Solved multiple lines of gcode executed at the same time
We are making a machine with a 6HC and 5 3HC and 1 1XD and we find that multiple lines of gcode get executed at the same time. (probably with a milliseconds delay)
here is our config.g file
G90 ; absolute mode M83 ; relative extrusion M111 S0 ; Debug off G21 ; Work in millimetres ; Display initial welcome message M291 R"This machine is in maintenance mode, be carefull!" P"Axis will move without restrictions." S1 T0 G4 S2 ;wait for expansion boards to start ;M564 H0 S1 ; H0=move without homing S1=move within boundaries ;stepper setup S=CW/CCW R=enable high/low ;motors on mainboard M569 P0.3 S0 ; left bottom pump goes forwards M569 P0.4 S1 ; left middle pump goes forward M569 P0.5 S1 ; left top pump goes forwards ;Z drive at 1XD M569 P122.0 S0 R0 ; Z drive ;motors on 3HC 1 M569 P1.0 S1 ; U drive right goes forwards M569 P1.1 S1 ; Y drive left goes backwards ;motors on 3HC 2 M569 P2.0 S0 ; motor goes forwards M569 P2.1 S1 ; motor left goes backwards ;motors on 3HC 3 M569 P3.0 S0 ; motor goes forwards M569 P3.1 S1 ; motor left goes backwards ;motors on 3HC 4 M569 P4.0 S0 ; X drive goes forwards M569 P4.1 S0 ; Y drive right goes backwards ;motors on 3HC 5 M569 P5.0 S0 ; right bottom pump goes forwards M569 P5.1 S0 ; right middle pump right goes backwards M569 P5.2 S0 ; right top pump forwards ;linear Mapping M584 U1.0 X4.0 Y1.1:4.1 Z122.0 S0 ; set drive mapping ; Axis Limits M208 U72 X0 Y0 Z0 S1 ; set axis minima M208 U1528 X1456 Y255 Z270 S0 ; set axis maxima ; Endstops M574 U2 S1 P"!3.io0.in" ; U max active low(!) endstop switch M574 X1 S1 P"!2.io0.in" ; X min active low(!) endstop switch M574 Y2 S1 P"!1.io0.in+!4.io0.in" ; Y max active low(!) endstop switch M574 Z2 S1 P"!1.io1.in+!4.io1.in" ; Z max active low(!) endstop switch ;pump mapping M584 E0.5:0.4:0.3:5.2:5.1:5.0 M350 U16 X16 Y16 Z16 I1 ; configure linear microstepping M350 E16:16:16:16:16:16 ; configure pump microstepping M92 U26.7 X26.7 Y60 Z1600 ; set linear axis steps/mm M92 E3200:3200:3200:3200:3200:3200 ; set pump steps/mm M566 U60 X60 Y60 Z60 ; Maximum jerk speeds mm/minute M566 E10:10:10:10:10:10 ; Maximum pump jerk speeds mm/minute M203 U42000 X42000 Y12000 Z900 ; Maximum speeds (mm/min) M203 E1000:1000:1000:1000:1000:1000 ; Maximum pump speeds (mm/min) M201 U1000 X1000 Y500 Z30 ; Accelerations (mm/s^2) M201 E10:10:10:10:10:10 ; pump Accelerations (mm/s^2) M906 U2000 X2000 Y3000 I30 ; Set motor currents (mA) M906 E3000:3000:3000:3000:3000:3000 ; Set pump currents (mA) M84 S30 ; Set idle timeout
so we made a little macro
G1 X100 F6000 G1 Y100 F6000
and what happens is
G1 X100 Y100 F6000
What are we doing wrong?
@fcwilt We want it to move to the right.
Then, when it has moved to the right it, move to the back.
In that sequence.But in stead, it moves to the back right in one go.
@danzaywer M400 does not do what it should, still the same result.
G4 Sxx does work (as a backup, but should absolutely not be needed) -
@jos_mosa what firmware version are you running?
RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)Also on the expansion boards
@jos_mosa I'm not aware of any bug in 3.3 that would cause the issue you report. However, there have been major changes in the development of RRF 3.4 that may affect the behaviour. So please upgrade to RRF 3.4RC2 and see if you still get the incorrect behaviour. If you do then I will attempt to reproduce your configuration.
@dc42 we updated to 3.4RC2 but now the pi will not connect to it.
DCS is not started.
sudo journalctl -u duetcontrolserver gives: invalid protocol version 6went for unstable release
Installed 3.4RC2 and it now works as it should
Thanks for the tips
@jos_mosa thanks, I'll close this thread.
