    Putting the heater into operation what is wrong?
    Using Duet Controllers
    • dieterddundefined
      dieterdd
      I have tried to understand the existing Gcode. The hotend has been set to "out3" and "temp3" by the creator. I have connected both heater and thermistor accordingly.
      But when I set the temperatures in the controller at tool 0 and switched them on, the temperatures shot up above the set values.
      As feared I need your help again🙃
      For info: the other two heaters are used for the bed (50x50cm each)
      Board: Duet 3 Mainboard 6HC
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out2" T0 Q1 ; create heater output on out0 and map it to sensor 0 ; disable bang-bang mode for heater and set PWM limit
      M143 H0 S70 ; set temperature limit for heater 0 to 70C
      M140 P1 H0
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 Q1 ; create heater output on out1 and map it to sensor 1 ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H1 S70 ; set temperature limit for heater 1 to 70C
      M140 P2 H1
      M308 S2 P"temp3" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1
      M950 H2 C"out3" T2 Q500 ; create heater output on out1 and map it to sensor 1 ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H2 S260 ; set temperature limit for heater 1 to 70C
      M307 H0 A200.8 C850.6 D2.0 S1.00 V24.0 B0
      M307 H1 A200.0 C850.0 D2.0 S1.00 V24.0 B0
      M307 H2 A491.0 C185.5.0 D4.9 S1.00 V24.0 B0
      to the picture:The going down of the temperature was done by "hand"
      Thanks for looking at it in advance
      Dieter
      3d drucken? - JA! Einen 3DDrucker bauen? - JA! Elektronik (Duet 3 6HC ) einstellen? - HILFE!!!
      3d printing? - YES! Build a 3D printer? - YES! Adjust electronics (Duet 3 6HC )? - HELP!!!
        Did the temperature really rise 200c in less than 30 seconds?
        Can you plese provide some more details?
        What kind of heaters (12v? 24v?) and thermistors are these?
        Can you please post your full config.g?
        Also the results of M122 and M98 P"config.g" can be very useful.
        dieterddundefined 1 Reply Last reply Reply Quote 0
        • dieterddundefined
          dieterdd @Phaedrux
          @phaedrux
          Never think to have thought, because thinking the thoughts (I would have used a 24V heater) is thoughtless thinking ... it was a 12v heater cartridge😬🙃🙂 thank you! danke!
          • Phaedruxundefined Phaedrux has marked this topic as solved
