    Driver install for USB
    4.8k
    • Wild Bill Diamondundefined
      Wild Bill Diamond
      I have a new wifi board coming to day and when I try to install the driver . When I double click the duet inf file all I get is the security catalog. any ideas whats going on
        I assume you have downloaded the driver zip file and unzipped both the .inf and the .cat file into the same folder. Right-click on duet.inf and select Install.
          Wild Bill Diamond
          got the new board in and everything is good until I send m552 s1 and this is the message I get wifi reported error no known networks found wifi module is idle. where to from here Thank you
            See https://duet3d.com/wiki/Getting_connected_to_the_Duet_WiFi#Connecting_to_your_access_point_using_firmware_1.19_or_later.
              Wild Bill Diamond
              Tried to install YAT and it wants the port that the wifi usb driver is using any way to work around that. I'm in the process of getting another computer to work then I'll try to put YAT on it. Do you have any other ideas. Thanks
                That is the correct port to use. What exactly is the problem?
                  Wild Bill Diamond
                  I was able to get the printer to connect and now it doesn't I have error 5 any ideas
                    Wild Bill Diamond
                    Do you know anyone in the Las Vegas Nevada area that is good with your duet electronics
                      Sounds like the port is being used by another program. Do you have Pronterface or Repetier or another program connected to that port?
                      If all else fails, reboot Windows.
                        Wild Bill Diamond
                        ok here is what I did. I rebooted with the printer unhooked and no printer shows up under device manager then I plug in printer and the port shows up and the name is DuetWifi or Duet Ethernet 3d printer control electronics (com6) is this the right driver
                          Wild Bill Diamond
                          printer still comes up with error 5
                            Which program is giving error 5? Or is it the printer giving error 5 when you send it a command?
                              Wild Bill Diamond
                              I'm using Ponterface and it does it when I try to connect. When I first put in the new board it connect with no trouble, but then the issue was when I sent the M552 S1 command it couldn't find a local network and wifi was idle
                                I'm fairly sure that Error 5 in Pronterface means that some other program has attached to that serial port already.
                                  Wild Bill Diamond
                                  I agree a 100% with you. I just uninstalled the driver and reinstalled it. But I get the same error code. Is there an earlier driver version I could try. I have no idea what version of firmware I have on the printer
                                    It's not a problem with the driver, it's something else on your PC grabbing the port. This http://digital.ni.com/public.nsf/allkb/29B079481C5ECE76862578810082394E may help you work out what.
                                      Wild Bill Diamond
                                      Looking thru all the ports it shows com 6 blank and that's the one its connected to. I just want to use the duetwifi not become a computer expert. Any way to move to a different port. Thank you
                                        If you connect it to a different USB port on your computer, then the COM port number will change.
                                          Wild Bill Diamond
                                          Thank you. Printer now online. Standby for the next problem. LOL
                                            Wild Bill Diamond
                                            Ok next problem wifi reported no known networks found
