script on layer change
Firmware wishlist
    too
    Hello Guys,
    I want to have the duet execute a script on every new layer without having to add that in the slicer, similar to the "start.g" or "end.g" files.
    Is there any tricks to do that already?
    I guess as long as there are some kind of layer indicators in the gcode that could be doable?
    Cartesian Duet3+Raspberry pi 4 with 5x 1XD using servo drives printing mortars and concrete
    undefined 1 Reply Last reply 31 Jan 2022, 16:53 Reply Quote 0
      CNCModeller @too
      @too you could put M98 P"LayerChange.g" in your slicer layer change settings, and create a LayerChange.g macro to define the behaviour locally.
      At least that would mean you could change that behaviour globally without having to re-slice your code.
      Polar Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      K40 Laser, Duet2
      https://forum.duet3d.com/post/312082
      Wanhao D5S
      https://www.youtube.com/CNCModellerUK
      undefined 1 Reply Last reply 31 Jan 2022, 20:21 Reply Quote 3
        too @CNCModeller
        @cncmodeller That's a good tip, I have actually resorted to something similar!
        I created a "M2001.g" file in the sys folder and added a M2001 command on each layer change...
        The issue is that I am using a custom slicer that I can't easily change myself and that doesn't have this capability (that at least adds ";LAYER: ##" markers at the beginning of a new layer). I was hoping to not have to manually change the gcode file, but thank god for the "change all occurrences" function in VSCode 🙂
        2 out of 3
