Driver install for USB
4.8k
    Wild Bill Diamond
    Looking thru all the ports it shows com 6 blank and that's the one its connected to. I just want to use the duetwifi not become a computer expert. Any way to move to a different port. Thank you
      If you connect it to a different USB port on your computer, then the COM port number will change.
        Wild Bill Diamond
        Thank you. Printer now online. Standby for the next problem. LOL
          Wild Bill Diamond
          Ok next problem wifi reported no known networks found
            See https://duet3d.com/wiki/Getting_connected_to_the_Duet_WiFi#Connecting_to_your_access_point_using_firmware_1.19_or_later.
              Wild Bill Diamond
              When I installed my first board I sailed right thru all this and now its being a real pain in the butt, with this board any ideas. Thank you
                Which bit are you stuck on?
                  Wild Bill Diamond
                  Sending M552 S1 and this is the message I get wifi reported error no known networks found, wifi module is idle. With the first board I had no trouble with this at all
                    Dougal1957
                    Have you loaded up your WiFi access point details with the M587 command as DC linked to above?
                    M587 S"your-network-ssid" P"your-network-password" remember this is case sensitive so will need to be put in using a text editor or dumb terminal such as yat or possibly even hyperterminal will do it or put the command into a macro but I suspet you will need to use a terminal program as you wont be able to load a macro unless you move the SD Card to the PC
                      Wild Bill Diamond
                      When I send 587 S I get bad parameter in 587 command. When I did all this with my first board everything worked like it was suppose. I know right now I have 1.19.1 driver. I have no idea what firmware came with the board, but something is not right. I am able to take the sd card out and put in my computer. I am getting really close to going back to my ramps board a 3 color diamond
                        What is the exact M587 command you are running that it is telling you has a bad parameter? You can obfuscate the password when replying.
                          Wild Bill Diamond
                          M587 or M587p remembered networks TNCAP2FCC19 or M587S bad paramter in M587S
                          26 out of 28
