    Why first move of tue bed leveling is going up?
    Gcode meta commands
    838
    • fcwiltundefined
      fcwilt @Arisoy
      @arisoy said in Why first move of tue bed leveling is going up?:
      @fcwilt But i'm printing and it works fine! What can be wrong in the configuration or wiring?
      Hard to say.
      Please copy-and-paste your config and homing files using the </> tag - one per file.
      • infiniteloopundefined
        infiniteloop @Arisoy
        A lot. I think of two gcodes in your config.g which might result in the behaviour you describe:
        M558: is the dive height ("H") properly set?
        G31: the probe offset ("Z") might be too low
        Don't know what kind of probe you have - depending on that you might use two macros as well: deployprobe.g and retractprobe.g.
        To put things right, you should test the function of the probe at a safe location on your bed first, before you jump right into bed levelling.
        Arisoyundefined 1 Reply Last reply Reply Quote 0
        • Arisoyundefined
          Arisoy @infiniteloop
          @infiniteloop @fcwilt I'm using a bltouch for z probe. I hommit to mention that after the bed moves up a little. The true bed leveling process continue and everything works fine. But because of that first move the probe is really close to the bed. And if the bed is not already horizontal the probe touches it and the process stops.
          Here you can find my files :
          config.g
          ;;;;;;;;;; General preferences ;;;;;
          G90                                     ; Send absolute coordinates...
          M83                                     ; ...but relative extruder moves
          M550 P"V-Core 3"                        ; Set printer name
          M669 K1                                 ; Set printer type as CoreXY
          G29 S1                                  ; Set Units to Millimeters
          G4 S1									; Wait for the expansion board to start
          M404 N1.75 D0.4                         ; Filament width and nozzle diameter
          ;;;;;;;;;; Network ;;;;;;;;;;
          M552 S1                                 ; enable WiFi
          M586 P0 S1                              ; enable HTTP
          M586 P1 S0                              ; disable FTP
          M586 P2 S0                              ; disable Telnet
          ;;;;;;;;;; Drives ;;;;;;;;;;
          M569 P0.0 S1 D3                         ; physical drive 0.0 goes forwards
          M569 P0.1 S1 D3                         ; physical drive 0.1 goes forwards
          M569 P0.2 S0 D3                         ; physical drive 0.2 goes forwards
          M569 P0.3 S0 D3                         ; physical drive 0.3 goes forwards
          M569 P0.4 S0 D3                         ; physical drive 0.4 goes forwards
          M569 P20.0 S0 D3                        ; physical drive 0.5 goes forwards
          M584 X0.0 Y0.1 Z0.2:0.3:0.4 E20.0.0     ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z400.00               ; set steps per mm
          M906 X1000 Y1000 Z800 I30               ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                 ; Set idle timeout
          M566 X400.00 Y400.00 Z6.00 E120.00 P1          ; set maximum instantaneous speed changes (mm/min)
          M203 X10800.00 Y10800.00 Z1000.00 E3600.00     ; set maximum speeds (mm/min)
          M201 X3000.00 Y3000.00 Z100.00 E3600.00        ; set accelerations (mm/s^2)
          ;;;;;;;;;; Axis Limits ;;;;;;;;;;
          M208 X0 Y0 Z0 S1                               ; set axis minima
          M208 X310 Y300 Z290 S0                         ; set axis maxima
          ;;;;;;;;;; Endstops ;;;;;;;;;;
          M574 X1 S1 P"io1.in"                           ; configure active high endstops
          M574 Y2 S1 P"io0.in"                           ; configure active high endstops
          M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
          M671 X-4.5:150:304.5 Y-4.52:305:-4.52 S5       ; define positions of Z leadscrews or bed levelling screws
          M557 X20:280 Y20:280 P5                        ; define 5x5 mesh grid
          ;;;;;;;;;; Heaters ;;;;;;;;;;
          M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed"    ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out0" T0                                     ; create bed heater output on out0 and map it to sensor 0
          M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                                ; map heated bed to heater 0
          M143 H0 S110                                           ; set temperature limit for heater 0 to 110C
          M307 H0 B0 R0.855 C274.9 D3.97 S1.00				   ; PID parameter
          M308 S1 P"20.temp0" Y"PT1000" A"Hotend"
          M950 H1 C"20.out0" T1       ; create nozzle heater output on out0 and map it to sensor 1
          M307 H1 B0 S1.00            ; disable bang-bang mode for heater and set PWM limit
          M143 H1 S250                ; set the maximum temperature in C for heater
          M307 H1 B0 R2.320 C237.4 D5.37 S1.00 V24.1
          ;;;;;;;;;; Fans ;;;;;;;;;;
          M950 F0 C"20.out2+out2.tach" Q5000	; create fan 0 on pin out3 and set its frequency
          M106 P0 C"Hotend Fan" S0 H1 T45		; set fan 0 name and value. Thermostatic control turned on for Hotend
          M950 F1 C"20.out1" Q5000			; create fan 1 on pin out4 and set its frequency
          M106 P1 C"Layer Fan" S0 H-1			; set fan 1 name and value. Thermostatic control is turned off
          ;;;;;;;;;; Tools ;;;;;;;;;;
          M563 P0 D0 H1 F1           ; define tool 0
          G10 P0 X0 Y0 Z0            ; set tool 0 axis offsets
          G10 P0 R0 S0               ; set initial tool 0 active and standby temperatures to 0C
          ;;;;;;;;;; EVA 2 / BMG / Mosquitto ;;;;;;;;;;
          M92 E830          ; set extruder steps per mm, 0.9 angle/step (LDO Pancake)
          M906 E800         ; set extruder motor current (mA) and idle factor in per cent
          ;;;;;;;;;; BLTouch ;;;;;;;;;;
          M950 S0 C"20.io0.out"                     ; Create a servo pin on io0 (toolboard 1LC)
          M558 P9 C"20.io0.in" H5 F240 T10800 A5    ; set Z probe type to unmodulated and the dive height + speeds
          G31 P25 X-28.00 Y-13.00 Z3.700          	  ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
          ;;;;;;;;;; Acclerometer ;;;;;;;;;;
          ;M955 P20.0 I10 ; specify orientation of accelerometer on Toolboard 1LC with CAN address 121
          ;;;;;;;;;; Pressure Advance ;;;;;;;;;;
          M572 D0 S0.10
          homeall.g
          	M280 P0 S160        	; Precautionary alarm release (BLTouch)
          	M280 P0 S90        		; Ensure the pin is raised (BLTouch)
          	G91						; relative positioning
          ;	G1 H2 Z5 F6000			; lift Z relative to current position (bed goes down)
          	G1 H1 X-999 Y999 F1800	; move quickly to X axis endstop and stop there (first pass)
          	G1 H1 X-999 F1800		; move quickly to X axis endstop and stop there (first pass)
          	G1 H1 Y999 F1800		; move quickly to Y axis endstop and stop there (first pass)
          	G1 H0 X5 Y-5 F6000		; go back a few mm
          	G1 H1 X-999 Y999 F100	; move quickly to X axis endstop and stop there (first pass)
          	G1 H1 X-999 F100		; move quickly to X axis endstop and stop there (first pass)
          	G1 H1 Y999 F100			; move quickly to Y axis endstop and stop there (first pass)
          	G90               		; absolute positioning
          	G1 X150 Y150 F10000		; go to first probe point
          	G30               		; home Z by probing the bed
          	G1 Z5 F1000       		; lift Z relative to current position  (bed goes down)
          deployprobe.g
          ; deployprobe.g
          ; Called to deploy a physical Z probe
          M280 P0 S10															; Deploy the BLTouch pin
          retractprobe.g
          ; retractprobe.g
          ; Called to retract a physical Z probe
          M280 P0 S90													; Retract the BLTouch pin
          fcwiltundefined infiniteloopundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @Arisoy
            In your homeall.g you have this:
            G1 H2 Z5 F6000
            Change the Z5 to Z10 and report back the behavior with this new setting.
              For one, you can increment the dive height. Another thing to do is to add a move to bed.g, ahead of the probing with G30. Something like
              G1 X5 Y10 Z20 F2000
              This would go to the first point to probe and lower the bed 20 mm from 0, regardless what initial Z-height you start with.
              Arisoyundefined 1 Reply Last reply Reply Quote 1
              • Arisoyundefined
                @infiniteloop Adding the line "G1 X5 Y10 Z20 F2000" before the G30 in the bed.g make my bed going down first. Then it goes up fast at the same time of the carriage moves in x/y to the first point.
                So nothing really changed except i have a new mouvement before the problem occured.
                @infiniteloop said in Why first move of tue bed leveling is going up?:
                I don't know how to do that. Can you tell me please.
                @fcwilt said in Why first move of tue bed leveling is going up?:
                G1 H2 Z5 F6000
                With the bed is going more down when i home the z. But nothing changed with true bed leveling.
                • fcwiltundefined
                  fcwilt @Arisoy
                  You can put back the Z5.
                  Now change the H2 parameter in the M558 command to H5. You will have to re-boot to get the config.g to be loaded again.
                  Let us know the behavior with this change.
                  • Arisoyundefined
                    Arisoy @fcwilt
                    Now change the H2 parameter in the G31 command to H5.
                    I don't find where is this command with H2.
                    It's here?
                    But there is no H2 parameter in the G31 command.
                    fcwiltundefined PCRundefined 2 Replies Last reply Reply Quote -1
                    • fcwiltundefined
                      fcwilt @Arisoy
                      It's here?
                      Sorry my bad. It is in the M558. Trusted to my memory - I shouldn't do that.
                      • PCRundefined
                        PCR @Arisoy
                        @arisoy what's your Z M566?
                        • Arisoyundefined
                          Arisoy @fcwilt
                          @fcwilt The paramater was already H5 so I tried H2 But no change. I set it back to H5.
                          • fcwiltundefined
                            fcwilt @Arisoy
                            Let's try the suggestion posted previously.
                            Add G90 G1 X155 Y150 Z10 before the set of three G30 commands in your bed.g file and report the behavior.
                            • Arisoyundefined
                              Arisoy @fcwilt
                              @fcwilt I already did it. And after this positioning command "G90 G1 X155 Y150 Z10" the bed did a fast move up while the bltouch is going to the first probe point then wait for the probe to be in the good place and finally did the probing work.
                                infiniteloop
                                Look at my first post in this thread.
                                • fcwiltundefined
                                  fcwilt @Arisoy
                                  Please change the Z10 to Z20 and see how that affects the behavior.
                                  It may help to post a video of what you are seeing to be sure we all understand what is happening.
                                  • Arisoyundefined
                                    Arisoy @fcwilt
                                    @fcwilt Ok so i homed all axis and then i take a video from what happened.
                                    I started the video and just after i send the G32 command.
                                    As you can see at first the bed moves up. I don't want that at all. I want the probe to go at his place first and then the bed can moves up.
                                    link text
                                    infiniteloopundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                      @arisoy Split the G1 movement in two:
                                      1. Move X/Y to whatever point you want
                                      2. Lower Z to 10 or 20 mm
                                      Possibly you can omit Z completely - at the moment, I can't verify that …
                                      • fcwiltundefined
                                        fcwilt @Arisoy
                                        link text
                                        I went and watched my printer and it does what yours is doing. That initial Z movement prior to the first probe has never caused me any issues.
                                        You could adjust the initial G1 to move to the first probe XY point.
                                        • Arisoyundefined
                                          @infiniteloop I did it. I split the G1 in two. The G1 command works fine.
                                          But after that the G30 command moves the bed up again and fast close to the probe. And then the probing starts.
                                          So if the bed is not leveled the bed will crash to the probe during this first fast move.
                                          I don't want to add some mouvement before the bed moves up fast. I want it to not do that. It should probe directly not move up first.
                                          Like it's done when you home your printer. When homing the Z i can start it from the bottom and the bed will slowly search the probe. It wil not move fast and then start to probe.
                                          • fcwiltundefined
                                            fcwilt @Arisoy
                                            A Z probe can have this issue with a bed setup like yours (and mine).
                                            I dealt with it by having a Z endstop switch for each Z axis.
                                            See this video which starts with the bed way out of level. It homes and "levels" using the Z endstops. At the point it is level enough that the Z probe can always do the final leveling without issue.
                                            Bed Leveling
                                            You might try adjusting the H5 parameter to H10 or H15 to see how that affects the behavior.
