Duet 2 Ethernet WC 3.3.0 crashes, have to reset to reconnect
Duet Web Control
4.7k
    trobison @airscapes
    @airscapes I had my first board replaced. Unfortunately, this board is doing the same. "Connection lost, attempting to reconnect." I purchased a screen as I could not rely on the ethernet connection on the Duet 2. My machine is on, not printing, and I can see that I require a reboot to fix the behaviour. I was looking at the config.g file to determine what I might have to do if I upgrade to version 3.4.0. I have tried three different switches, several cables, and I get the same errors. This isn't what I expected. On long prints, the screen has been the only way to interact with the Duet 2. Once the network goes funky, cycling the power appears to be the only way to restore communication.
    undefined 1 Reply Last reply 11 Feb 2022, 13:43 Reply Quote 0
      airscapes @trobison
      @trobison said in Duet 2 Ethernet WC 3.3.0 crashes, have to reset to reconnect:
      @trobison Have you tired to connect to the USB port with a terminal program, send M552 S0 to disable network, then send 552 S1 Pxx.xx.xx.xx to enable network and set your IP? This worked for me yesterday after the connection dropped. The network came back, never hit reset and worked the rest of the day. I would also like to know what the serial number is on your board? There is a sticker on the box in came in and one on the CPU on the board. If you already exchanged it I would assume you know that. Seems like something crashes in the network module if my workaround continues to enable the connection after failure? I am lucky, as I was using octoprint with the printers for years before this "Upgrade" . I must say, I have grown to like the DWC interface as much if not more than octoprint for what I do. Please send your issue to your reseller if you have not already done so and ask them to forward your issue to Ronald@duet3d.com as he is the person Matterhackers forwarded mine to.
      Would be good from them to know there are multiple customers with the same issue if they don't already know about it.
      Thanks for posting and validating this is a real problem unrelated to external network issues.
        We are trying to work out a way to get you a replacement ethernet module to test with. Thanks for your patience.
        @trobison Do you have a thread of your own discussing your issue already?
        undefined 1 Reply Last reply 12 Feb 2022, 21:03 Reply Quote 0
          airscapes @Phaedrux
          @phaedrux No worries, this is really a weird one. My first board is on it's way back to Matter Hackers, should be there by now so not sure how long it will take to get back to manufacture location. That one failed much more often than this one.
          I have been printing ABS parts for the past 2 days with as much as a blip.. Wish I knew what triggered it, but glad I have a work around that does not involve resetting the board since the print job is not interrupted in any way.
            trobison
            No, I did not create a thread. I tried connecting via USB and resetting the network. I still have the same issues with network drop outs. The chip has a sticker of DUET2 Main W06367. This morning I powered on the printer and attempted to print. I have issues loading files to the printer, the network drops out. Nic lights are correct, but the connection drops randomly. It faults more while printing.
            13/02/2022, 09:36:19	Failed to upload Desk_Stand.gcode
            Could not complete action because the connection has been terminated
            13/02/2022, 09:36:19	Connection interrupted, attempting to reconnect...
            Network error
            13/02/2022, 09:35:57	Successfully deleted TESTPRINT.gcode
            13/02/2022, 09:31:02	Finished printing file 0:/gcodes/TESTPRINT.gcode, print time was 0h 48m
            13/02/2022, 09:31:00	Connection established
            13/02/2022, 09:31:00	Connection interrupted, attempting to reconnect...
            Operation failed (Reason: Service Unavailable)
            13/02/2022, 09:10:37	Connection established
            13/02/2022, 09:10:36	Failed to upload Print-In-Place Phone holder.gcode
            13/02/2022, 09:10:36	Connection interrupted, attempting to reconnect...
            Network error
            13/02/2022, 09:08:25	Successfully deleted 2 items
            13/02/2022, 08:40:55	Cancelled printing file 0:/gcodes/TESTPRINT.gcode, print time was 0h 5m
            13/02/2022, 08:40:46	Resume state saved
            Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
            13/02/2022, 08:39:01	Connection established
            13/02/2022, 08:39:00	Connection interrupted, attempting to reconnect...
            13/02/2022, 08:37:36	Connection established
            13/02/2022, 08:37:36	Connection interrupted, attempting to reconnect...
            13/02/2022, 08:35:33	M32 "0:/gcodes/TESTPRINT.gcode"
            File 0:/gcodes/TESTPRINT.gcode selected for printing
            13/02/2022, 08:35:25	Upload of TESTPRINT.gcode successful after 5s
            13/02/2022, 08:35:02	Connected to 192.168.10.60
            13/02/2022, 09:54:06	m122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet Ethernet 1.02 or later + DueX5
            Board ID: 0JD0M-9P6M2-NWNS0-7J9DJ-3SJ6S-K90RJ
            Used output buffers: 12 of 24 (24 max)
            Static ram: 23876
            Dynamic ram: 73712 of which 0 recycled
            Never used RAM 13972, free system stack 98 words
            Tasks: NETWORK(ready,29.2%,231) HEAT(delaying,0.1%,330) Move(notifyWait,0.2%,307) DUEX(notifyWait,0.0%,24) MAIN(running,70.4%,441) IDLE(ready,0.1%,29), total 100.0%
            Owned mutexes:
            Last reset 00:12:46 ago, cause: power up
            Last software reset at 2022-02-12 17:20, reason: User, GCodes spinning, available RAM 16828, slot 2
            Error status: 0x0c
            Aux0 errors 0,1,0
            Step timer max interval 0
            MCU temperature: min 34.1, current 37.9, max 38.0
            Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/86/0, gc cycles 0
            Driver 0: position 15650, ok, SG min/max 0/1023
            Driver 1: position 754, ok, SG min/max 0/1023
            Driver 2: position 4627, ok, SG min/max 0/1023
            Driver 3: position 3641, standstill, SG min/max not available
            Driver 4: position 0, ok, SG min/max 0/1023
            Driver 5: position 0, standstill, SG min/max not available
            Driver 6: position 0, standstill, SG min/max not available
            Driver 7: position 0, standstill, SG min/max 0/56
            Driver 8: position 0, standstill, SG min/max not available
            Driver 9: position 0, standstill, SG min/max not available
            Driver 10: position 0
            Driver 11: position 0
            Date/time: 2022-02-13 09:54:06
            Slowest loop: 175.42ms; fastest: 0.14ms
            === Storage ===
            Free file entries: 9
            SD card longest read time 1.2ms, write time 50.3ms, max retries 0
            DMs created 83, maxWait 291747ms, bed compensation in use: mesh, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 2259, completed moves 2229, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state 3
            === AuxDDARing ===
            Heater 0 is on, I-accum = 0.2
            Heater 2 is on, I-accum = 0.5
            Segments left: 1
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is doing "G1 X81.698 Y83.929 E304.1846" in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === DueX ===
            Read count 1, 0.08 reads/min
            === Network ===
            Slowest loop: 202.93ms; fastest: 0.02ms
            HTTP sessions: 2 of 8
            Interface state active, link 100Mbps full duplex
            undefined 1 Reply Last reply 13 Feb 2022, 00:50 Reply Quote 0
              Phaedrux Moderator @trobison
              @trobison Just to ensure we've covered all the bases, do you have another SD card to test with?
              undefined 1 Reply Last reply 13 Feb 2022, 02:08 Reply Quote 0
                trobison @Phaedrux
                @phaedrux This is a replacement card. I went through the online configurator to get the most recent stable version. Do you require another SD card? If so, can I image the existing card? There are a lot of files for the tool-changer.
                After a reboot, I was able to upload some jobs straight away. I used the screen to submit the jobs without issue. The network issues are random. Somethings worse, other times it's good.
                undefined 1 Reply Last reply 13 Feb 2022, 03:03 Reply Quote 0
                  @trobison Switching to a new SD card is simple matter of copying all the folders and files across. Provided the old card still works.
                  undefined 2 Replies Last reply 16 Feb 2022, 00:46 Reply Quote 0
                    trobison @Phaedrux
                    @phaedrux I prepared a new SD Card (SanDisk Extreme). I copied all files to the new card, and the Duet booted. I left the machine on for 6 hours, and recorded only one disconnect. Then a test print was sent to the printer, which
                    completed without error. The machine was powered off after that. The following day, I turned on the printer, No SD Card found. I took the card out and reinserted it. Same response. I put the card into a card reader and I could see all contents. I replaced the card with the SD card I had earlier (this is a replacement card as well). I still get network drop outs. Network cables have been changed, and the switch has been changed. Having the DuePanel has proved useful for this issue.
                      @trobison Do any of the chips on the ethernet module get extremely hot to the touch?
                        trobison @Phaedrux
                        @phaedrux I have a little more diagnostic info. During the last print I tried to make changes to my toolchanging routines. The network drop outs prevented this during printing. After the print I could make some changes but still having random drop outs. I open up a new Enterprise HP Switch as a test. There are only two ports in use on this 24 port switch. While working on tpre0.g the network dropped and cleared all contents in the file. This has happened 6 times today; changing the switch and network cables have not had an effect. Cycling the DUET is the only way to return comms. Thank goodness I have a DuePanel to see what is going on. It is becoming challenging to use my ToolChanger.
                        rjenkinsgbundefined 1 Reply Last reply 7 Mar 2022, 06:44 Reply Quote 0
                          trobison
                          I photographed the network chip with my thermo camera - it reports 53 degrees. The network has failed minutes into a print. I can't see the webpage. "Connection lost" I swapped switches back, and it is not available on this switch as well. I can see the printing status on the DuePanel. There are pauses in the print to insert nuts, but I can't locate layer lines on the panel. Hopefully it pops up a message on the screen of the duet.
                          undefined 1 Reply Last reply 16 Feb 2022, 13:44 Reply Quote 0
                            airscapes @trobison
                            @Phaedrux I have been printing items every day this week and have yet to experience a third connection drop with the new board. I am fairly sure the issue has not magically resolved but nothing new to report at this time. Have not heard back from anyone on the Warranty department as of yet. Hopefully once the first board gets back it can be analyzed.
                              @airscapes @trobison Can you both send an email to warranty@duet3d.com with your name and address? We will send out a replacement ethernet module.
                              undefined 1 Reply Last reply 16 Feb 2022, 20:45 Reply Quote 0
                                airscapes @Phaedrux
                                @phaedrux Sure is it replaceable without soldering or will the board need to be removed to R&R the module? Truthfully never looked that close to see how it was installed.
                                Hum... looks to just plug into headers.. maybe should have done and R&R on the first board that was acting up constantly.. @trobinson, have you done this on your board? Just removed it and reinstalled it to see if there was any change?
                                  Yes it's a small module that can be removed.
                                  Perhaps as part of the exploration could you grab some close up shots of it? Perhaps there is a solder point that is suspect.
                                  undefined 1 Reply Last reply 16 Feb 2022, 21:49 Reply Quote 0
                                    airscapes @Phaedrux
                                    @phaedrux Sure, once it shows up I will pull the board from the machine and see what I can see. I was just looking at the image of it in the getting started guide and saw it was plugged into headers so 2 solder joints for every connection.
                                    Just wish mine would act up on a regular basis.. Trobinson seems to be having issues constantly. I will email MatterHackers and see if my original has made it back home.
                                    undefined 1 Reply Last reply 17 Feb 2022, 16:07 Reply Quote 0
                                      airscapes @airscapes
                                      @Phaedrux Duet has mailed the module .. will travel across the pond so I guess it will take a while to arrive..
                                      undefined 1 Reply Last reply 26 Feb 2022, 04:15 Reply Quote 0
                                        Module arrived today, will try and replace this weekend. I have had a total of 3 network failures since replacing the the board so not real often..
                                        undefined 1 Reply Last reply 5 Mar 2022, 18:36 Reply Quote 0
                                          @Phaedrux I have installed the new Network Module. This second board has only failed 3 times that I know of making it very hard to diagnose. I did take photos of the solder joints of the header to board on both the old and new module as well as the top and bottom of the main board. I also looked a the surface mounted components on the module .. none of the joints look like they were cold or had large amounts of inclusions.. The photos are here.
                                          Photos of Solder joints magnified
                                          Now the waiting ..
                                          undefined 1 Reply Last reply 6 Mar 2022, 01:44 Reply Quote 1
