Easy question: Z-offset/trigger Height
    westech
    Thank for all the help. I got my BL touch and my mesh really nicely set. I would like a little more SQUASH, maybe bring the nozzle down 0.1mm.
    G31 P500 X-40 Y-12 Z2.08
    For the Z offset, I should reduce the number to bring the nozzle closer to the bed, or increase the number?
    undefined 1 Reply Last reply 22 Feb 2022, 03:47 Reply Quote 0
      rjenkinsgb
      Reduce it, I believe?
      Robert J.
      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
        fcwilt @westech
        @westech
        By Z offset to you mean the Z parameter to G31, the Z Trigger Height?
        If so remember that larger values move the nozzle closer to the bed.
        undefined 1 Reply Last reply 22 Feb 2022, 03:59 Reply Quote 1
          westech @fcwilt
          @fcwilt Thanks, that's why I was confused. my Z is Z2.08. So if I change it to Z2.18 I will be .1mm closer to the bed.
          undefined 1 Reply Last reply 22 Feb 2022, 04:06 Reply Quote 0
            fcwilt @westech
            @westech said in Easy question: Z-offset/trigger Height:
            Yes.
            When the probe triggers the logical Z position is set to the Z Trigger Height parameter value. That doesn't mean that logical position matches the physical position, though that is the goal.
            So if the Z Trigger Height parameter is 5, the logical Z position is set to 5 and the firmware "believes" that to move to Z = 0 it needs to move closer to the bed by 5mm. If after moving 5mm there is a gap between the tip of the nozzle and the bed that 5 value was too small. If before moving 5mm the tip of the nozzle touches the bed that 5 value was too large.
            3 out of 5
