    issues in RRF build
    Firmware developers
    497
    • user M_123undefined
      user M_123 @user M_123
      • JoergS5undefined
        JoergS5 @user M_123
        @user-m_123 it must be also in the path. And the version is newer than the version 8 2018 q4 which I'm using. I don't know whether 10 2020 q4 is compatible.
        user M_123undefined 1 Reply Last reply Reply Quote 0
          user M_123 @JoergS5
          @joergs5 yes it is
            • JoergS5undefined
              JoergS5 @user M_123
              @user-m_123 did you check calling the program from commandline?
              eg
              C:\Users\Joerg>arm-none-eabi-g++ --version
              arm-none-eabi-g++ (GNU Tools for Arm Embedded Processors 8-2018-q4-major) 8.2.1 20181213 (release) [gcc-8-branch revision 267074]
              Copyright (C) 2018 Free Software Foundation, Inc.
              This is free software; see the source for copying conditions. There is NO
              warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
              C:\Users\Joerg>make --version
              GNU Make 4.1
              Built for x86_64-w64-mingw32
              Copyright (C) 1988-2014 Free Software Foundation, Inc.
              License GPLv3+: GNU GPL version 3 or later http://gnu.org/licenses/gpl.html
              This is free software: you are free to change and redistribute it.
              There is NO WARRANTY, to the extent permitted by law.
                dc42 administrators @user M_123
                @user-m_123 are you building under Windows or under Linux?
                  user M_123 @dc42
                  @dc42 Windows
                    user M_123 @JoergS5
                    @joergs5 Thanks for your support it is build perfectly
                    JoergS5undefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • JoergS5undefined
                      JoergS5 @user M_123
                      @user-m_123 that's fine, don't hesitate to ask when there is a new question.
                        @user-m_123 from https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware:
                        The build depends on the Eclipse workspace variable ArmGccPath being set to the directory where your arm-none-eabi-g++ compiler resides. For example C:\Program Files (x86)\GNU Tools ARM Embedded\7 2018-q2-update\bin on Windows (see step #1 for which compiler to use). To set it, go to Windows -> Preferences -> C/C++ -> Build -> Build Variables and click "Add..."
                        It sounds to me that you didn't do that step. The Eclipse project is set up so that Eclipse uses that variable to find the compiler.
                        • Phaedruxundefined Phaedrux moved this topic from Firmware installation
