    Ender 3 RRF v1.1 setting up BLtouch
    4.2k
    • re_tourundefined
      re_tour @Gixxerfast
      @gixxerfast Gotcha.
      Okay so now I set the offset in config.g to this:
      G31 P500 X117.5 Y117.5 Z5                      ; set Z probe trigger value, offset and trigger height
      Then I started lowering the nozzle to do the paper scraper test thingy. Right now I think that the height of the nozzle is optimal. On the dashboard the value of Z at this time is 1.45
      So now I have to add that or subtract that from the offset which I wrote in config.g?
      Creality Ender 3 | BIGTREETECH E3 RRF V1.1 Wifi | BLTouch | RepRap 3.3.0_11
      Gixxerfastundefined 2 Replies Last reply Reply Quote 0
      • Gixxerfastundefined
        Gixxerfast @re_tour
        @re_tour Try adding it 🙂 (I always mess upp here). Just be close to the breaker
        Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
        Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
        Ender 3 Pro with BTT SKR-2 + RRF
          Gixxerfast @re_tour
          @re_tour Then again my offset is Z4.370 and I think my probe is as close to the bed as it could really be
          re_tourundefined 1 Reply Last reply Reply Quote 1
          • re_tourundefined
            re_tour @Gixxerfast
            @gixxerfast Stupid question I know, but how will I know that my offset is correct?😁
            Gixxerfastundefined 1 Reply Last reply Reply Quote 0
              Gixxerfast @re_tour
              @re_tour Same way, just lower slowly to zero and see if your paper feels right.
              Then when printing you will probably see that you're to close and you will want to lift it a bit. But all do it differently I think. I just go for a lot of paper friction, it's easier to adjust every corner.
              Also, on the Ender. Don't put too much work into this cause you will do the bed screws anyway with the paper method I guess. Then when it's fairly flat (ish) you'll do a bed mesh.
              • re_tourundefined
                re_tour @Gixxerfast
                @gixxerfast Wait, so if I set up the offset correctly, how do I get from here to be able to do the bed mesh?
                Gixxerfastundefined Stephen6309undefined 2 Replies Last reply Reply Quote 0
                  Gixxerfast @re_tour
                  @re_tour
                  You have something like this in your config.g:
                  ;mesh_min: 30, 15
                  ;mesh_max: 190, 220
                  ;probe_count: 5
                  M557 X30:190 Y15:220 P5                      ; define mesh grid
                  Then you have a file called mesh.g in your /sys directory with something like this in it:
                  G29 S2
                  ; move to the center of the mesh with the PROBE (mind affset in Y is 25 above noozle)
                  G90
                  var xoffset = 37.1
                  var yoffset = 9.25
                  var xpos = {110 - var.xoffset}
                  var ypos = {117.5 - var.yoffset}
                  G1 X{var.xpos} Y{var.ypos} Z15 F6000
                  echo "Setting Probe Offset now"
                  G30 K0
                  G1 Z15 F3000
                  G29 S0
                  The offsets of course depends on where you have your probe mounted.
                  • Stephen6309undefined
                    Stephen6309 @re_tour
                    @re_tour Home all, then mesh.
                    G28
                    G29
                    or
                    G28
                    G32 ; call bed.g
                    In bedg.g I have:
                    ; bed.g
                    if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                     G28
                    M290 R0 S0    ;  clear baby stepping
                    G29 S1 ; load heightmap.csv
                    if result > 1 ; if no heightmap.csv, make one
                     G29 S0
                    re_tourundefined 1 Reply Last reply Reply Quote 0
                    • re_tourundefined
                      re_tour @Gixxerfast
                      @gixxerfast
                      Okay, looks like subtraction is the way to go when calibrating offset 😁
                      Offset is now correct and set to Z3.55.
                      the part you mentioned in config.g looks like this for me:
                      M950 S0 C"servo0"                              ; create servo pin 0 for BLTouch
                      M558 P9 C"^probe" H5 F300:120 A3 T6000         ; set Z probe type to bltouch and the dive height + speeds,the F300:120 first speed 300 second 120
                      G31 P500 X117.5 Y117.5 Z3.55                      ; set Z probe trigger value, offset and trigger height
                      M557 X15:215 Y15:195 S20                       ; define mesh grid
                      But, I don't have a mesh.g in my sys. Do I have to make that for myself or it will autamatically be generated once I run the process?
                      • re_tourundefined
                        re_tour @Stephen6309
                        @stephen6309 I have this in bed.g:
                        ; bed.g
                        ; generated by RepRapFirmware Configuration Tool v3.3.1-LPC-STM32+2 on Tue Dec 28 2021 01:07:55 GMT+0100 (közép-európai téli idő)
                        G29  ; probe the bed and enable compensation
                        Stephen6309undefined 1 Reply Last reply Reply Quote 0
                          Gixxerfast @re_tour
                          @re_tour Great!! I always get that the other way around.
                          If you're happy with your mesh grid go for it
                          You will have to make the file yourself.
                            Gixxerfast @re_tour
                            @re_tour G32 and bed.g is for gantry/bed leveling. G29 and mesh.g is for the bed mesh.
                            In earlier vesrions of RRF I think mesh-g didn't exist so therefore a lot of people still uses bed.g with the G32.
                            Anyhow, the Ender can't level gantry or bed automatically since it only has one z-motor
                            • re_tourundefined
                              re_tour @Gixxerfast
                              @gixxerfast Oh right, so I can only use the bed mesh anyways.
                              Okay so I modified the config.g a little bit:
                              M557 X30:190 Y30:190 P5                       ; define mesh grid
                              and copied your mesh.g, in which I presume I'll have to measure the distances with a ruler or something?
                                @re_tour That will work fine. I have the if statements make sure it's homed and load the height map. Also, I clear the baby stepping, since I update a macro I call to set the Z offset.
                                  Gixxerfast @re_tour
                                  @re_tour Yes, if you don't already know them. Usually mounts have a them in the description/documentation. It's not very precise so ruler works.
                                  As said above, it's probably wise to add this to the top of your mesh.g
                                   G28
                                  But then you should be ready to go 🙂
                                  • re_tourundefined
                                    re_tour @Gixxerfast
                                    @gixxerfast Thank you. Lastly, how do I measure these:
                                    var xoffset = 37.1
                                    var yoffset = 9.25
                                    I mean in relation to what from what?
                                    Also, what kind of bltouch holder do you have? Maybe we have the same which would mean the numbers are mostly correct 😁
                                      Gixxerfast @re_tour
                                      @re_tour I have the Voron Afterburner, so probably not. But I have my probe to the right and behind the nozzle seen standing in fron of the printer.
                                      Should be the same numbers you have in your G31 command
                                      <-------- 37.1 ------->
                                                            x   ^
                                                              9.25
                                      o                         ---
                                      • re_tourundefined
                                        re_tour @Gixxerfast
                                        @gixxerfast Okay, so measured up I now have the following mesh.g:
                                         G28
                                        G29 S2
                                        G90
                                        var xoffset = 44
                                        var yoffset = 18
                                        var xpos = {117.5 - var.xoffset}
                                        G30 K0
                                        G1 Z15 F3000
                                        G29 S0
                                        In which the xpos and ypos is the same as this line in the config.g file:
                                        What is the next step from here?
                                          Gixxerfast @re_tour
                                          @re_tour said in Ender 3 RRF v1.1 setting up BLtouch:
                                          No, this must be wrong
                                          Shouldn't it be:
                                          G31 P500 X44 Y18 Z3.55
                                            Gixxerfast @re_tour
                                            @re_tour When all of this is done. Heat your bed to the standard temp and the home all with
                                            and run mesh compensation:
                                            The you should have a mesh file which you can look at with:
