    Ender 3 RRF v1.1 setting up BLtouch
    4.2k
    • Gixxerfastundefined
      Gixxerfast @re_tour
      @re_tour
      Now, when all this is done. You just have to configure your slicer to output reprap firmware gcode
      In the easiest case you can home and mesh manually and then just load the gcode and print.
      Later, you can add that either directly to custom start/end/layer change gcode in the slicer, but you don't need it to start printing.
      I usually warm the bed a bit before I do a mesh just to make sure it has time deform and go into bowl shape mode before the print.
      Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
      Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
      Ender 3 Pro with BTT SKR-2 + RRF
        Gixxerfast @re_tour
        @re_tour
        Well, that is not correct (maybe I have some faults in mine as well)
        var xpos = {middle of the bed which you can access - var.xoffset}
        var ypos = {middle of the bed which you can access - var.yoffset}
        This gives you a position where the probe is in the middle of the bed.
        I f you just move to the middle of the bed it's the nozzle that's in the middle not the probe...
        There is where you want to probe with G30
        BTW. Your xoffset and yoffset need to be negative here for it to work or you alter the add the values instead above.
        re_tourundefined 1 Reply Last reply Reply Quote 1
        • re_tourundefined
          re_tour @Gixxerfast
          @gixxerfast Well 117.5 on the X axis is the middle for me, on Y it isnt but then I just have to correct it like
          G31 P500 X117.5 Y90 Z3.55
          and then in mesh.g I presume it'll look like this:
          var xoffset = -44
          var yoffset = -18
          var xpos = {117.5 - var.xoffset}
          var ypos = {90 - var.yoffset}
          Right?
          Creality Ender 3 | BIGTREETECH E3 RRF V1.1 Wifi | BLTouch | RepRap 3.3.0_11
          Gixxerfastundefined 1 Reply Last reply Reply Quote 0
            Gixxerfast @re_tour
            @re_tour said in Ender 3 RRF v1.1 setting up BLtouch:
            No, wait a minute here. Everything in G31 is relative to the nozzle, nothing else. You only tell where the probe is relative the nozzle. Nada mas.
            Also, the middle of the bed for you should be 235/2 right? That you only use in the mesh-g file not in the G31 command.
            • re_tourundefined
              re_tour @Gixxerfast
              @gixxerfast Oh alright, so its gonna be this in the config.g:
              G31 P500 X-44 Y-18 Z3.55
              this in the mesh.g:
              var xoffset = -44
              var yoffset = -18
              var ypos = {117.5 - var.yoffset}
              But for some strange reason my nozzle homes to X130 Y160
                Gixxerfast @re_tour
                @re_tour That looks better.
                Well, that's where you go in your homez.g
                G1 X130 Y160 F6000
                You can change it to the same as in the mesh.g
                • re_tourundefined
                  re_tour @Gixxerfast
                  @gixxerfast Oh my god I'm starting to get really exhausted 😬
                    Gixxerfast @re_tour
                    @re_tour Yeah, take a break. Start again tomorrow 🙂
                    It will work now as it is. Maybe not perfectly but good enough to print PLA and stuff.
                    With PC, ABS and ASA it need to be pretty spot on but with PLA it should work fine.
                    You should not print those others anyway with your PTFE lined hotend.
                    re_tourundefined 2 Replies Last reply Reply Quote 1
                    • re_tourundefined
                      re_tour @Gixxerfast
                      @gixxerfast You're right, I'll leave it be for today. I can't thank you enough for all the help, I would be nowhere without your assistance.
                        Gixxerfast @re_tour
                        @re_tour No problems, happy to help out when I can 🙂
                        • re_tourundefined
                          re_tour @Gixxerfast
                          @gixxerfast I'm bosting everythin here so that it won't get lost somehow and I can better check it tomorrow 😁 Maybe someone can find it helpful as well
                          homez.g:
                          ; homez.g
                          ; called to home the Z axis
                          ; do nothing if XY is not homed yet
                          if !move.axes[0].homed || !move.axes[1].homed
                              echo "XY are not homed yet. Aborting"
                              abort
                          ;end if
                          G91
                          G1 H2 Z5 F6000
                          G90
                          G1 X117.5 Y117.5 F6000
                          G30 K0 Z-99999						    ; Probe the Z pin at the back
                          G1 Z10 F9000
                          homex.g:
                          ; homex.g
                          ; called to home the X axis
                          G91
                          if !move.axes[1].homed
                          	; raise Z a bit
                          	G1 H2 Z5
                          G1 H2 Z5 F6000    ; lift Z relative to current position
                          G1 H1 X-240 F3000 ; move quickly to X axis endstop and stop there (first pass)
                          G1 H2 X5 F6000    ; go back a few mm
                          G1 H1 X-240 F240  ; move slowly to X axis endstop once more (second pass)
                          G90               ; absolute positioning
                          homey.g:
                          ; homey.g
                          ; called to home the Y axis
                          G91
                          	; raise Z a bit
                          	G1 H2 Z5
                          G1 H1 Y-240 F3000 ; move quickly to Y axis endstop and stop there (first pass)
                          G1 H2 Y5 F6000    ; go back a few mm
                          G1 H1 Y-240 F240  ; move slowly to Y axis endstop once more (second pass)
                          homeall.g:
                          ; homeall.g
                          ; called to home all axes
                          M98 P"/sys/homex.g"
                          M98 P"/sys/homey.g"
                          M98 P"/sys/homez.g"
                          config.g:
                          ; Configuration file for SKR-RFF-E3-v1.1 (firmware version 3)
                          ; generated by RepRapFirmware Configuration Tool v3.3.1-LPC-STM32+2 on Tue Dec 28 2021 01:07:55 GMT+0100 (közép-európai téli idő)
                          G90                                            ; send absolute coordinates...
                          M83                                            ; ...but relative extruder moves
                          M550 P"Ender3"                                 ; set printer name
                          M552 S1                                        ; enable network
                          M586 P0 S1                                     ; enable HTTP
                          M586 P1 S0                                     ; disable FTP
                          M586 P2 S0                                     ; disable Telnet
                          M569 P0 S0                                     ; physical drive 0 goes backwards using TMC2209 driver timings
                          M569 P1 S0                                     ; physical drive 1 goes backwards using TMC2209 driver timings
                          M569 P2 S1                                     ; physical drive 2 goes forwards using TMC2209 driver timings
                          M569 P3 S1                                     ; physical drive 3 goes forwards using TMC2209 driver timings
                          M584 X0 Y1 Z2 E3                               ; set drive mapping
                          M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                          M92 X80.00 Y80.00 Z400.00 E93.00               ; set steps per mm
                          M566 X1200.00 Y1200.00 Z60.00 E360.00          ; set maximum instantaneous speed changes (mm/min)
                          M203 X9000.00 Y9000.00 Z1800.00 E6000.00       ; set maximum speeds (mm/min)
                          M201 X500.00 Y500.00 Z100.00 E5000.00          ; set accelerations (mm/s^2)
                          M906 X1000 Y1000 Z1000 E1000 I30               ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30                                        ; Set idle timeout
                          M208 X0 Y0 Z0 S1                               ; set axis minima
                          M208 X235 Y235 Z260 S0                         ; set axis maxima
                          M574 X1 S1 P"xstop"                            ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                          M574 Y1 S1 P"ystop"                            ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                          M950 S0 C"servo0"                              ; create servo pin 0 for BLTouch
                          M558 P9 C"^probe" H5 F300:120 A3 T6000         ; set Z probe type to bltouch and the dive height + speeds,the F300:120 first speed 300 second 120
                          G31 P500 X-45 Y-7 Z3.55                      ; set Z probe trigger value, offset and trigger height
                          M557 X30:190 Y30:190 P5                       ; define mesh grid
                          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                          M950 H0 C"bed" T0                              ; create bed heater output on bed and map it to sensor 0
                          M307 H0 B0 R0.365 C296.6 D3.97 S1.00 V24.0                               ; disable bang-bang mode for the bed heater and set PWM limit
                          M140 H0                                        ; map heated bed to heater 0
                          M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                          M308 S1 P"e0temp" Y"thermistor" T100000 B4092  ; configure sensor 1 as thermistor on pin e0temp
                          M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                          M307 H1 B0 R2.845 C121.4:119.4 D5.71 S1.00 V24.0                               ; disable bang-bang mode for heater  and set PWM limit
                          M143 H1 S245                                   ; set temperature limit for heater 1 to 245C
                          M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                          M106 P0 C"Part Cooling Fan" S0 H-1             ; set fan 0 name and value. Thermostatic control is turned off
                          M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                          M106 P1 C"Hotend Fan" S0.01 H1 T45             ; set fan 1 name and value. Thermostatic control is turned on
                          M563 P0 D0 H1 F0                               ; define tool 0
                          G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                          G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                          M918 P1 E4 E1000000
                          bed.g:
                          ; bed.g
                          G29  ; probe the bed and enable compensation
                          mesh.g:
                          if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                           G28
                          M290 R0 S0    ;  clear baby stepping
                          G29 S2
                          ; move to the center of the mesh with the PROBE (mind affset in Y is 25 above noozle)
                          G90
                          var xoffset = -45
                          var yoffset = -7
                          G1 X{var.xpos} Y{var.ypos} Z15 F6000
                          echo "Setting Probe Offset now"
                          G30 K0
                          G1 Z15 F3000
                          G29 S0
                          • re_tourundefined
                            re_tour @Gixxerfast
                            @gixxerfast Hey there! So today I've tried the mesh and it works! This is what I see after running it:
                            So now all is left is to slice the things I want in Cura and upload the gcode which I get? 😁
                            re_tourundefined 1 Reply Last reply Reply Quote 0
                            • re_tourundefined
                              re_tour @re_tour
                              So I started the print, and the filament started to go in the opposite direction. I haven't the slightest clue why.
                                Gixxerfast @re_tour
                                @re_tour Hi there, reverse the extruder motor
                                M569 P3 S0
                                • re_tourundefined
                                  re_tour @Gixxerfast
                                  @gixxerfast said in Ender 3 RRF v1.1 setting up BLtouch:
                                  M569 P3 S0
                                  Thank you so much. Do I have to reverse it every time I turn the printer on or was it just an initial setting mistake I didn't pay attention to? 😁
                                    Gixxerfast @re_tour
                                    @re_tour No, just change it once in config.g and it wasn't a mistake. Really hard to know how the wires are supposed to be, just as long as the pairs are correct it's good. Many has to adjust that AFAIK.
                                    • re_tourundefined
                                      re_tour @Gixxerfast
                                      @gixxerfast Thank you very much!
                                      • re_tourundefined
                                        re_tour @Gixxerfast
                                        @gixxerfast So I didn't input that change into the config.g yet, but wrote it into the console. Printed 2 things, the strange thing is that at the end of each print the mechanism pulls the filament all the way out. Why could that be?
                                          Gixxerfast @re_tour
                                          @re_tour You must have something wonky in your slicer. Check if there some custom end print gcode in Cura (it was Cura you were using, right?)
                                          re_tourundefined 2 Replies Last reply Reply Quote 0
                                          • re_tourundefined
                                            re_tour @Gixxerfast
                                            @gixxerfast Yes sir, let me check.
