    Error loading and generating heighmap.csv
    Using Duet Controllers
    489
    • Marcossfundefined
      Marcossf
      Hi everyone,
      We have this error trying to active the mesh bed leveling:
      Error: G29: Failed to load height map from file heightmap.csv: Unknown heightmap field: axis0
      The file is present and we tried to delete and get a new probe map but the problem remains.
      heightmap contains the matrix points obtained with the G32 (bed.g macro) but it seem there is a format? problem reading the data.
      If we issue a new G29 S0 to get a new map file, the printer hangs at the finish, after the last point probed, the general status is IDLE but unresponsive and need to reset it to get it back alive.
      Once reseted, the new heightmap.csv is there but it fails when enabling it again. This is the file created:
      RepRapFirmware height map file v2 generated at 2022-03-09 14:00, min error -0.230, max error 0.080, mean -0.060, deviation 0.095
      axis0,axis1,min0,max0,min1,max1,radius,spacing0,spacing1,num0,num1
      X,Y,-100.00,100.00,-60.00,60.00,-1.00,49.99,30.00,5,5
        0.010, -0.020, -0.060, -0.130, -0.200
        0.060,  0.010, -0.040, -0.120, -0.220
        0.080,  0.040, -0.010, -0.120, -0.230
        0.050,  0.050,  0.000, -0.110, -0.220
       -0.040,  0.020, -0.020, -0.100, -0.190
      Tryed to get a G29 S3 p"file.csv" but the file.csv isn't made. Just hangs.
      SBC mode, Duet 3 MB6HC + 1LC + 1XD version 3.4.0rc2
      What to try for troubleshoot it? New bug?
        Can you share the results of M122 and M122 B# where # is the canbus address of the expansion boards?
        Also please share your config.g
        Marcossfundefined 1 Reply Last reply Reply Quote 0
        • Marcossfundefined
          Marcossf @Phaedrux
          @phaedrux Our config.g its very complex and related to other files with a lot of variables and I think it doesn't give additional information.
          All the axis are driven by 1XD boards, connected to OM closed loop external drivers and servos except the printheads which are driven by 1LC boards. In the +3.4 beta7 this was working fine. Prior to that, it was affected by the CANbus delay when probing, but resolved by David from this beta version. With the latest RC all works except this issue, at least the things tested so far.
          I think, now the G29 command has a bug in the 3.4Rc2, that may be related to the modifications @dc42 did to solve this issue: https://forum.duet3d.com/topic/27248/3-4-rc1-1xd-probe-problem-after-update/3?_=1646900775328
          M122 from the 6HC board, six 1XD and three 1LC doesn't shows any hint of failure. All movements works as expected except this error making or reading the mesh bed level file.
            Can you test with this build?
            https://www.dropbox.com/sh/amtiizdcylnuaye/AAA4hzXFvU0RMOSDtdT37HFua?dl=0
            Marcossfundefined 1 Reply Last reply Reply Quote -1
            • Marcossfundefined
              Marcossf @Phaedrux
              @phaedrux I'll try asap and back with the results.
              • Marcossfundefined
                Marcossf @Marcossf
                @Phaedrux @dc42 With the version 3.4RC2+2 it doesn't work either. We drop the version files thru DWC and updated sucessfully all boards, while using SBC not standalone mode.
                DSF and DWC are still in version: 3.4-b3. Are the parts that we still didn't updated.
                Sending a simple code like this:
                G28
                G29 S2
                G29 S0
                Does the home OK, erase all mesh corrections OK, probe the area OK.
                BUT, after the last probe point and retract the probe, the printer goes idle but it hangs up. The send button in DWC keeps doing circles and it's unresponsive until we reset it.
                After reset, boot fine, and there is the heightmap file saved, but notifying at start console there's a error loading heightmap.csv described up there.
                All remaining funcionality works well.
                We need to get out this printer to customer asap (max. March18th) so we are concerned. If mesh bed leveling doesn't works properly the printer can't be delivered.
                11/3/2022, 19:33:19: Connected to 192.168.2.100:3000
                11/3/2022, 19:37:40: m122: === Diagnostics ===
                RepRapFirmware for Duet 3 MB6HC version 3.4.0rc2+2 (2022-03-07 20:15:30) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                Board ID: 08DJM-9P63L-DJMSS-6J9D0-3S46M-9UFM8
                Used output buffers: 1 of 40 (18 max)
                Static ram: 151000
                Dynamic ram: 70072 of which 0 recycled
                Never used RAM 126024, free system stack 152 words
                Tasks: SBC(resourceWait:,0.7%,494) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.1%,259) CanReceiv(notifyWait,0.1%,772) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,339) TMC(notifyWait,7.8%,92) MAIN(running,91.2%,923) IDLE(ready,0.1%,30), total 100.0%
                Owned mutexes: HTTP(MAIN)
                Last reset 00:11:16 ago, cause: software
                Last software reset at 2022-03-11 19:26, reason: User, GCodes spinning, available RAM 126024, slot 1
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                Error status: 0x00
                Step timer max interval 738
                MCU temperature: min 21.4, current 22.4, max 22.5
                Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                Heap OK, handles allocated/used 99/14, heap memory allocated/used/recyclable 2048/1358/1156, gc cycles 0
                Events: 0 queued, 0 completed
                Driver 0: standstill, SG min 0, mspos 8, reads 53004, writes 11 timeouts 0
                Driver 1: standstill, SG min 0, mspos 8, reads 53004, writes 11 timeouts 0
                Driver 2: standstill, SG min 0, mspos 8, reads 53004, writes 11 timeouts 0
                Driver 3: standstill, SG min 0, mspos 8, reads 53004, writes 11 timeouts 0
                Driver 4: standstill, SG min 0, mspos 8, reads 53004, writes 11 timeouts 0
                Driver 5: standstill, SG min 0, mspos 8, reads 53005, writes 11 timeouts 0
                Date/time: 2022-03-11 19:37:39
                Slowest loop: 55.66ms; fastest: 0.03ms
                === Storage ===
                Free file entries: 10
                DMs created 125, segments created 30, maxWait 119971ms, bed compensation in use: mesh, comp offset 0.000
                === MainDDARing ===
                Scheduled moves 1376, completed 1376, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                === AuxDDARing ===
                Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 1 -1 -1 -1, ordering errs 0
                Segments left: 0
                Movement lock held by HTTP
                Telnet* is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is idle in state(s) 0
                Aux2 is idle in state(s) 0
                Code queue is empty
                === Filament sensors ===
                Extruder 0 sensor: no filament
                === CAN ===
                Messages queued 10165, received 54399, lost 0, boc 0
                Longest wait 2ms for reply type 6031, peak Tx sync delay 152, free buffers 50 (min 17), ts 3383/3382/0
                Tx timeouts 0,0,0,0,0,0
                === SBC interface ===
                Transfer state: 4, failed transfers: 0, checksum errors: 0
                RX/TX seq numbers: 29519/29519
                SPI underruns 0, overruns 0
                State: 5, disconnects: 0, timeouts: 0, IAP RAM available 0x2b880
                Buffer RX/TX: 0/0-0, open files: 0
                === Duet Control Server ===
                Duet Control Server v3.4-b3
                Code buffer space: 4096
                Configured SPI speed: 8000000Hz
                Full transfers per second: 43.73, max wait times: 53.7ms/5.0ms
                Codes per second: 1.27
                Maximum length of RX/TX data transfers: 4400/820
                11/3/2022, 19:38:10: m122 b40: Diagnostics for board 40:
                Duet EXP1XD firmware version 3.4.0rc2+2 (2022-03-07 20:16:45)
                Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
                All averaging filters OK
                Never used RAM 5524, free system stack 43 words
                Tasks: Move(notifyWait<null>,0.1%,111) HEAT(notifyWait<null>,0.1%,115) CanAsync(notifyWait<null>,0.0%,60) CanRecv(notifyWait<null>,0.0%,75) CanClock(notifyWait<null>,0.0%,64) MAIN(running<null>,96.3%,443) IDLE(ready<null>,0.0%,40) AIN(delaying<null>,3.5%,142), total 100.0%
                Last reset 00:11:46 ago, cause: software
                Last software reset data not available
                Driver 0: pos -8132, 150.5 steps/mm, steps req 264316 done 241135
                Moves scheduled 1317, completed 1317, in progress 0, hiccups 0, step errors 0, maxPrep 443, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                Peak sync jitter 0/6, peak Rx sync delay 204, resyncs 0/0, no step interrupt scheduled
                VIN voltage: min 24.4, current 24.5, max 24.5
                MCU temperature: min 21.4C, current 22.2C, max 22.2C
                Last sensors broadcast 0x00000000 found 0 194 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 5676, send timeouts 0, received 10365, lost 0, free buffers 37, min 37, error reg 0
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 324, adv 34966/92488
                11/3/2022, 19:38:12: m122 b41: Diagnostics for board 41:
                Tasks: Move(notifyWait<null>,0.1%,111) HEAT(notifyWait<null>,0.1%,115) CanAsync(notifyWait<null>,0.0%,60) CanRecv(notifyWait<null>,0.0%,75) CanClock(notifyWait<null>,0.0%,64) MAIN(running<null>,96.4%,448) IDLE(ready<null>,0.0%,40) AIN(delaying<null>,3.5%,142), total 100.0%
                Last reset 00:11:47 ago, cause: software
                Driver 0: pos -19721, 150.5 steps/mm, steps req 75113 done 46364
                Moves scheduled 1301, completed 1301, in progress 0, hiccups 0, step errors 0, maxPrep 451, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                Peak sync jitter 0/5, peak Rx sync delay 203, resyncs 0/0, no step interrupt scheduled
                MCU temperature: min 23.0C, current 23.9C, max 23.9C
                Last sensors broadcast 0x00000000 found 0 66 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 5690, send timeouts 0, received 10370, lost 0, free buffers 37, min 37, error reg 0
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 324, adv 35375/92771
                11/3/2022, 19:38:13: m122 b42: Diagnostics for board 42:
                Never used RAM 5556, free system stack 43 words
                Tasks: Move(notifyWait<null>,0.1%,111) HEAT(notifyWait<null>,0.1%,115) CanAsync(notifyWait<null>,0.0%,64) CanRecv(notifyWait<null>,0.0%,75) CanClock(notifyWait<null>,0.0%,64) MAIN(running<null>,96.4%,448) IDLE(ready<null>,0.0%,40) AIN(delaying<null>,3.5%,142), total 100.0%
                Last reset 00:11:49 ago, cause: software
                Driver 0: pos -19721, 150.5 steps/mm, steps req 75113 done 46366
                Moves scheduled 1301, completed 1301, in progress 0, hiccups 0, step errors 0, maxPrep 445, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                Peak sync jitter 0/5, peak Rx sync delay 201, resyncs 0/0, no step interrupt scheduled
                VIN voltage: min 24.7, current 24.8, max 24.8
                MCU temperature: min 16.9C, current 17.9C, max 17.9C
                Last sensors broadcast 0x00000000 found 0 52 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 5698, send timeouts 0, received 10388, lost 0, free buffers 37, min 37, error reg 0
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 326, adv 35768/93057
                11/3/2022, 19:38:15: m122 b43: Diagnostics for board 43:
                Tasks: Move(notifyWait<null>,0.0%,111) HEAT(notifyWait<null>,0.1%,115) CanAsync(notifyWait<null>,0.0%,60) CanRecv(notifyWait<null>,0.0%,75) CanClock(notifyWait<null>,0.0%,64) MAIN(running<null>,96.4%,448) IDLE(ready<null>,0.0%,40) AIN(delaying<null>,3.5%,142), total 100.0%
                Last reset 00:11:50 ago, cause: software
                Driver 0: pos -27342, 100.1 steps/mm, steps req 127736 done 87844
                Moves scheduled 83, completed 83, in progress 0, hiccups 0, step errors 0, maxPrep 450, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                Peak sync jitter 0/5, peak Rx sync delay 204, resyncs 0/0, no step interrupt scheduled
                VIN voltage: min 24.3, current 24.4, max 24.4
                MCU temperature: min 24.9C, current 26.1C, max 26.1C
                Last sensors broadcast 0x00000000 found 0 190 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 5718, send timeouts 0, received 9221, lost 0, free buffers 37, min 37, error reg 0
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 317, adv 36832/37179
                11/3/2022, 19:38:16: m122 b44: Diagnostics for board 44:
                Never used RAM 5524, free system stack 88 words
                Tasks: Move(notifyWait<null>,0.0%,153) HEAT(notifyWait<null>,0.1%,115) CanAsync(notifyWait<null>,0.0%,64) CanRecv(notifyWait<null>,0.0%,77) CanClock(notifyWait<null>,0.0%,64) MAIN(running<null>,96.4%,448) IDLE(ready<null>,0.0%,40) AIN(delaying<null>,3.5%,142), total 100.0%
                Last reset 00:11:52 ago, cause: software
                Driver 0: pos 0, 100.1 steps/mm, steps req 0 done 0
                Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                Peak sync jitter 1/5, peak Rx sync delay 198, resyncs 0/0, no step interrupt scheduled
                VIN voltage: min 24.5, current 24.6, max 24.6
                MCU temperature: min 22.7C, current 24.4C, max 24.4C
                Last sensors broadcast 0x00000000 found 0 62 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 5724, send timeouts 0, received 9126, lost 0, free buffers 37, min 37, error reg 0
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                11/3/2022, 19:38:17: m122 b45: Diagnostics for board 45:
                Tasks: Move(notifyWait<null>,0.0%,153) HEAT(notifyWait<null>,0.1%,115) CanAsync(notifyWait<null>,0.0%,64) CanRecv(notifyWait<null>,0.0%,77) CanClock(notifyWait<null>,0.0%,64) MAIN(running<null>,96.4%,443) IDLE(ready<null>,0.0%,40) AIN(delaying<null>,3.5%,142), total 100.0%
                Last reset 00:11:53 ago, cause: software
                Peak sync jitter 1/5, peak Rx sync delay 202, resyncs 0/0, no step interrupt scheduled
                MCU temperature: min 23.4C, current 25.2C, max 25.3C
                Last sensors broadcast 0x00000000 found 0 89 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 5734, send timeouts 0, received 9143, lost 0, free buffers 37, min 37, error reg 0
                11/3/2022, 19:38:22: m122 b20: Diagnostics for board 20:
                Duet TOOL1LC rev 1.1 or later firmware version 3.4.0rc2+2 (2022-03-07 20:17:47)
                Never used RAM 2732, free system stack 88 words
                Tasks: Move(notifyWait<null>,0.0%,153) HEAT(notifyWait<null>,0.2%,115) CanAsync(notifyWait<null>,0.0%,65) CanRecv(notifyWait<null>,0.0%,76) CanClock(notifyWait<null>,0.0%,65) ACCEL(notifyWait<null>,0.0%,61) TMC(notifyWait<null>,3.0%,57) MAIN(running<null>,91.9%,351) IDLE(ready<null>,0.0%,26) AIN(delaying<null>,4.9%,142), total 100.0%
                Last reset 00:11:57 ago, cause: software
                Driver 0: pos 0, 42.0 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 48, reads 31041, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
                Peak sync jitter 0/4, peak Rx sync delay 216, resyncs 0/0, no step interrupt scheduled
                MCU temperature: min 31.3C, current 32.5C, max 32.5C
                Last sensors broadcast 0x00000004 found 1 8 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 11752, send timeouts 0, received 6427, lost 0, free buffers 37, min 37, error reg 0
                Accelerometer: LIS3DH, status: 00
                I2C bus errors 0, naks 3, other errors 0
                Interrupt 5726621 to 0us, poll 4 to 484us
                Driver 0: ok
                11/3/2022, 19:38:23: m122 b21: Diagnostics for board 21:
                Never used RAM 3016, free system stack 88 words
                Tasks: Move(notifyWait<null>,0.0%,147) HEAT(notifyWait<null>,0.1%,115) CanAsync(notifyWait<null>,0.0%,65) CanRecv(notifyWait<null>,0.0%,76) CanClock(notifyWait<null>,0.0%,65) ACCEL(notifyWait<null>,0.0%,61) TMC(notifyWait<null>,3.0%,57) MAIN(running<null>,92.0%,441) IDLE(ready<null>,0.0%,26) AIN(delaying<null>,4.9%,142), total 100.0%
                Last reset 00:11:58 ago, cause: software
                Driver 0: pos 0, 42.0 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 48, reads 31748, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
                Peak sync jitter 0/4, peak Rx sync delay 213, resyncs 0/0, no step interrupt scheduled
                VIN voltage: min 24.1, current 24.2, max 24.2
                MCU temperature: min 30.8C, current 31.9C, max 32.0C
                Last sensors broadcast 0x00000000 found 0 166 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 5781, send timeouts 0, received 9214, lost 0, free buffers 37, min 37, error reg 0
                11/3/2022, 19:38:24: m122 b22: Diagnostics for board 22:
                Never used RAM 3856, free system stack 88 words
                Tasks: Move(notifyWait<null>,0.0%,153) HEAT(notifyWait<null>,0.1%,115) CanAsync(notifyWait<null>,0.0%,65) CanRecv(notifyWait<null>,0.0%,76) CanClock(notifyWait<null>,0.0%,65) TMC(delaying<null>,3.0%,57) MAIN(running<null>,92.0%,441) IDLE(ready<null>,0.0%,26) AIN(delaying<null>,4.9%,142), total 100.0%
                Last reset 00:12:00 ago, cause: software
                Driver 0: pos 0, 420.0 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 48, reads 32372, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
                Peak sync jitter 0/4, peak Rx sync delay 212, resyncs 0/0, no step interrupt scheduled
                VIN voltage: min 24.3, current 24.3, max 24.3
                MCU temperature: min 28.0C, current 29.5C, max 29.5C
                Last sensors broadcast 0x00000000 found 0 164 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 5790, send timeouts 0, received 9230, lost 0, free buffers 37, min 37, error reg 0
                Accelerometer: none
                I2C bus errors 0, naks 12, other errors 0
                  Phaedrux Moderator @Marcossf
                  @marcossf said in Error loading and generating heighmap.csv:
                  Those should be running 3.4 RC2 at least. I think this may be part of your problem. Are you able to update them using sudo apt update and sudo apt upgrade?
                  • Marcossfundefined
                    Marcossf @Phaedrux
                    @phaedrux Right now i'm doing that. Soon back with the results.
                    Thx!
                    • Marcossfundefined
                      Marcossf @Marcossf
                      YES! That was the problem. I'm sorry for such stupidity 😖
                      The heighmap file was done right and readed properly at boot. Waiting for a final stable version, hope soon!
                      Thanks! Have a good weekend.
