    Duet Telegram bot
    14
    3.3k
    • sbcrumbundefined
      sbcrumb @IdefixRC
      @IdefixRC
      Not sure if you every got this fixed, but I noticed I would only get this message when nothing was printing. IE Idle state has no status but printing messages came through.
      • phcellaundefined
        phcella
        I installed and it worked but not all commands.
        /status - not working
        /macros - not working
        • ErwinH78undefined
          ErwinH78
          its not working with my duet 3. are there updates available or something like that?
            A Former User
            Hi, I'm installing the whole....just a question: do the bot starts automatically with the Pi or should I do something to make it autosart?
            Thanks
            toufou54undefined 1 Reply Last reply Reply Quote 0
            • toufou54undefined
              toufou54
              Excellent job ! Thanks
              • tristanryerparkeundefined
                tristanryerparke
                Duet 3 and sbc running duetbot on the sbc.
                Getting error:
                Connecting to duet...
                Duet is offline!
                Checking for upload dir...
                Uploads disabled: Request to http://tristan-painting-machine.local/rr_filelist?dir=0%3A%2Fgcodes%2Ftelegram failed. code: 404
                Bot started...
                Also tried with the same numerical ip address that works to connect to dwc.
                Any advice?
                • toufou54undefined
                  toufou54 @A Former User
                  @the_dragonlord I don't remember if I did the file or get on the web but you have to make duetbot as a service with a file "duetbot.service" or whatever into /etc/systemd/system as root
                  File content (edited):
                  [Unit]
                  Description=node js duetbot for telegram
                  #after network is up
                  After=network.target
                  [Service]
                  WorkingDirectory=/usr/bin
                  ExecStart=duetbot
                  Restart=on-failure
                  RestartSec=1500ms
                  Type=forking
                  #user pi or root, will determine where the script will search the configuration file **.duetbot.json**
                  User=pi
                  # Note Debian/Ubuntu uses 'nogroup', RHEL/Fedora uses 'nobody'
                  Group=nogroup
                  Environment=PATH=/usr/bin:/usr/local/bin
                  Environment=NODE_ENV=production
                  # log send to syslog
                  StandardOutput=syslog
                  StandardError=syslog
                  # syslog name id
                  SyslogIdentifier=duetbot
                  [Install]
                  WantedBy=multi-user.target
                  And don't forget to execute after that :
                  #to load the file for the systemctl manager
                  systemctl daemon-reload
                  # to start and test
                  service duetbot start
                  # to check if loaded an active
                  service duetbot status
                  # if all is good you can tell the system to execute it as a service on boot :
                  systemctl enable duetbot
                  #if it's ok the system will respond :
                  Created symlink /etc/systemd/system/multi-user.target.wants/duetbot.service → /etc/systemd/system/duetbot.service.
                  • bothamichaelundefined
                    bothamichael
                    I am getting this error trying to install duet- telegram on my duet 3 with sbc (RPi 3b+).
                    Please can anyone assist
                    • Nicxorundefined
                      Nicxor
                      This post is deleted!
                      • bastienundefined
                        bastien
                        the last update of the bot on github is more than 3 years old,
                        the project was abandoned
