    Duet 2 Ethernet WC 3.3.0 crashes, have to reset to reconnect
    Duet Web Control
    4.8k
    • airscapesundefined
      airscapes @airscapes
      @airscapes pint job done, did not look at the dang gui first, went and pulled the bed out on the Y axis to remove the print. Went to pc and was disconnected. Could not ping
      oot@ [/root] # ping 192.168.1.245
      PING 192.168.1.245 (192.168.1.245) 56(84) bytes of data.
      From 192.168.1.101 icmp_seq=1 Destination Host Unreachable
      From 192.168.1.101 icmp_seq=2 Destination Host Unreachable
      From 192.168.1.101 icmp_seq=3 Destination Host Unreachable
      From 192.168.1.101 icmp_seq=4 Destination Host Unreachable
      From 192.168.1.101 icmp_seq=5 Destination Host Unreachable
      From 192.168.1.101 icmp_seq=6 Destination Host Unreachable
      From 192.168.1.101 icmp_seq=7 Destination Host Unreachable
      From 192.168.1.101 icmp_seq=8 Destination Host Unreachable
      Still have flashing green light and orange link light.
      Had to push da reset button.. again. 😞
      airscapesundefined 1 Reply Last reply Reply Quote 0
        @Phaedrux
        Just found one thing that "Might" be causing this issue but not positive. I had the network set to DHCP and I also had forgotten to add a Fixed entry for the host in the router. I am doubtful this is it, because I would not think the gui would return me a message that a network error had occurred if it just get a new IP and did not look when it was offline. I now have the Duet set to a fixed IP and the router set so that mac always get that same IP or should I say, so it does not give that IP to anyone else.
        Is there a way to add additional logging and is there a CLI to the OS from the USB connections to see if the Web interface is still running should I get another failure??
        BTW I did verify that disconnecting the network and reconnecting works just fine.. i.e. remove the cable wait a few moment, plug it back in, gui still works as it should. So other than an IP address no longer being on the interface or the IP I was expecting.. I don't think this is related to anything external in the network.
        Thanks!
          If you get a disconnection again use the USB terminal again as you did when you got the M122 report but this time send M552 and see what IP address it has.
            airscapes @Phaedrux
            @phaedrux Yep, will do! Have not used the printer but have several things to print today. Seems like my configuation failures would very likely cause the symptoms.. The nic was not dead, link and trafic lights still working so no IP or different IP makes perfect sense.
              @Phaedrux So much for that.. just lost connection after canceling a print job and homing Z. Ran the 552 and 122 again, also started the job from the usb connection without resetting the board if there is something else I can do to try and figure this out..
              Recv: Network is enabled, configured IP address: 192.168.1.245, actual IP address: 192.168.1.245
              Recv: ok
              From pc to printer
              Pinging 192.168.1.245 with 32 bytes of data:
              Reply from 192.168.1.161: Destination host unreachable.
              Ping statistics for 192.168.1.245:
              Packets: Sent = 1, Received = 1, Lost = 0 (0% loss),
              Control-C♣
              Here is m122 again
              Send: M122
              Recv: === Diagnostics ===
              Recv: RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet Ethernet 1.02 or later
              Recv: Board ID: 0JD0M-9P6B2-NJ4S8-6J1F2-3S46M-KU66M
              Recv: Used output buffers: 1 of 24 (22 max)
              Recv: === RTOS ===
              Recv: Static ram: 23876
              Recv: Dynamic ram: 70804 of which 320 recycled
              Recv: Never used RAM 16560, free system stack 112 words
              Recv: Tasks: NETWORK(ready,762.2%,225) HEAT(delaying,0.9%,330) Move(notifyWait,3.5%,313) MAIN(running,302.5%,420) IDLE(ready,0.2%,29), total 1069.2%
              Recv: Owned mutexes: USB(MAIN)
              Recv: === Platform ===
              Recv: Last reset 03:56:56 ago, cause: power up
              Recv: Last software reset at 2022-01-23 12:09, reason: User, GCodes spinning, available RAM 16560, slot 2
              Recv: Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
              Recv: Error status: 0x00
              Recv: Step timer max interval 0
              Recv: MCU temperature: min 20.4, current 54.9, max 59.3
              Recv: Supply voltage: min 23.7, current 23.8, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
              Recv: Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/120/120, gc cycles 0
              Recv: Driver 0: position 0, standstill, SG min/max 0/355
              Recv: Driver 1: position 178, standstill, SG min/max 0/360
              Recv: Driver 2: position 213533, standstill, SG min/max 0/1023
              Recv: Driver 3: position 0, standstill, SG min/max 0/1023
              Recv: Driver 4: position 0, standstill, SG min/max not available
              Recv: Driver 5: position 0
              Recv: Driver 6: position 0
              Recv: Driver 7: position 0
              Recv: Driver 8: position 0
              Recv: Driver 9: position 0
              Recv: Driver 10: position 0
              Recv: Driver 11: position 0
              Recv: Date/time: 2022-01-25 11:36:51
              Recv: Cache data hit count 4294967295
              Recv: Slowest loop: 90.23ms; fastest: 0.09ms
              Recv: I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0
              Recv: === Storage ===
              Recv: Free file entries: 10
              Recv: SD card 0 detected, interface speed: 20.0MBytes/sec
              Recv: SD card longest read time 4.0ms, write time 40.0ms, max retries 0
              Recv: === Move ===
              Recv: DMs created 83, maxWait 9607499ms, bed compensation in use: none, comp offset 0.000
              Recv: === MainDDARing ===
              Recv: Scheduled moves 1, completed moves 1, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
              Recv: === AuxDDARing ===
              Recv: Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
              Recv: === Heat ===
              Recv: Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
              Recv: Heater 0 is on, I-accum = 0.8
              Recv: Heater 1 is on, I-accum = 0.3
              Recv: === GCodes ===
              Recv: Segments left: 0
              Recv: Movement lock held by null
              Recv: HTTP is idle in state(s) 0
              Recv: Telnet is idle in state(s) 0
              Recv: File is idle in state(s) 0
              Recv: USB is ready with "M122" in state(s) 0
              Recv: Aux is idle in state(s) 0
              Recv: Trigger is idle in state(s) 0
              Recv: Queue is idle in state(s) 0
              Recv: LCD is idle in state(s) 0
              Recv: Daemon is idle in state(s) 0
              Recv: Autopause is idle in state(s) 0
              Recv: Code queue is empty.
              Recv: === Network ===
              Recv: Slowest loop: 193.31ms; fastest: 0.02ms
              Recv: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
              Recv: HTTP sessions: 0 of 8
              Recv: Interface state active, link 100Mbps full duplex
              Recv: ok
                When and where did you purchase your Duet?
                  airscapes @Phaedrux
                  @phaedrux MatterHackers.com Nov 20 2021
                    Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                      airscapes @Phaedrux
                      @phaedrux Ok, thanks! Will post how it goes. Email sent
                        @airscapes said in Duet 2 Ethernet WC 3.3.0 crashes, have to reset to reconnect:
                        The return has been started, still waiting to hear details from Matterhackers about what to do next but they did email me and said I would be contacted.
                        I have been using the printer today with no issues until I smacked a print with the spatula to remove it, when I returned to the desk the network connection was gone. Guess the vibrations is all it took as I did not move any cables or touch the board enclosure.
                          @Phaedrux Return initiated and shipping shortly!!
                          This has been one of the best trouble shooting and return process I have ever had. Top notch and thanks you very much!
                          airscapesundefined 1 Reply Last reply Reply Quote 1
                            @Phaedrux
                            Wow this is not good.. Replacement board installed on the weekend. Did my first print today. PETG so no heat in the enclosure, 35 minute print job, finished, when into the other room pulled the bed out manually (been doing that since I got it as the manufacture said it is fine to do. removed the print, returned to desk and I am now disconnected. Checked m552 still had an IP, network module still flashing lights. connected to usb with octoprint, head bead still on as it should have been as I did not turn it off at the end of the job. Hit reset button, and after boot was back on the network. So what is the next step. Guess I will email Matterhackers and let them know still have the same problem?? Is there any more trouble shooting we can do. can not recreate problem on demand.
                              It's pretty unlikely that the new board has an issue with ethernet as well. I think it's more likely that the issue is on the network hardware side. The Duet appears to still have an address and seeing activity.
                              What network hardware is between your PC and the Duet? Do you have any means of testing something alternative?
                                airscapes @Phaedrux
                                @phaedrux I have tested it the with the first card. Cable was sent directly from the failed duet to the switch in a different port. Remember it can be correct by pushing the reset button on the board, so how would that fix my network? I would like it to be a bad cable, but it is not, that was swapped out with the old board and no change. so far I have not had a second failure. I used it all day yesterday and today. Without being able to reproduce the problem on demand it is going to be very difficult to track down.
                                Are there any other logs that can be configured on the duet?
                                I had thought it was maybe triggered by heat, but when it happened with the new board, I was printing PETG. Today all Day had the enclosure running at 100F printing ABS with no failures.. I am willing to try anything.
                                Questions; If next time it fails, I remove the network cable from the car and plug in a different cable, running it directly to the switch and into an unused port, would you assume that eliminates my network?
                                Currently the network path is; switch to jack, cable through wall to jack, Jack to 8 port switch which has the pi (octoprint) and the duet plugged into it. Booth switches are Dlink Unmanaged switches, a 24 port and 8port, DHCP is from the WAN router which is a Fios Gateway. I have many devices on the network with no issues on any of them.
                                Is there a way to ping the gateway from the USB connection using octoprint next time the failure occurs?
                                Also not sure on how the serial numbers work, but the first one was w09221 and the replacement is w09219. I am guessing they were built with all the same lot of parts and could wave to each other on the production line.
                                I just want to get to the root cause and correct it, be it local network or bad solder joint between the module and board etc.
                                After having 6 hard drives go bad in new IBM P950 enterprise servers servers within a week, I know even new enterprise class hardware can be manufactured with defects, and of course even technical users do make dumb mistakes, so please any other ideas on ways to track this next time it happens will be much appreciated!
                                Just thought of something the maybe I am doing wrong? My assumption was I can access the WC from multiple remote locations at the same time. For instance, I login from the browser on the Pi that is plugged into the same 8 port switch were the Duet it connected and sits next to the printer to load filament. I also connect from my PC in the other room. When the failure happens both browsers are disconnected. Now this is not what is causing my issue is it?? I mean I do this with the pi all the time when I was using octoprint so I assumed it is just a web interface and would not matter how many connections I make?
                                  @Phaedrux OK in failed state after first print of the day finished. I ran a known good network cable from an open port of the 24 port switch directly to the duet.
                                  The duet shows link, and shows activity light, switch end show link but no activity. Moved same cable from duet to pi, get link and activity at switch.
                                  Using the USB connection to Octoprint I disabled the networking on the Duet and then Enabled it setting the IP as it was prior. Refreshed the browser and after a few seconds got connected to WC!
                                  So what does this tell you? Seems like software/frimware process died and needed to be restarted? Again I will ask is there a way to see a process table from USB or from other means I may have access to?
                                  trobisonundefined 1 Reply Last reply Reply Quote 0
                                  • trobisonundefined
                                    trobison @airscapes
                                    @airscapes I had my first board replaced. Unfortunately, this board is doing the same. "Connection lost, attempting to reconnect." I purchased a screen as I could not rely on the ethernet connection on the Duet 2. My machine is on, not printing, and I can see that I require a reboot to fix the behaviour. I was looking at the config.g file to determine what I might have to do if I upgrade to version 3.4.0. I have tried three different switches, several cables, and I get the same errors. This isn't what I expected. On long prints, the screen has been the only way to interact with the Duet 2. Once the network goes funky, cycling the power appears to be the only way to restore communication.
                                      airscapes @trobison
                                      @trobison said in Duet 2 Ethernet WC 3.3.0 crashes, have to reset to reconnect:
                                      @trobison Have you tired to connect to the USB port with a terminal program, send M552 S0 to disable network, then send 552 S1 Pxx.xx.xx.xx to enable network and set your IP? This worked for me yesterday after the connection dropped. The network came back, never hit reset and worked the rest of the day. I would also like to know what the serial number is on your board? There is a sticker on the box in came in and one on the CPU on the board. If you already exchanged it I would assume you know that. Seems like something crashes in the network module if my workaround continues to enable the connection after failure? I am lucky, as I was using octoprint with the printers for years before this "Upgrade" . I must say, I have grown to like the DWC interface as much if not more than octoprint for what I do. Please send your issue to your reseller if you have not already done so and ask them to forward your issue to Ronald@duet3d.com as he is the person Matterhackers forwarded mine to.
                                      Would be good from them to know there are multiple customers with the same issue if they don't already know about it.
                                      Thanks for posting and validating this is a real problem unrelated to external network issues.
                                        We are trying to work out a way to get you a replacement ethernet module to test with. Thanks for your patience.
                                        @trobison Do you have a thread of your own discussing your issue already?
                                          airscapes @Phaedrux
                                          @phaedrux No worries, this is really a weird one. My first board is on it's way back to Matter Hackers, should be there by now so not sure how long it will take to get back to manufacture location. That one failed much more often than this one.
                                          I have been printing ABS parts for the past 2 days with as much as a blip.. Wish I knew what triggered it, but glad I have a work around that does not involve resetting the board since the print job is not interrupted in any way.
                                          • trobisonundefined
                                            trobison
                                            No, I did not create a thread. I tried connecting via USB and resetting the network. I still have the same issues with network drop outs. The chip has a sticker of DUET2 Main W06367. This morning I powered on the printer and attempted to print. I have issues loading files to the printer, the network drops out. Nic lights are correct, but the connection drops randomly. It faults more while printing.
                                            13/02/2022, 09:36:19	Failed to upload Desk_Stand.gcode
                                            Could not complete action because the connection has been terminated
                                            13/02/2022, 09:36:19	Connection interrupted, attempting to reconnect...
                                            Network error
                                            13/02/2022, 09:35:57	Successfully deleted TESTPRINT.gcode
                                            13/02/2022, 09:31:02	Finished printing file 0:/gcodes/TESTPRINT.gcode, print time was 0h 48m
                                            13/02/2022, 09:31:00	Connection established
                                            13/02/2022, 09:31:00	Connection interrupted, attempting to reconnect...
                                            Operation failed (Reason: Service Unavailable)
                                            13/02/2022, 09:10:37	Connection established
                                            13/02/2022, 09:10:36	Failed to upload Print-In-Place Phone holder.gcode
                                            13/02/2022, 09:10:36	Connection interrupted, attempting to reconnect...
                                            Network error
                                            13/02/2022, 09:08:25	Successfully deleted 2 items
                                            13/02/2022, 08:40:55	Cancelled printing file 0:/gcodes/TESTPRINT.gcode, print time was 0h 5m
                                            13/02/2022, 08:40:46	Resume state saved
                                            Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
                                            13/02/2022, 08:39:01	Connection established
                                            13/02/2022, 08:39:00	Connection interrupted, attempting to reconnect...
                                            13/02/2022, 08:37:36	Connection established
                                            13/02/2022, 08:37:36	Connection interrupted, attempting to reconnect...
                                            13/02/2022, 08:35:33	M32 "0:/gcodes/TESTPRINT.gcode"
                                            File 0:/gcodes/TESTPRINT.gcode selected for printing
                                            13/02/2022, 08:35:25	Upload of TESTPRINT.gcode successful after 5s
                                            13/02/2022, 08:35:02	Connected to 192.168.10.60
                                            13/02/2022, 09:54:06	m122
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet Ethernet 1.02 or later + DueX5
                                            Board ID: 0JD0M-9P6M2-NWNS0-7J9DJ-3SJ6S-K90RJ
                                            Used output buffers: 12 of 24 (24 max)
                                            Static ram: 23876
                                            Dynamic ram: 73712 of which 0 recycled
                                            Never used RAM 13972, free system stack 98 words
                                            Tasks: NETWORK(ready,29.2%,231) HEAT(delaying,0.1%,330) Move(notifyWait,0.2%,307) DUEX(notifyWait,0.0%,24) MAIN(running,70.4%,441) IDLE(ready,0.1%,29), total 100.0%
                                            Owned mutexes:
                                            Last reset 00:12:46 ago, cause: power up
                                            Last software reset at 2022-02-12 17:20, reason: User, GCodes spinning, available RAM 16828, slot 2
                                            Error status: 0x0c
                                            Aux0 errors 0,1,0
                                            MCU temperature: min 34.1, current 37.9, max 38.0
                                            Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                            Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/86/0, gc cycles 0
                                            Driver 0: position 15650, ok, SG min/max 0/1023
                                            Driver 1: position 754, ok, SG min/max 0/1023
                                            Driver 2: position 4627, ok, SG min/max 0/1023
                                            Driver 3: position 3641, standstill, SG min/max not available
                                            Driver 4: position 0, ok, SG min/max 0/1023
                                            Driver 5: position 0, standstill, SG min/max not available
                                            Driver 6: position 0, standstill, SG min/max not available
                                            Driver 7: position 0, standstill, SG min/max 0/56
                                            Driver 8: position 0, standstill, SG min/max not available
                                            Driver 9: position 0, standstill, SG min/max not available
                                            Date/time: 2022-02-13 09:54:06
                                            Slowest loop: 175.42ms; fastest: 0.14ms
                                            === Storage ===
                                            Free file entries: 9
                                            SD card longest read time 1.2ms, write time 50.3ms, max retries 0
                                            DMs created 83, maxWait 291747ms, bed compensation in use: mesh, comp offset 0.000
                                            === MainDDARing ===
                                            Scheduled moves 2259, completed moves 2229, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state 3
                                            === AuxDDARing ===
                                            Heater 0 is on, I-accum = 0.2
                                            Heater 2 is on, I-accum = 0.5
                                            Segments left: 1
                                            File is doing "G1 X81.698 Y83.929 E304.1846" in state(s) 0
                                            USB is idle in state(s) 0
                                            === DueX ===
                                            Read count 1, 0.08 reads/min
                                            === Network ===
                                            Slowest loop: 202.93ms; fastest: 0.02ms
                                            HTTP sessions: 2 of 8
