Macro Can't open 0:/sys/0 to read, error code 1 ( Solved)
I put a file named SetNetworks
in /macros
the file contains
[c]M552 S0
G4 P1000
M587 S"CasaBisi" P"binbin1973" I192.168.0.104 [/c]
I execute throug repetierM98 P/macros/SetNetwork
and the answer is23:04:18.698 : Can't open 0:/sys/0 to read, error code 1
23:04:18.698 : Macro file 0 not found.
23:04:18.698 : okNow I am stuck
I tried calling other macros without succes but M503 works.
Tested other sd card with same results.My folder structure is
gocdes
macros โhereI placed SetNetwork
sys
wwwAny idea what I am missing?
Perhaps Repetier is failing to send the M98 command exactly as you sent it. Try using another program, such as Pronterface or a terminal emulator.
Thank you , you answered at the same time I am going to post the solution
You are right repetier can't handle M98 correctly , solved using simplify3d console.
Lightning answer anywaythank you
Connected but I am receiving this error, what this mean?
Can't open 0:/sys/oem.json to read, error code 4
Also I am on 1.19.2 running on Duet WiFi 1.0
My corexy axis is screwed my last functionally config was
[c]M569 P0 S1 ; Drive 0 goes forwards (change to S0 to reverse it)
M569 P1 S0 ; Drive 1 goes forwards. (Change if motor goes wrong way. Or just turn the motor connection 180 degrees around..)
M569 P2 S0 ; Drive 2 goes forwards
M569 P3 S0 ; Drive 3 goes forwards
M574 X1 Y2 Z0 S0 ; set endstop configuration (X1 is at MIN end. Y2 is at MAX end. (active high switch = S1, active low switch= S0)
M667 S1 ; set CoreXY mode[/c]can you suggest me how can change it?
Read the notes. Have to swap connectors.
thank you , I read it , but I prefer to change the config setting instead of swapping connector ,and I didn't remember the drive order , then I found that Y is number 1
so
M569 P1 S1 fix the problem.thank you for answering me.
Andrea
