    PanelDue is not starting any print job [SOLVED]
    PanelDue
    1.5k
      Check the Console page of the PanelDue and the web interface for error messages. Perhaps you didn't home the printer?
      • duetinoundefined
        duetino
        Hi I checked the console and it says File selected for printing…. and even in the web interface it does the same, but no error at all? Fast bargraph done -> reprint -> same again.
        Totally lost here?
        do it to it -> rinse and repeat
          deckingman
          Can you just confirm that the web interface does the same. i.e is it as the thread title that you can't print from Pane Due, or is it acse that you can't print from either the web interface or PanelDue? And does it show print complete 100% done?
          • Dougal1957undefined
            Dougal1957
            have you definitely got a tool selected I have seen this behaviour if you don't
            • duetinoundefined
              duetino
              As you can see from the start script I got T0, which is pretty much a tool selection I guess, or do I have to confirm it somewhere?
              all the best
                Dougal1957
                try putting a T0 at the end of your Config.g I agree the one in the start should do it but S3D can ignore things like that from time to time
                • duetinoundefined
                  duetino
                  I have that multiple times now everywhere
                  OK, now I can say if I take the uploaded file from S3D and want to print it via WebControl. It does not print as well. Same behaviour. But if I upload the file via WebControl via Upload and Print it does it fine.
                  all the best
                  • duetinoundefined
                    duetino
                    OK I figured it out now…. Whooheee!!!!
                    Slightly modified postprocessing script:
                    [[bash]]
                    path=[output_filepath]
                    file=${path##*/}
                    curl --data-binary "@[output_filepath]" http://192.168.0.85/rr_upload?name=gcodes/[output_filename].gcode
                    logger "Writing file to 3DPrinter via: curl --data-binary "@[output_filepath]" http://192.168.0.85/rr_upload?name=gcodes/[output_filename].gcode"
                    curl http://192.168.0.85/rr_gcode?gcode=M140S50
                    curl http://192.168.0.85/rr_gcode?gcode=G10P0R120S200
                    curl http://192.168.0.85/rr_gcode?gcode=T-1
                    If you are courious what the difference is
                    1. I tried to find a debug possibility with logger -> install logutils and you can directly log into syslog | Check
                    2. I found out that the file I uploaded was completely different in size and behaviour -> changed to data-binary option | Check
                    Voila printing from PanelDue and WebControl -> no problemo
                    Could have been so easy, but the dog lies in detail (or whatever you say in english)
                    all the best duetino
                    • duetinoundefined
                      duetino
                      How can I mark the thread as solved?
                        deckingman
                        @duetino:
                        Edit the title in the opening post is one way.
                        • duetinoundefined
                          duetino
                          Thanks guys, even no direct hint brought me to THE solution, and also edit the title is even better… did that and I guess nobody can tell if I did hit a button or not.
                          BTW, there is an Answer button, which marks the solution of the thread, don't know if that leads to a double solved ?
                          Great work/help/assistance anyway
                          • duetinoundefined
                            duetino
                            Actually I want to leave it like this but for everybody to visualize the difference of a little misconfiguration…
                            The (left) part with line numbers is correct, the other is as well just without carriage return and linefeed uploaded as one big line.
