Edit Config Data
Hello I installed a new Printing Plate. This Plate is about 3mm higher than the standard one.
How can I download the config data an edit it ----> Upload it again?
Thanks!! -
The config file can be edited using the Duet Web control interface.
https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_System
If you aren't using the web interface you can edit the config.g file on the SD card directly.
@marcel-0 If your using a Z probe for homing, like a BLTouch, you won't need to edit config.g.
@phaedrux Many Thanks:)
