    Before updating to 1.19….
    Firmware installation
    • claustroundefined
      claustro
      excuse me for my dumb question but the correct sintax for the m587 comand is with quotes or not?
      M587 S"myssd" P"mypassword" I"192.168.0.104"
      or
      M587 Smyssd Pmypassword I192.168.0.104
      thx
      Andrea
      • Dougal1957undefined
        Dougal1957
        If a password or SSID includes space or semicolon characters then it must be enclosed in double quotation marks. For security, do not use this command in the config.g file, or if you do then remove it after running it once so that the network password is not visible in the file.
        From the GCODE Wiki
        • claustroundefined
          claustro
          Thank you very much !
            The password and SSID in the M587 command must always be enclosed in double quotes. The IP address and other parameters must not be.
            • claustroundefined
              claustro
              ok .
              thank you very much.
              A.
