Error: Probe already triggered at start of probing move
Hello, have this error message when homing the z axis. At the Config, I have not changed nothing and the printer worked for 500 hours without a problem. I have installed a Vinda sensor and for the homing of Z is a normal z switch. Can someone help me please
; generated by RepRapFirmware Configuration Tool v3.2.1 on Fri Jan 15 2021 23:22:23 GMT+0100 (MitteleuropƤische Normalzeit); General preferences
M555 P2 ; Set firmware compatibility to look like Marlin
M550 P"Voron V2-1" ; set printer name
M669 K1 ; select CoreXY mode; Network
M551 P"" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet; G29 Mesh
M557 X10:340 Y10:340 S30 ; S30 for high density, S40 for testing; Drives
M569 P0 S1 ; X Motor goes backwards
M569 P1 S1 ; Y Motor goes backwards
M569 P3 S1 ; Extruder Motor 0 goes forwards (BMG)
M569 P5 S1 ; Z1 goes backwards
M569 P6 S0 ; Z2 goes forwards
M569 P7 S1 ; Z3 goes forwards
M569 P8 S0 ; Z4 goes backwards; Z-Axis Stepper Leveling Configuration
M584 X0 Y1 E3 Z5:6:7:8 ; 4 motors; duex 5, 6, 7, 8M92 X80 Y80 Z400 ; Steps per mm
M92 E415.00 ; Steps per mm (BMG) (1.8deg)
M350 E16 I1 ; Configure microstepping with interpolation
M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
M203 X21000 Y21000 E8000 Z4000 ; Set maximum speeds (mm/min) for 2.1 only (300mm/s max)
M201 X3600 Y3200 E4000 Z850 ; Set accelerations (mm/s^2)
M566 X240 Y300 E1200 Z120 ; Set maximum instantaneous speed changes (mm/min)
M98 P"/macros/print_scripts/xy_current_high.g" ; Set XY Motor Currents
M98 P"/macros/print_scripts/e_current_high.g" ; Set Extruder Motor Currents
M98 P"/macros/print_scripts/z_current_high.g" ; Set Z Motor Currents (must come after extruder, because on the extruder headers)
M84 S0 ; Set idle timeout, never time out; Axis Limits
M208 X0:350 Y-10:350 Z0:300 ; set axis minima and maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Inductive Leveling Sensor
M98 P"/macros/probe_scripts/activate_z_probe.g" ; activate the Z probe
M98 P"/macros/probe_scripts/activate_z_switch.g" ; activate the Z switchM671 X410:410:-60:-60 Y350:-80:-80:350 S20 ; belts in all 4 corners
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M98 P"/macros/PID/ABS_PID.g" ; Set model parameters for heater 0 and use PID mode?
M308 S1 P"e0temp" Y"thermistor" T100000 B4750 ; define E0 temperature sensor (B4725)
M950 F0 C"duex.fan3" Q500 ; create fan 0 on pin duex.fan3 and set its frequency
M950 F1 C"duex.fan4" Q500 ; create fan 1 on pin duex.fan4 and set its frequency
M950 F2 C"duex.fan5" Q500 ; create fan 2 on pin duex.fan5 and set its frequency
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M575 P1 S1 B57600 ; enable support for PanelDue; Enable config-override.g
;M501; Allow Movement of Axis that have not been homed
M564 H00:/macros/Probe_Scripts/activate_z_probe.g
M558 P5 C"^zprobe.in" H20 A5 S0.020 F1200 T18000 ; set Z probe type to switch and the dive height + speeds
G31 P1000 X0 Y-28.0 Z1.322 ; Setup Offsets for Z Switch0:/macros/Probe_Scripts/activate_z_switch.g
M574 Z0 P"nil" ; no Z endstop switch, free up Z endstop input
M558 P5 C"zstop" H5 F400 T3000 ;Z Probe connector to Z endstopG31 P1000 X0 Y0 Z-0.40 ; Setup Offsets for Z Switch
can nobody help me ? the probe is active all the time even if i disconnect the cables. I loaded the config on my second print for testing and I can't find any errors there (both prints are voron 2)
@joe92 said in Error: Probe already triggered at start of probing move:
If the same config works on the other printer with the same hardware that would mean there is a wiring problem with the probe.
@phaedrux at the moment only x and x are homing. at z comes the error message but then tried g30 s-1 and the probe works normally. I also disconnected the probe from the board but the value on the web control remains at 1000
Can you send M122 and M98 P"config.g" and post the results?
@phaedrux m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DGM-956GU-DJ3S0-7JKFJ-3SD6M-1TFHG
Used output buffers: 3 of 24 (11 max)
Static ram: 23876
Dynamic ram: 75852 of which 28 recycled
Never used RAM 14660, free system stack 174 words
Tasks: NETWORK(ready,12.9%,237) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) DUEX(notifyWait,0.0%,24) MAIN(running,86.5%,443) IDLE(ready,0.4%,29), total 100.0%
Owned mutexes:
Last reset 00:02:59 ago, cause: power up
Last software reset at 2022-01-25 19:19, reason: User, GCodes spinning, available RAM 11676, slot 2
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 31.8, current 37.5, max 37.7
Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0, standstill, SG min/max not available
Driver 6: position 0, standstill, SG min/max not available
Driver 7: position 0, standstill, SG min/max not available
Driver 8: position 0, standstill, SG min/max not available
Driver 9: position 0, standstill, SG min/max not available
Driver 10: position 0
Driver 11: position 0
Date/time: 2022-01-26 05:40:12
Slowest loop: 6.95ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 2.7ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== DueX ===
Read count 1, 0.33 reads/min
=== Network ===
Slowest loop: 15.91ms; fastest: 0.00ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address 8c:aa:b5:d5:7e:45
WiFi Vcc 3.35, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 23968
WiFi IP address 192.168.0.67
WiFi signal strength -39dBm, mode none, reconnections 0, sleep mode modem
Clock register ffffffff
- WiFi -
@phaedrux M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: Pin 'zstop' is not free
Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 558C -
Is something broken on the board or is it a config setting? -
Is something broken on the board or is it a config setting?No I think that's because your zstop pin is already been used when you run M98 P"config.g"
M558 P5 C"zstop" H5 F400 T3000 ;Z Probe connector to Z endstopThis macro gets called and uses zstop. And when you send M98 config.g it tries to use zstop again in your m574 command, but it's already in use from that macro.
Can you post your homing files and bed.g/mesh.g files as well?
bed.g
; setup for quad belt gantryM561 ; Clear any existing bed transform
G28 ; homeM98 P"/macros/probe_scripts/activate_z_probe.g" ;activate inductive z-probe
; Probe bed at these 4 points:
G30 P0 X290 Y290 H0 Z-99999
G30 P1 X290 Y60 H0 Z-99999
G30 P2 X60 Y60 H0 Z-99999
G30 P3 X60 Y290 H0 Z-99999 S4G28 Z ; Home Z Axis
; homeall.g
; called to home all axesG91 ; Relative
G1 H2 Z5 F2000 S2 ; Lower bed 15mm
G1 H1 X-300 Y-300 F2000 S1 ; Coarse home X and Y
G1 H1 X-300 S1 ; Coarse X in case Y homed first
G1 H1 Y-300 S1 ; Coarse Y in case X homed first
G1 H0 X5 Y5 F2000 ; Move away from the endstops
G1 H1 X-300 F360 S1 ; Fine home X
G1 H1 Y-300 F360 S1 ; Fine home YM98 P"/macros/print_scripts/xy_current_high.g" ; Restore motor currents
G90 ; Absolute positioning; Go to z switch and home z axis
M98 P"/macros/probe_scripts/activate_z_switch.g" ; Activate Z Switch
M98 P"/macros/probe_scripts/goto_z_switch.g" ; Go To Z SwitchG30 Z-99999 ; Probe Z Switch
G0 Z5
M98 P"/macros/probe_scripts/goto_nozzle_scrubber_and_scrub.g" ; Scrub Nozzle
G0 Z20
M98 P"/macros/probe_scripts/activate_z_probe.g" ; Activate Z Probe
; homez.g
; called to home the Z axis
;; Lift Z relatively to current position
G91
G1 H2 Z5 F2000 S2; Back to absolute positioning
G90; Go to z switch and home z axis
G0 Z5
G0 Z20
What is the order of operations that gets you to the error message?
Turn on the printer and press homeall in DWC?
Just trying to understand the flow of gcode commands.
However, if it's worked for 500 hours without issue up until now with the same config, and the same config works on your other printer, then I have to think it's a hardware issue. Most likely with the probe itself or with it's wiring.
@phaedrux
Yes, home all is the first thing I do, but I have now installed the duet from the other printer and everything works. I completely erased the board with the defect and wrote it with the latest software, but the error is still there in the other printer -
can you tell me/show me the wiring for your probe?
Can you grab some photos of the board with the problem?
@phaedrux I can take the photos after work
found the fault in the cable to the z switch. a broken wire has trigged the z stop
