    Weird retraction problem. How is my end G-code?
    • westechundefined
      westech
      Greetings!
      Thought I'd ask here. I use Cura on an Ender 3. Trying a new fast profile. Same end g-code I have been using. But I've experienced the extruder retracting almost all the way up the bowden tube at the end.
      I leaned the hard way on my next print when nothing was coming out.
      Does my end G-code look okay?
      G91 ;Relative positioning
      G1 E-2 F2700 ;Retract a bit
      G1 E-2 Z0.2 F2400 ;Retract and raise Z
      G1 X5 Y5 F3000 ;Wipe out
      G1 Z10 ;Raise Z more
      G90 ;Absolute positioning
      G1 X0 Y{machine_depth} ;Present print
      M106 S0 ;Turn-off fan
      M104 S0 ;Turn-off hotend
      M140 S0 ;Turn-off bed
      M84 X Y E ;Disable all steppers but Z
      • fcwiltundefined
        fcwilt @westech
        @westech
        G91 sets relative mode only for axis moves.
        For extrusion you need M82 to set absolute mode and M83 to set relative mode.
        Stephen6309undefined 1 Reply Last reply Reply Quote 1
        • Stephen6309undefined
          Stephen6309 @fcwilt
          @fcwilt M83 is for relative extruder mode. 🙂
          fcwiltundefined 1 Reply Last reply Reply Quote 2
          • fcwiltundefined
            fcwilt @Stephen6309
            @stephen6309 said in Weird retraction problem. How is my end G-code?:
            Thanks for catching my typo.
