    manual adjustment of the bed level by three screws
    Gcode meta commands
    902
    • Vladimir_Uundefined
      Vladimir_U
      hello.
      I'm trying to make a macro for leveling the bed. My printer is without bltouch sensors. There was a three-point height adjustment on the marlin firmware. The tool head moved to each of the three points and the screw on the base of the bed adjusted the height until the nozzle touched the glass. The algorithm was looped. On RFF I made a looped algorithm of work. But I need that after the height calibration is completed, the tool head goes to the home position and the steppers turn off (the last two commands in the picture) Unfortunately, I do not know how to finish the "while" algorithm correctly so that these two commands work. I will be grateful for any help.
      cosmowaveundefined 1 Reply Last reply Reply Quote 0
        Take a look at this: https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant
        You can use probe type 0 for manual probing. M558 P0. This prompts you to jog the nozzle down to touch the bed when a G30 is used.
        Then you can use the technique described here to loop it with while.
        https://forum.duet3d.com/topic/17872/automatic-bed-leveling-with-conditional-gcode-iterations/79
        Vladimir_Uundefined 1 Reply Last reply Reply Quote 1
        • cosmowaveundefined
          cosmowave @Vladimir_U
          @vladimir_u I can show you my macro for leveling the bed.
          It moves to the four corners, 20mm away from max travel. And it will automatically end after a adjustable time with no input.
          Eventually you can adjust it to your needs, or find some ideas...
          ; LevelAssist macro
          ; this macro helps for manually leveling the bed, it moves the nozzle to 4 probing points (20mm away from min/max area)
          ; the macro will automatically aborted if no user action during 120s
          var EntryTime = state.upTime												; set start time
          var ReturnTime = 120														; set abort time
          if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed		; axles homed ?
          	M291 P"axles not homed! perform homing ?" R"LevelAssist" S3
          	G28																		; homing
          ; loop beginn
          while state.upTime < {var.EntryTime + var.ReturnTime}								; loop until cancel or abort time
          	M291 P"move to Point1 ?" R"LevelAssist" S3								; message
          	G0 Z4																	; Z +
          	G0 X{move.axes[0].min + 20} Y{move.axes[1].min + 20}					; move XY to Point1
          	G0 Z0																	; Z -
          	set var.EntryTime = state.upTime										; reset start time
          	M291 P"move to Point2 ?" R"LevelAssist" S3								; message
          	G0 Z4																	; Z +
          	G0 X{move.axes[0].min + 20} Y{move.axes[1].max - 20}					; move XY to Point2
          	G0 Z0																	; Z -
          	M291 P"move to Point3 ?" R"LevelAssist" S3								; message
          	G0 Z4																	; Z +
          	G0 X{move.axes[0].max - 20} Y{move.axes[1].max - 20}					; move XY to Point3
          	G0 Z0																	; Z -
          	M291 P"move to Point4 ?" R"LevelAssist" S3								; message
          	G0 Z4																	; Z +
          	G0 X{move.axes[0].max - 20} Y{move.axes[1].min + 20}					; move XY to Point4
          	G0 Z0																	; Z -
          	M291 P"once again or cancel ?" R"LevelAssist" S3						; once again?
          Mankati FSXT+, DeltaTowerV2, E3D MS/TC
          fcwiltundefined Vladimir_Uundefined 2 Replies Last reply Reply Quote 1
          • fcwiltundefined
            fcwilt @cosmowave
            @cosmowave
            Interesting.
            Is there a reason you have chosen to not use the Manual Bed Leveling Assistant that is built-in to the firmware?
              cosmowave @fcwilt
              @fcwilt The only reason is, that i wrote this macro before i saw that the fw has a built-in assistant! 😊
                Vladimir_U @cosmowave
                @cosmowave Hello. This is a great macro. I really like it and maybe I'll take some functions from it. But it has a drawback. the same as my original macro. there is no return of the tool head to the home position after adjusting the level. That was my question. I don't know how to do it yet.
                  Vladimir_U @Phaedrux
                  @phaedrux Thanks. I'm going to experiment now.
                  • fcwiltundefined
                    fcwilt @Vladimir_U
                    @vladimir_u said in manual adjustment of the bed level by three screws:
                    Don't use that macro - use the Manual Bed Leveling Assistant (MBLA) that is built-in to the firmware.
                    The needed code is entered into the file bed.g and aside from the commands needed by the MBLA you can add whatever other commands you desire, such as returning to home that you mentioned as wanting.
                    Vladimir_Uundefined 1 Reply Last reply Reply Quote 0
                      Vladimir_U @fcwilt
                      @fcwilt I don't fully understand how to enter the commands correctly. especially the G30.
                      In config.g I entered the command
                      M558 P0
                      M671 X10:190:100 Y 10:10:190
                      In bed.g entered
                      G28
                      G30 P0 X10 Y10 Z0
                      G30 P1 X190 Y10 Z0
                      G30 P2 X100 Y190 Z0 S3
                      G28
                      but it doesn't work. when you enter z-99999, the tool head moves to the desired points. But it offers to move the bed with the Z-axis lead screw. I have to change the G30 somehow, probably.
                      Sorry, I'm not a programmer, unfortunately.
                        Phaedrux Moderator @Vladimir_U
                        That's what M558 P0 does, it asks you to adjust the Z position manually if you don't have a z probe.
                          @phaedrux I don't have bltouch. But I have an end stop at z=0
                            I know you don't have a probe, that's why I suggested using M558 P0 which is manual probing. You can't use the Z endstop to get the lead screw or leveling screw adjustment info because it is fixed. The manual probing lets you tell the firmware where the bed surface is to set Z0 at the various points.
                              @phaedrux It turns out there is no way to simply adjust the plane of the bed by three points without manually rotating the lead screw? But this complicates calibration. Or I'm completely confused.
                                If your bed has it's own leveling screws you can adjust them manually as well.
                                The firmware can only adjust the lead screws automatically if each one has its own driver and motor.
                                Did you review this page? https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant
                                  @phaedrux Yes, the bed has three adjusting screws on springs. I looked at the information on your link. I was guided by it. I may have translated something incorrectly. 😞
                                    Vladimir_U
                                    This post is deleted!
                                      Vladimir_U
                                      I think I found the best option for myself. how wrong is it?
                                      ; bed.g
                                      M98 P"/macros/Bedlevel.g"
                                      G28
                                      M18
                                      ; Bedlevel.g
                                      M291 P"ALL AXES HOME" S0
                                      G28
                                      while true
                                       M291 P"GO TO POINT 1" S0
                                       ; Move to Rear Left leveling point P1
                                       G1 Z5 ; move to z5 for travel
                                       G1 X10 Y10 ; Move to rear left corner
                                       G1 Z0 ; move to z0 to level the bed
                                       M400
                                       M291 P"GO TO POINT 2?" S3
                                       M291 P"GO TO POINT 2" S0
                                       ; Move to Rear Right leveling point P2
                                       G1 X190 Y10 ; Move to rear right corner
                                       M400
                                       M291 P"GO TO POINT 3?" S3
                                       M291 P"GO TO POINT 3" S0
                                       ; Move to Front Right leveling point P3
                                       G1 X100 Y190 ; Move to front right corner
                                       M400
                                       M291 P"GO TO POINT 1?" S3
                                        That is a valid way to do it as well.
                                        I do something similar.
                                        ; Helps guide leveling the bed mechanically, and calibrate the ZProbe trigger height before running a grid bed compensation routine..
                                        ; Preamble to tell the user to prepare the printer before continuing
                                        ;M291 P"Before proceeding make sure the printer is mechanically sound and properly functioning." R"Prepare printer for leveling routine" S3 ; User must click OK
                                        ;M291 P"ZProbe should be configured and working. Clear the print bed of any obstacles or debris." R"Prepare printer for leveling routine" S3 ; User must click OK
                                        ;M291 P"This routine will take about 10-20 minutes and heat both the bed and nozzle." R"Prepare printer for leveling routine" S3 ; User must click OK
                                        ;M291 P"You will need a screwdriver and piece of paper. Filament will be unloaded." R"Prepare printer for leveling routine" S3 ; User must click OK
                                        ;M291 P"Make sure you have successful Gcodes logged to the console before proceeding." R"WARNING" S3 ; User must click OK or cancel
                                        ;M291 P"Make a note of your M558 Z value and backup current heightmap before proceeding." R"WARNING" S3 ; User must click OK or cancel
                                        ; Clear compensation map and Zprobe trigger height
                                        M291 P"Grid bed compensation map will be disabled. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel.
                                        M291 P"Bed and nozzle will preheat and home all axis." R"Preheat and Home" S3 T0 ; User must click OK or cancel
                                        ; Heat up bed and nozzle to PLA temps in prep for filament removal and probing
                                        T0			; Activate first tool
                                        M104 S85		; Set nozzle to 85 and release
                                        M140 S65		; Set bed to 65 and release
                                        G28				; home all
                                        M561			; Disable any current bed compensation
                                        ; Move nozzle forward for filament removal
                                        M291 P"Moving nozzle to the front for filament removal and cleaning." T0
                                        M98 P"0:/macros/1_Nozzle Access.g"		; Moves print head to front left and drops the bed down for easy access
                                        M109 S85		; Set nozzle to 85 and wait
                                        M98 P"0:/macros/Musical Tunes/GetAttention.g" ; Tone to get user attention
                                        ; Unload filament and clean nozzle
                                        M291 P"Unload filament if loaded and clean nozzle, then press OK to continue" R"Unload Filament" S3 T0 ; User must click OK or cancel
                                        ; Preheat to probing temps
                                        M291 P"Preheating the bed to 60 and nozzle to 210 for accurate probing" T0
                                        M104 S210		; Set nozzle to 210 and release
                                        M190 S60		; Set bed to 60 and wait
                                        M109 S210		; Set nozzle to 210 and wait
                                        ; Move nozzle to center of bed at Z10 and drop to Z1
                                        M291 P"Nozzle will now move to center of bed and move close to the bed" T0
                                        M98 P"0:/macros/0_Center Nozzle.g"
                                        G90 G1 Z3 F400	; drop bed for nozzle clearance
                                        G92 Z4 		; Reset z to 8 to allow jogging up to touch bed to nozzle
                                        ; Set lower speeds for Z homing and lower Z motor current
                                        M98 P"ZSpeedsSlow.g"
                                        M400
                                        M913 Z50			; Drop motor current to prevent damage in case of head crash
                                        ; Dialog to allow user to job z to touch nozzle to bed gently and then move Z down 10
                                        M291 P"Carefully Jog the Z Axis until the bed and nozzle are touching and click OK" R"Setting Z=0" Z1 S3
                                        G92 Z0      		; set z = 0
                                        ; Move nozzle to leveling points and prompt user to level bed at each
                                        M291 P"Nozzle will now move to the 3 leveling points twice." S1 T2
                                        ; Move to leveling point 1
                                        G1 Z2      		; move to z2 for travel
                                        M98 P"0:/macros/Calibration/Bed Leveling/1_Leveling Position #1" ; Move to rear left corner
                                        M400
                                        M291 P"Adjust point 1. Jog down by 2 and adjust screw." R"Adjustment Point 1" S2 Z1
                                        ; Move to leveling point 2
                                        G1 Z2			; Move to Z2 for clearance
                                        M98 P"0:/macros/Calibration/Bed Leveling/1_Leveling Position #2"	; Move to rear right corner
                                        M400
                                        M291 P"Adjust point 2. Jog down by 2 and adjust screw." R"Adjustment Point 2" S2 Z1
                                        ; Move to leveling point 3
                                        M98 P"0:/macros/Calibration/Bed Leveling/1_Leveling Position #3"	; Move to front middle
                                        M400
                                        M291 P"Adjust point 3. Jog down by 2 and adjust screw." R"Adjustment Point 3" S2 Z1
                                        ; Repeat to verify
                                        M291 P"The adjustment sequence will now repeat for fine adjustment." S1 T2
                                        M400
                                        M400
                                        M400
                                        ; Turn off heaters
                                        M104 S0		; Set nozzle to 0 and release
                                        M140 S0		; Set bed to 0 and release
                                        M98 P"ZSpeedsNormal.g"
                                        M98 P"CurrentsNormal.g"
                                        M291 P"Homing"
                                        G28		; Home XYZ
                                        M84 ; Turn off the motors
                                        M291 P"The bed has been mechanically leveled and Z0 set." S2
                                        ; Tell user to take values from gcode console log and average the Z height and use that as the new Z probe trigger height
                                        ;M291 P"Average the 10 Z height values in the console and round to 2 decimal places" S2
                                        ;M291 P"The resulting value is the ZProbe trigger height value (M558 Zn)" S2
                                        ;M291 P"Either set the value in config.g and reboot, or send M558 Zn in the console before running G29." S2
                                        ;M291 P"The bed is now mechanically leveled and probe height calibrated." R"Congratulations!" S2
                                        ;M291 P"You may now run a Grid Bed Compensation Detailed Probe. (G92)." S2
                                        ; Run bed grid compensation routine
                                          @phaedrux Thanks.
                                          I removed from the config.g lines
                                          M558 P0
                                          It is ok? Do I need to add something else to the config.g when using my option?
                                            That's fine. You do not need those commands if doing manual adjustments like that.
