G31 offset direction logic
    RajaaKahel
    My probe offsets are:
    X 26.8 (The nozzle is the closer to 0 position/endstop)
    Y 23.3 (The nozzle is the closer to 0 position/endstop)
    Z 1.5 (the nozzle is in the negative side of the Bl-touch triggering hight)
    The issue is that I had to put Z offset in positive value in order to get the nozzle to touch the bed at 0 hight. Does that mean that the logic is inverted and I have to change X and Y offsets to negative value?
    G31 P500 X26.8 Y23.3 Z1.5
    undefined 1 Reply Last reply 19 Feb 2022, 14:25 Reply Quote 0
      Stephen6309 @RajaaKahel
      @rajaakahel Use negative if the probe is towards X0 Y0 of the nozzle. The Z offset is how much the nozzle has to move form the probe trigger position to make the nozzle at Z0, and it's a positive number.
      undefined 1 Reply Last reply 19 Feb 2022, 19:00 Reply Quote 0
        RajaaKahel @Stephen6309
        @stephen6309 Ok thanks, then my offsets are correct as they are.
        1 out of 3
