ;G90                    ; absolute positioning
                Problem is I don't know what I did wrong. It could be the order or something.
                  Gixxerfast @re_tour
                  @re_tour
                  Your homeall.g is missing stuff but this is how I do it and it's not perfect and my Ender so modified now I don't really know what it is any longer but it should work fairly OK:
                  homeall.g:
                  ; homeall.g
                  M98 P"/sys/homex.g"
                  M98 P"/sys/homey.g"
                  M98 P"/sys/homez.g"
                  homex.g:
                  ; homex.g
                  ; called to home the X axis
                  G91
                  if !move.axes[1].homed
                  	; raise Z a bit
                  	G1 H2 Z5
                  G1 H1 X-240 F3000 ; move quickly to X axis endstop and stop there (first pass)
                  G1 H2 X5 F6000    ; go back a few mm
                  G1 H1 X-240 F240  ; move slowly to X axis endstop once more (second pass)
                  homey.g:
                  ; homey.g
                  ; called to home the Y axis
                  G91
                  if !move.axes[0].homed
                  	; raise Z a bit
                  	G1 H2 Z5
                  G1 H1 Y-240 F3000 ; move quickly to Y axis endstop and stop there (first pass)
                  G1 H2 Y5 F6000    ; go back a few mm
                  G1 H1 Y-240 F240  ; move slowly to Y axis endstop once more (second pass)
                  and finally homez.g
                  ; homez.g
                  ; called to home the Z axis
                  ; do nothing if XY is not homed yet
                  if !move.axes[0].homed || !move.axes[1].homed
                      echo "XY are not homed yet. Aborting"
                      abort
                  ;end if
                  G91
                  G1 H2 Z5 F6000
                  G90
                  G1 X130 Y160 F6000
                  G30 K0 Z-99999						    ; Probe the Z pin at the back
                  G1 Z10 F9000
                  Also you cab define two speed probeing with this in your config.g:
                  M558 P9 C"io2.in" H5 F300:120 A3 T6000 ; See the F300:120 first speed 300 second 120
                  When all this is done do a, in order, to test:
                  g28 x
                  g28 y
                  g28 z
                  g28
                  • re_tourundefined
                    re_tour @Gixxerfast
                    @gixxerfast Okay, after doing everything, during the testing all axises find their homes and the Z homing does 3 probing and then stays in place, in the middle. bltouch red led is on constantly.
                      Gixxerfast @re_tour
                      @re_tour Good, then all works as expected.
                      What you want to do now is calibrate your Z offset.
                      I usually do the paper friction thing and just home z and then lower it slowly by G1 Z-0.2 (DON'T FORGET THE G91 before that) (or less) until it's right. Then I adjust the offset in the G31 in config.g
                      • re_tourundefined
                        re_tour @Gixxerfast
                        @gixxerfast said in Ender 3 RRF v1.1 setting up BLtouch:
                        So like
                        G1 Z-0.2
                        *axis moves*
                        G91
                        G1 Z-0.2
                        *axis moves*
                        G91
                        G1 Z-0.2
                        this?
                          Gixxerfast @re_tour
                          @re_tour G91 set's RRF in realtive coordinates mode so you only need to do that once AFAIK. G90 sets it back to absolute coordinates mode.
                          So it's like:
                          G91
                          G1 z-5
                          G1 z-.2
                          G1 Z-.1
                          ... until you're happy
                          then look at the Z offset in DWC (or some gcode command I don't remember right now) and remember it
                          G90
                          Take it down until the nozzle touches the paper and you can feel the friction some when moving the paper. You may need to correct this when printing later but then you can baby step it up and down until it looks fine.
                          I think you do almost the same in Marlin and Klipper. Maybe there's some automated method you can use in RRF but I don't know about it. 🙂
                          • re_tourundefined
                            re_tour @Gixxerfast
                            @gixxerfast Okay, I have a new problem: despite my Z being at 0, there's still about 50-60mm space between the bed and the extruder tip.
                              Gixxerfast @re_tour
                              @re_tour Can you take a screen dump of DWC Dashboard.
                              and also add your latest config.g and homez.g
                              • re_tourundefined
                                re_tour @Gixxerfast
                                @gixxerfast
                                Dashboard:
                                config.g:
                                ; Configuration file for SKR-RFF-E3-v1.1 (firmware version 3)
                                G90                                            ; send absolute coordinates...
                                M83                                            ; ...but relative extruder moves
                                M550 P"Ender3"                                 ; set printer name
                                M552 S1                                        ; enable network
                                M586 P0 S1                                     ; enable HTTP
                                M586 P1 S0                                     ; disable FTP
                                M586 P2 S0                                     ; disable Telnet
                                M569 P0 S0                                     ; physical drive 0 goes backwards using TMC2209 driver timings
                                M569 P1 S0                                     ; physical drive 1 goes backwards using TMC2209 driver timings
                                M569 P2 S1                                     ; physical drive 2 goes forwards using TMC2209 driver timings
                                M569 P3 S1                                     ; physical drive 3 goes forwards using TMC2209 driver timings
                                M584 X0 Y1 Z2 E3                               ; set drive mapping
                                M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                                M92 X80.00 Y80.00 Z400.00 E93.00               ; set steps per mm
                                M566 X1200.00 Y1200.00 Z60.00 E360.00          ; set maximum instantaneous speed changes (mm/min)
                                M203 X9000.00 Y9000.00 Z1800.00 E6000.00       ; set maximum speeds (mm/min)
                                M201 X500.00 Y500.00 Z100.00 E5000.00          ; set accelerations (mm/s^2)
                                M906 X1000 Y1000 Z1000 E1000 I30               ; set motor currents (mA) and motor idle factor in per cent
                                M84 S30                                        ; Set idle timeout
                                M208 X0 Y0 Z0 S1                               ; set axis minima
                                M208 X235 Y235 Z260 S0                         ; set axis maxima
                                M574 X1 S1 P"xstop"                            ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                                M574 Y1 S1 P"ystop"                            ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                                M574 Z1 S1 P"zstop"                            ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                                M950 S0 C"servo0"                              ; create servo pin 0 for BLTouch
                                M558 P9 C"^probe" H5 F300:120 A3 T6000         ; set Z probe type to bltouch and the dive height + speeds,the F300:120 first speed 300 second 120
                                G31 P500 X117.5 Y117.5 Z0                      ; set Z probe trigger value, offset and trigger height
                                M557 X15:215 Y15:195 S20                       ; define mesh grid
                                M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                                M950 H0 C"bed" T0                              ; create bed heater output on bed and map it to sensor 0
                                M307 H0 B0 R0.365 C296.6 D3.97 S1.00 V24.0                               ; disable bang-bang mode for the bed heater and set PWM limit
                                M140 H0                                        ; map heated bed to heater 0
                                M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                                M308 S1 P"e0temp" Y"thermistor" T100000 B4092  ; configure sensor 1 as thermistor on pin e0temp
                                M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                                M307 H1 B0 R2.845 C121.4:119.4 D5.71 S1.00 V24.0                               ; disable bang-bang mode for heater  and set PWM limit
                                M143 H1 S245                                   ; set temperature limit for heater 1 to 245C
                                M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                                M106 P0 C"Part Cooling Fan" S0 H-1             ; set fan 0 name and value. Thermostatic control is turned off
                                M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                                M106 P1 C"Hotend Fan" S0.01 H1 T45             ; set fan 1 name and value. Thermostatic control is turned on
                                M563 P0 D0 H1 F0                               ; define tool 0
                                G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                                G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                                M918 P1 E4 E1000000
                                homez.g:
                                ; homez.g
                                    abort
                                ;end if
                                G91
                                G1 H2 Z5 F6000
                                G90
                                G1 X130 Y160 F6000
                                G1 Z10 F9000
                                  Gixxerfast @re_tour
                                  @re_tour
                                  OK, a few things. I assume you want to replace any old z endstop switch with the probe. Then you need to remove this:
                                  Also I don think you want to set your Z offset in the G32 to 0 (zero). It should reflect the distance between the probe (when triggered) and the nozzle.
                                  • re_tourundefined
                                    re_tour @Gixxerfast
                                    @gixxerfast
                                    I took out this line from config.g:
                                    So to calibrate offset I need to extend the probe with the M280 P0 S10 and watch when the probe touches the bed and then write the value of Z into config?
                                    Sorry, this offset thing is a bit unclear to me.
                                      Gixxerfast @re_tour
                                      @re_tour No, you home z and then you try to lower it to zero. If it's not at zero. you lower it some more manually until "the paper thing". Then you see what actual offset yo have by looking at the z coordinate in, for example, DWC. Then adjust your z offset value in G31 using this value.
                                      Be careful here, it's the other way around the way many thinks of this. A large offset will try to move the nozzle closer to the bed and a small will keep it away.
                                      Anyhow, I'm not very good at this so there is probably a write up about this in the duet documentation.
                                      • re_tourundefined
                                        re_tour @Gixxerfast
                                        @gixxerfast Gotcha.
                                        Okay so now I set the offset in config.g to this:
                                        G31 P500 X117.5 Y117.5 Z5                      ; set Z probe trigger value, offset and trigger height
                                        Then I started lowering the nozzle to do the paper scraper test thingy. Right now I think that the height of the nozzle is optimal. On the dashboard the value of Z at this time is 1.45
                                        So now I have to add that or subtract that from the offset which I wrote in config.g?
                                        Gixxerfastundefined 2 Replies Last reply Reply Quote 0
                                          Gixxerfast @re_tour
                                          @re_tour Try adding it 🙂 (I always mess upp here). Just be close to the breaker
                                            Gixxerfast @re_tour
                                            @re_tour Then again my offset is Z4.370 and I think my probe is as close to the bed as it could really be
