    CONSTANT AJAX disconnect errors
    307
    55.1k
    • Jareryundefined
      Jarery
      Similar to KeeganB, my board is set to 16x micro stepping (with interpolation).
      I also do not have a G28 homing in any of my Gcode but as KeeganB states in my Bed command is a G28 at the start. After that the Gcode has no homing until finished.
      My disconnects happen early in a print but unlike KeeganB, mine has never reconnected on its own that I'm aware of.
      I have never seen the reconnect count above 0.
      Edit: mine don't always happen only near start of a print, just that they are a high chance at start. Mine also disconnects just sitting idle sometime.
      I'm about a week away from commissioning a second delta with another duet wifi, based on dc42's large Kossel build. So in a week or so I'll be able to tell if both boards exhibit the same behaviour in my wifi network or if its specific to the one board.
      • lolorcundefined
        lolorc
        Hi there.
        I also have the constant disconnections.
        the disconnections also happen when the printer is idle…
        I also have a tons of issue uploading g-code files through wifi. (when usb is plugged)
        • BlackTomundefined
          BlackTom
          I have had the same kind of issue with 1.19.2, 1.19 is correct.
          I had issues when I was running my bed compensation routine and I had it too when I was printing,
          I always finish by being disconnected of the web interface when I print and I cannot reconnect to it.
          The print continue without issue until it's done so it doesn't affect it
          The only way to get back access to the web interface is by powering off / on the board,
          • lolorcundefined
            lolorc
            @bloood3d:
            same here.
            • botundefined
              bot
              What about when you do a "hard refresh" of the web page through the web browser? On chrome this is done by holding the CTRL key while clicking refresh. In the past, this has helped me get back into a web interface session.
              *not actually a robot
              • KeeganBundefined
                KeeganB
                bot,
                That hasn't worked for me. I have also tried loading the page on difference devices.
                Artemis
                Rostock Max v2
                Orion
                • RGN01undefined
                  RGN01
                  I'm commissioning my new Duet WiFi and have the same issue. I've tried it in two locations (both no more than 10 feet from the WiFi router) and with three clients (desktop PC, Android tablet and Android mobile phone all running Chrome). The desktop PC is best but it still drops the connection frequently - perhaps every 15 minutes - despite the printer not even being fully commissioned (the most it has done is home the towers and heatbed auto set up) and the PC is being used for browsing and email.
                  I hope that this is resolved as it is a bit concerning to someone new to the Duet (which I think is absolutely great!)
                    Have you tried increasing the number of retries in the DWC settings?
                    • RGN01undefined
                      RGN01
                      Thanks, David.
                      I increased it to 5 earlier this evening and it seems to be OK so far on the desktop PC (about 90 minutes) - but the printer and PC are effectively idle.
                      It was set to one initially, is there a recommended larger setting, or is it trial and error?
                      I'll monitor this as I start adding and testing functionality to the printer - and report back.
                        1 is rather low, I think 3 would be a better default.
                        • KeeganBundefined
                          KeeganB
                          At this point I can confidently say mine fits the pattern I mentioned earlier. Every print it starts fine and after a few minutes it disconnects. After probably 30 mins or so, it reconnects without issue and stays connected until I start the next new print.
                          David, I am considering downgrading to 1.19. Is there any reason not to?
                          Artemis
                          Rostock Max v2
                          Orion
                          • Jareryundefined
                            Jarery
                            Interesting yours reconnects. Mine never has, retries I've changed to 5, 10, to no effect.
                            • KeeganBundefined
                              KeeganB
                              Jarery,
                              It may just be that the webpage is auto reloaded by the browser when I come back to the computer and pull it up.
                              Artemis
                              Rostock Max v2
                              Orion
                              • RGN01undefined
                                RGN01
                                Thanks, David. I've dropped it to 3 and am testing that. SO far, so good!
                                • snomonundefined
                                  snomon
                                  Hi guys, I'm having the same problem..Im trying to tell it to print something but it keeps giving me AJAX errors..ctrl+r a few times, i get in at some point. The print then keeps messing up and having me to reset it, not sure why
                                  2:55:56 AMM122
                                  Used output buffers: 3 of 32 (15 max)
                                  RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
                                  Board ID: 08DDM-9FAM2-LW4SD-6J9F6-3S46N-12X7W
                                  Static ram used: 21176
                                  Dynamic ram used: 96104
                                  Recycled dynamic ram: 1504
                                  Stack ram used: 1304 current, 5920 maximum
                                  Never used ram: 6368
                                  Last reset 00:12:18 ago, cause: power up
                                  Last software reset reason: User, spinning module GCodes, available RAM 3136 bytes (slot 4)
                                  Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
                                  Error status: 0
                                  Free file entries: 10
                                  SD card longest block write time: 9.7ms
                                  MCU temperature: min 51.1, current 53.7, max 55.9
                                  Supply voltage: min 23.4, current 24.1, max 24.6, under voltage events: 0, over voltage events: 0
                                  Driver 0: stalled standstill
                                  Driver 1: stalled standstill
                                  Driver 2: stalled standstill
                                  Driver 3: standstill
                                  Driver 4: standstill
                                  Date/time: 2017-09-21 02:55:52
                                  Slowest main loop (seconds): 0.167053; fastest: 0.000034
                                  MaxReps: 6, StepErrors: 0, FreeDm: 240, MinFreeDm 234, MaxWait: 10780ms, Underruns: 0, 0
                                  Scheduled moves: 5, completed moves: 5
                                  Bed compensation in use: none
                                  Bed heater = 0, chamber heater = -1
                                  Heater 0 is on, I-accum = 0.0
                                  Heater 1 is on, I-accum = 0.3
                                  Segments left: 0
                                  Movement lock held by null
                                  http is idle in state(s) 0
                                  telnet is idle in state(s) 0
                                  file is idle in state(s) 0
                                  serial is idle in state(s) 0
                                  aux is idle in state(s) 0
                                  daemon is idle in state(s) 0
                                  queue is idle in state(s) 0
                                  Code queue is empty.
                                  Network state is running
                                  WiFi firmware version 1.19.2
                                  WiFi MAC address 60:01:94:34:40:06
                                  WiFi Vcc 3.14, reset reason Turned on by main processor
                                  WiFi flash size 4194304, free heap 36896
                                  WiFi IP address 192.168.20.81
                                  WiFi signal strength -57dBm
                                  Reconnections 0
                                  HTTP sessions: 1 of 8
                                  Socket states: 2 0 0 0 0 0 0 0
                                  Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                  2:55:49 AMConnection established!
                                  2:55:24 AMDisconnected.
                                  2:55:16 AMConnection established!
                                  2:55:11 AMDisconnected.
                                  2:55:03 AMConnection established!
                                  2:55:01 AMDisconnected.
                                  2:54:53 AMConnection established!
                                  2:54:15 AMDisconnected.
                                  2:52:10 AMConnection established!
                                  2:46:32 AMDisconnected.
                                  2:43:49 AMConnection established!
                                  2:41:46 AMDisconnected.
                                  2:39:46 AMConnection established!
                                  2:38:11 AMDisconnected.
                                  2:33:01 AMConnection established!
                                  2:32:52 AMDisconnected.
                                  2:32:40 AMCalibrated 6 factors using 13 points, deviation before 0.028 after 0.014
                                  2:31:48 AMM32 Enclosure bracket v10(1).gcode
                                  File Enclosure bracket v10(1).gcode selected for printing
                                  2:30:54 AMM0 H1
                                  File Enclosure bracket v10(0).gcode print time was 0h 9m
                                  2:30:07 AMM25
                                  Printing paused
                                  2:25:29 AMConnection established!
                                  2:24:55 AMDisconnected.
                                  2:21:20 AMCalibrated 6 factors using 13 points, deviation before 0.091 after 0.024
                                  2:20:42 AMM32 Enclosure bracket v10(0).gcode
                                  File Enclosure bracket v10(0).gcode selected for printing
                                  2:20:14 AMM0 H1
                                  2:19:53 AMM25
                                  Printing paused
                                  2:11:17 AMCalibrated 6 factors using 13 points, deviation before 0.071 after 0.014
                                  2:10:35 AMM32 Enclosure bracket v10(0).gcode
                                  2:10:08 AMM122
                                  Used output buffers: 1 of 32 (14 max)
                                  Dynamic ram used: 96200
                                  Recycled dynamic ram: 1408
                                  Stack ram used: 4048 current, 9104 maximum
                                  Never used ram: 3184
                                  Last reset 00:31:37 ago, cause: power up
                                  Error status: 0
                                  SD card longest block write time: 0.0ms
                                  MCU temperature: min 54.7, current 55.3, max 55.6
                                  Supply voltage: min 23.4, current 24.0, max 24.4, under voltage events: 0, over voltage events: 0
                                  Driver 0: standstill
                                  Date/time: 2017-09-21 02:10:06
                                  Slowest main loop (seconds): 0.176147; fastest: 0.000000
                                  MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                                  Bed probe heights: 0.245 0.225 0.020 -0.266 -0.374
                                  Heater 1 is on, I-accum = 0.5
                                  Segments left: 0
                                  http is ready with "M122" in state(s) 0
                                  WiFi flash size 4194304, free heap 32424
                                  Reconnections 0
                                  Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                  2:10:00 AMM0 H1
                                  File Enclosure bracket v10.gcode print time was 0h 14m
                                  • mhackneyundefined
                                    mhackney
                                    My update…
                                    I installed a wifi extender on my network to get a better signal to my Duet WiFi. I'm in the range of about -45dBm now, much better than the -79 I had before.
                                    I've been on a business trip for 3 days but have some additional observations.
                                    I've done 10ish prints before the trip and a few yesterday and did not have any disconnects during the print. The disconnects while idle still occur but they are farther between. The reason is
                                    "An AJAX error has been reported, so the current session has been terminated. Please check if your printer is still on and try to connect again."
                                    M122 shows:
                                    MaxReps: 117, StepErrors: 0, FreeDm: 240, MinFreeDm 120, MaxWait: 3180388ms, Underruns: 0, 1
                                    Scheduled moves: 1, completed moves: 1
                                    The good news is, when this happens, I am able to Connect without restarting the Duet. I did read the new wiki on disconnects and found my AJAX retries was set to 1 so I've changed that to 3 and I'll keep watching.
                                    My 3D Printing blog: http://www.sublimelayers.com
                                    Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
                                    • botundefined
                                      bot
                                      Just a note, to anyone who is questioning whether their signal strength is sufficient, here is a great article I found:
                                      https://support.metageek.com/hc/en-us/articles/201955754-Understanding-WiFi-Signal-Strength
                                      Notice the chart at the end that gives general guidelines for required signal strength.
                                      • Jareryundefined
                                        Jarery
                                        Currently I cannot connect at all anymore via web. Ive tried clearing cache, safari and chrome, rebooted the printer 3 times, cycled the wifi on/off.
                                        Consol says it connects to my network and lists assigned ip, but unable to connect.
                                        Edit : connected after about 20min of throwing things at it
                                        Via USB my M122 network is :
                                        WiFi MAC address 5c:cf:7f:a4:a1:64
                                        WiFi Vcc 3.13, reset reason Turned on by main processor
                                        WiFi flash size 4194304, free heap 39944
                                        WiFi IP address 192.168.2.54
                                        WiFi signal strength -33dBm
                                        Reconnections 0
                                        HTTP sessions: 0 of 8
                                        • KeeganBundefined
                                          KeeganB
                                          Ok, after a few more nights of testing, I can confidently say the following:
                                          1. It will stay connected forever at idle.
                                          2. It seems to stay connected forever running G32 commands, and other manual control commands
                                          3. Within minutes of starting a new print, it disconnects. EVERY SINGLE TIME. The same AJAX error every time.
                                          4. After approximately 30-60 mins, it can be reconnected fine and will stay connected forever or until I start a new print.
                                          I am still on 1.19.2, but may downgrade as this is really annoying.
                                          Artemis
                                          Rostock Max v2
                                          Orion
                                            Is the "Error reason:" given in the Ajax disconnect message Timeout, or something else?
