PrusSlicer never finishes upload with PI4
Using Duet Controllers
1.7k
    Stephen6309
    On my Duet 3 6HC+1LC+PI4 3.4.0rc1, same with proir versions, PrusaSlicer never finishes the upload using any of the upload options. The file does fully upload, but the process in the slicer never finishes. So, I have to cancel the upload to do anything else. PrusaSlicer versions: 3.4.0, and 3.4.1beta1, and SuperSlicer 2.4.58.0. PI4 powered by a Meanwell power supply.
    In standalone mode, it works fine.
    Deleting the printer and adding it again doesn't fix it. It been occuring for a while now. The test button finds the printer just fine.
    Must be something on my pc, since I don't find on their github any issues reported for this. It really hasn't bothered me much, since it kinda worked.
    undefined 1 Reply Last reply 15 Feb 2022, 23:17 Reply Quote 0
      PetrKroupa
      @stephen6309 - Same in my setup. Two printers. 6HC+1LC + SBC pi4.
      BigOne:Duet3 6HC +1LC + Rpi5 +SSD, mosquito hotend, 400x400x420
      SmallOne : Duet3 6HC +1LC + Rpi5 +SSD, mosquito hotend, 210x250x210
      Petr
        bot
        PrusaSlicer handles the functions differently for DSF vs "RRF." I do not have an SBC to test. What is the way to do things with SBC vs standalone?
        *not actually a robot
          chrishamm administrators @Stephen6309
          @stephen6309 @PetrKroupa I just tried this with PrusaSlicer 2.4.0 and the print started right after the upload. If you have SSH access to your machines, can you run
          journalctl -u duetwebserver -f
          and check what happens when you send a G-code job to your printer?
          Duet software engineer
          undefined 1 Reply Last reply 16 Feb 2022, 15:58 Reply Quote 0
            PetrKroupa @chrishamm
            @chrishamm -
            Run comand and start upload.
            pi@malej:~ $ journalctl -u duetwebserver -f
            -- Logs begin at Tue 2022-02-15 05:47:02 CET. --
            Feb 16 16:53:30 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Executed action DuetWebServer.Controllers.MachineController.DeleteFileOrDirectory (DuetWebServer) in 29.9095ms
            Feb 16 16:53:30 malej DuetWebServer[596]: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Executed endpoint 'DuetWebServer.Controllers.MachineController.DeleteFileOrDirectory (DuetWebServer)'
            Feb 16 16:53:30 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 DELETE http://192.168.1.50/machine/file/0:%2Fgcodes%2Ffixa_cidlo_0.2mm_PETG_malej_12h39m.gcode application/json - - 204 - - 32.2082ms
            Feb 16 16:53:30 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://192.168.1.50/machine/directory/0:%2Fgcodes%2F application/json -
            Feb 16 16:53:30 malej DuetWebServer[596]: Microsoft.AspNetCore.Routing.EndpointMiddleware[0] Executing endpoint 'DuetWebServer.Controllers.MachineController.GetFileList (DuetWebServer)'
            Feb 16 16:53:30 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Route matched with {action = "GetFileList", controller = "Machine"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.IActionResult] GetFileList(System.String) on controller DuetWebServer.Controllers.MachineController (DuetWebServer).
            Feb 16 16:53:30 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1] Executing ContentResult with HTTP Response ContentType of application/json
            Feb 16 16:53:30 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Executed action DuetWebServer.Controllers.MachineController.GetFileList (DuetWebServer) in 20.9218ms
            Feb 16 16:53:30 malej DuetWebServer[596]: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Executed endpoint 'DuetWebServer.Controllers.MachineController.GetFileList (DuetWebServer)'
            Feb 16 16:53:30 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://192.168.1.50/machine/directory/0:%2Fgcodes%2F application/json - - 200 705 application/json 22.9608ms
            Feb 16 16:53:41 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://192.168.1.50/rr_connect?password=reprap&time=2022-02-16T16:53:06 - -
            Feb 16 16:53:41 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://192.168.1.50/rr_connect?password=reprap&time=2022-02-16T16:53:06 - - - 404 0 - 15.1087ms
            Feb 16 16:53:41 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://192.168.1.50/machine/status - -
            Feb 16 16:53:41 malej DuetWebServer[596]: Microsoft.AspNetCore.Routing.EndpointMiddleware[0] Executing endpoint 'DuetWebServer.Controllers.MachineController.Status (DuetWebServer)'
            Feb 16 16:53:41 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Route matched with {action = "Status", controller = "Machine"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.IActionResult] Status() on controller DuetWebServer.Controllers.MachineController (DuetWebServer).
            Feb 16 16:53:41 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1] Executing ContentResult with HTTP Response ContentType of application/json
            Feb 16 16:53:41 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Executed action DuetWebServer.Controllers.MachineController.Status (DuetWebServer) in 73.3141ms
            Feb 16 16:53:41 malej DuetWebServer[596]: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Executed endpoint 'DuetWebServer.Controllers.MachineController.Status (DuetWebServer)'
            Feb 16 16:53:41 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://192.168.1.50/machine/status - - - 200 14110 application/json 90.5221ms
            Feb 16 16:53:41 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 PUT http://192.168.1.50/machine/file/gcodes/fixa_cidlo_0.2mm_PETG_malej_12h39m.gcode - 13348749
            Feb 16 16:53:41 malej DuetWebServer[596]: Microsoft.AspNetCore.Routing.EndpointMiddleware[0] Executing endpoint 'DuetWebServer.Controllers.MachineController.UploadFile (DuetWebServer)'
            Feb 16 16:53:41 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Route matched with {action = "UploadFile", controller = "Machine"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.IActionResult] UploadFile(System.String, DuetWebServer.Singletons.ISessionStorage) on controller DuetWebServer.Controllers.MachineController (DuetWebServer).
            and wait forewer.
            after stop in prusa slicer:
            Feb 16 16:55:33 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Executed action DuetWebServer.Controllers.MachineController.DeleteFileOrDirectory (DuetWebServer) in 40.363ms
            Feb 16 16:55:33 malej DuetWebServer[596]: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Executed endpoint 'DuetWebServer.Controllers.MachineController.DeleteFileOrDirectory (DuetWebServer)'
            Feb 16 16:55:33 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 DELETE http://192.168.1.50/machine/file/0:%2Fgcodes%2Ffixa_cidlo_0.2mm_PETG_malej_12h39m.gcode application/json - - 204 - - 42.3188ms
            Feb 16 16:55:33 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://192.168.1.50/machine/directory/0:%2Fgcodes%2F application/json -
            Feb 16 16:55:33 malej DuetWebServer[596]: Microsoft.AspNetCore.Routing.EndpointMiddleware[0] Executing endpoint 'DuetWebServer.Controllers.MachineController.GetFileList (DuetWebServer)'
            Feb 16 16:55:33 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Route matched with {action = "GetFileList", controller = "Machine"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.IActionResult] GetFileList(System.String) on controller DuetWebServer.Controllers.MachineController (DuetWebServer).
            Feb 16 16:55:33 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1] Executing ContentResult with HTTP Response ContentType of application/json
            Feb 16 16:55:33 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Executed action DuetWebServer.Controllers.MachineController.GetFileList (DuetWebServer) in 19.3754ms
            Feb 16 16:55:33 malej DuetWebServer[596]: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Executed endpoint 'DuetWebServer.Controllers.MachineController.GetFileList (DuetWebServer)'
            Feb 16 16:55:33 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://192.168.1.50/machine/directory/0:%2Fgcodes%2F application/json - - 200 705 application/json 22.5984ms
            Feb 16 16:55:44 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://192.168.1.50/rr_connect?password=reprap&time=2022-02-16T16:55:09 - -
            Feb 16 16:55:44 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://192.168.1.50/rr_connect?password=reprap&time=2022-02-16T16:55:09 - - - 404 0 - 10.9784ms
            Feb 16 16:55:44 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://192.168.1.50/machine/status - -
            Feb 16 16:55:44 malej DuetWebServer[596]: Microsoft.AspNetCore.Routing.EndpointMiddleware[0] Executing endpoint 'DuetWebServer.Controllers.MachineController.Status (DuetWebServer)'
            Feb 16 16:55:44 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Route matched with {action = "Status", controller = "Machine"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.IActionResult] Status() on controller DuetWebServer.Controllers.MachineController (DuetWebServer).
            Feb 16 16:55:44 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1] Executing ContentResult with HTTP Response ContentType of application/json
            Feb 16 16:55:44 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Executed action DuetWebServer.Controllers.MachineController.Status (DuetWebServer) in 67.8908ms
            Feb 16 16:55:44 malej DuetWebServer[596]: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Executed endpoint 'DuetWebServer.Controllers.MachineController.Status (DuetWebServer)'
            Feb 16 16:55:44 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://192.168.1.50/machine/status - - - 200 14108 application/json 81.8717ms
            Feb 16 16:55:44 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 PUT http://192.168.1.50/machine/file/gcodes/fixa_cidlo_0.2mm_PETG_malej_12h39m.gcode - 13348749
            Feb 16 16:55:44 malej DuetWebServer[596]: Microsoft.AspNetCore.Routing.EndpointMiddleware[0] Executing endpoint 'DuetWebServer.Controllers.MachineController.UploadFile (DuetWebServer)'
            Feb 16 16:55:44 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Route matched with {action = "UploadFile", controller = "Machine"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.IActionResult] UploadFile(System.String, DuetWebServer.Singletons.ISessionStorage) on controller DuetWebServer.Controllers.MachineController (DuetWebServer).
            Feb 16 16:57:23 malej DuetWebServer[596]: DuetWebServer.Controllers.MachineController[0] [UploadFile Failed upload file gcodes/fixa_cidlo_0.2mm_PETG_malej_12h39m.gcode (resolved to /opt/dsf/sd/gcodes/fixa_cidlo_0.2mm_PETG_malej_12h39m.gcode) Microsoft.AspNetCore.Server.Kestrel.Core.BadHttpRequestException: Unexpected end of request content.    at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.Http1ContentLengthMessageBody.ReadAsyncInternal(CancellationToken cancellationToken)    at System.Runtime.CompilerServices.PoolingAsyncValueTaskMethodBuilder`1.StateMachineBox`1.System.Threading.Tasks.Sources.IValueTaskSource<TResult>.GetResult(Int16 token)    at System.IO.Pipelines.PipeReader.CopyToAsyncCore[TStream](TStream destination, Func`4 writeAsync, CancellationToken cancellationToken)    at DuetWebServer.Controllers.MachineController.UploadFile(String filename, ISessionStorage sessionStorage) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetWebServer/Controllers/MachineController.cs:line 410
            Feb 16 16:57:23 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ObjectResultExecutor[1] Executing ObjectResult, writing value of type 'System.String'.
            Feb 16 16:57:23 malej DuetWebServer[596]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Executed action DuetWebServer.Controllers.MachineController.UploadFile (DuetWebServer) in 98781.7749ms
            Feb 16 16:57:23 malej DuetWebServer[596]: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Executed endpoint 'DuetWebServer.Controllers.MachineController.UploadFile (DuetWebServer)'
            Feb 16 16:57:23 malej DuetWebServer[596]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 PUT http://192.168.1.50/machine/file/gcodes/fixa_cidlo_0.2mm_PETG_malej_12h39m.gcode - 13348749 - 500 - text/plain;+charset=utf-8 98811.6824ms
            If I can test something else, let me know.
            Petr
              @petrkroupa I cannot spot anything obvious there, it seems PS is getting stuck at some point during the transfer. I cannot reproduce this problem either, I just tried to upload a 20MB file and it worked as expected. Are you using Windows?
              @bot It's just a PUT request (e.g. PUT http://duet3/machine/file/gcodes/myFile.gcode) with the plain G-code file as the body content. I just noticed one potential problem in PrusaSlicer 2.4.0: When you upload a file to a subdirectory, it doesn't use a slash but a backslash in the upload request as the directory separator (at least on Windows). Can you confirm this?
              undefined undefined 2 Replies Last reply 16 Feb 2022, 18:58 Reply Quote 0
                bot @chrishamm
                @chrishamm I was just taking a look to see what might be going wrong. You could be correct. It encodes the filename directly to the url.
                	if (connectionType == ConnectionType::dsf) {
                		return (boost::format("%1%machine/file/gcodes/%2%")
                				% get_base_url()
                				% Http::url_encode(filename)).str();
                Which is called like this (filename is the first argument):
                auto upload_cmd = get_upload_url(upload_data.upload_path.string(), connectionType);
                Which, digging into it, seems to directly set the upload path as the filesystem directory. So, yeah, on WIndows it might have \ instead of /.
                In the logs above, I did notice:
                But I do not understand what it means exactly.
                undefined 1 Reply Last reply 16 Feb 2022, 19:04 Reply Quote 1
                  chrishamm administrators @bot
                  @bot Thanks for looking into it. Unexpected end of request content means the request was too short which can be expected when the HTTP request is cancelled. So nothing unusual in there AFAICS.
                  undefined 1 Reply Last reply 16 Feb 2022, 19:40 Reply Quote 1
                    bot @chrishamm
                    @chrishamm
                    I think the filename argument ends up being different depending on where the upload is initiated from. There seeems to be a background process that will upload files at times, or prepare the data for upload at least.
                    @Stephen6309 Do you have background slicing/processing enabled in prusaslicer? I forget what the exact feature name is called. It's in the app preferences.
                    Anyways. It seems to me that the path is set by the user input of the upload dialog.
                    Plater.cpp Line 6310
                        PrintHostSendDialog dlg(default_output_file, upload_job.printhost->get_post_upload_actions(), groups);
                        if (dlg.ShowModal() == wxID_OK) {
                            upload_job.upload_data.upload_path = dlg.filename();
                            upload_job.upload_data.post_action = dlg.post_action();
                            upload_job.upload_data.group       = dlg.group();
                            p->export_gcode(fs::path(), false, std::move(upload_job));
                    There is a note on the dialog to use forward slashes a directory separators.
                      @chrishamm - Yes, on windows. Today I discovered an interesting thing. I use the arc welder plugin in post-processing scripts. If I do not use it, the upload will go smoothly.
                      @Stephen6309 - Do you use ARC Welder too?
                      Petr
                      undefined undefined 2 Replies Last reply 17 Feb 2022, 08:33 Reply Quote 0
                        chrishamm administrators @PetrKroupa
                        @petrkroupa That's the reason why it doesn't work. Perhaps PrusaSlicer doesn't wait for ArcWelder to finish or it attempts to use file information of the old unprocessed file before it sends it over to the Duet.
                        Either way this is no problem in DSF or RRF.
                        undefined 1 Reply Last reply 17 Feb 2022, 08:59 Reply Quote 0
                          @chrishamm - I agree. I assume that @Stephen6309 will confirm that he also uses this plugin. That's probably why no one has solved it yet and had no problem with it. This combination is probably not very common.
                          Thanks for help.
                          Petr
                            Stephen6309 @PetrKroupa
                            @petrkroupa Yes I use arcwelder. But this problem only occurs with the PI4.
                            undefined 1 Reply Last reply 17 Feb 2022, 15:23 Reply Quote 0
                              PetrKroupa @Stephen6309
                              @stephen6309 - I can't test that because both printers I have with RPi4. However, if without SBC it works ok then it will be something in DSF or RRF. What do you think @chrishamm ?
                              Petr
                              undefined 1 Reply Last reply 17 Feb 2022, 15:25 Reply Quote 0
                                @petrkroupa I am not convinced this is a problem in DSF. If you can upload files as usual using the web interface and if it works from PrusaSlicer without ArcWelder, it's obvious that ArcWelder interferes somehow with the upload process.
                                undefined 2 Replies Last reply 17 Feb 2022, 15:29 Reply Quote 0
                                  Stephen6309 @chrishamm
                                  @chrishamm Upload fine in standalone mode using arcwelder. My Duet 3 Mini 5+ is in standalone mode and everything uploaded fine. When I had a problem on my 6HC, I set it up in standalone mode for troubleshooting and the uploads worked fine.
                                  The only difference between the two, is the PI4.
                                    @chrishamm PrusaSlicer 2.4.1beta4, SBC mode never finshes upload.
                                    undefined 1 Reply Last reply 28 Feb 2022, 11:19 Reply Quote 0
                                      @stephen6309 I cannot confirm that (this is without ArcWelder on Windows x64):
                                      I just checked 2.4.1-b3 on Linux x64 and there it works with ArcWelder too.
                                      undefined undefined 2 Replies Last reply 28 Feb 2022, 16:43 Reply Quote 0
                                        @chrishamm Without an arc welder, it works on both my printers. Both 6HC + SBC. But not with ARCwelder. It always gets stuck at 96-97% depending on the file size.
                                        I don't have a Linux PC to test it.
                                        Petr
                                          @chrishamm Without arcwelder or the PI, it works fine. Just not working in SBC mode.
                                          undefined 1 Reply Last reply 21 Apr 2022, 13:31 Reply Quote 0
