    M915 won´t accept R2 or R3
    Beta Firmware
    657
    • vali3dundefined
      vali3d @jay_s_uk
      @jay_s_uk I should be able to set both modes, when testet it does not detect the crash at R2/3.
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @vali3d
        @vali3d are you getting any stalls at all?
        Are you explicitly setting the drivers as stealthchop? i.e. D3 in M569?
        vali3dundefined 2 Replies Last reply Reply Quote 0
        • vali3dundefined
          vali3d @jay_s_uk
          @jay_s_uk when I set a R1 it log them in the console
            dc42 administrators @vali3d
            @vali3d did you create the /sys/driver-stall.g file with appropriate contents to do what you want when a stall is detected?
            vali3dundefined 1 Reply Last reply Reply Quote 0
            • vali3dundefined
              vali3d @dc42
              @dc42 I now created that file with some contents. Sadly that did not solve the Problem.
              • vali3dundefined
                vali3d @jay_s_uk
                @jay_s_uk The M569 looks like this:
                M569 P0.0 S0
                M569 P0.1 S1
                M569 P0.2 S0
                M569 P0.3 S1
                M569 P0.4 S1
                M569 P0.5 S1
                M569 P2.0 S1
                M569 P2.1 S1
                M569 P1.2 S1
                M569 P2.2 S1
                M584 V0.3 W0.4 X0.5 Y0.1 Z0.0 A0.2 R0 S0 E1.2:2.0:2.1:2.2
                  jay_s_uk @vali3d
                  @vali3d what board are you using?
                  • vali3dundefined
                    vali3d @jay_s_uk
                    @jay_s_uk MB6HC+2x EXP3HC (see https://forum.duet3d.com/topic/18329/duet-3-expansion-looses-connection)
                      @vali3d is it the drivers on the MB6HC that are not invoking the driver-stall.g file, or the ones on the 3HCs?
                      • vali3dundefined
                        vali3d @dc42
                        @dc42 all relevant drivers are on the MB6HC
                        • vali3dundefined
                          vali3d
                          I don´t think that there is a Problem with the file. The Problem is that the R3 cant be set. When I do M915 X S3 R3 and then M915 the configuration of the axis is on the default settig.
                            @vali3d I confirm this is a bug. I will fix it in the next RC, and I will probably make a test version available before then.
