    PT1000 on Toolboard v1.2 shows 2000C on RRF 3.4RC2
    Using Duet Controllers
    • kdekid23undefined
      kdekid23
      I have a 6HC + 1LC Tool board configuration for a Voron 2.4 printer. The extruder motor, hotend heater, hotend/part fans, and hotend temperature sensor (PT1000) are connected to the tool board.
      The PT1000 sensor returns the correct temperature in RRF 3.3. However, when I upgrade both the 6HC and 1LC's firmware to 3.4RC2, the PT1000 sensor always return 2000C. Is this a known bug?
      Here's my config.g:
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Mar 02 2022 23:23:46 GMT-0500 (Eastern Standard Time)
      G90                                          ; send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M550 P"Voron2"                               ; set printer name
      M669 K1                                      ; select CoreXY mode
      ; Wait a moment for the CAN expansion boards to start
      G4 S2
      M552 P0.0.0.0 S1                             ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                   ; enable HTTP
      M586 P1 S1                                   ; enable FTP
      M586 P2 S0                                   ; disable Telnet
      M569 P0.4 S1      ; X motor direction (B motor)
      M569 P0.5 S1      ; Y motor direction (A motor)
      M569 P0.0 S1      ; Z0 motor direction
      M569 P0.1 S0      ; Z1 motor direction
      M569 P0.2 S1      ; Z2 motor direction
      M569 P0.3 S0      ; Z3 motor direction
      M569 P121.0 S0    ; E motor direction
      ; Motor remapping for dual Z and axis Limits
      M584 X0.4 Y0.5 Z0.0:0.1:0.2:0.3 E121.0                         ; set drive mapping
      M671 X-65:-65:365:365 Y-20:380:380:-20 S20      ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right)
      M557 X25:275 Y25:275 S25                        ; Define bed mesh grid (inductive probe, positions include the Z offset!)
      ; Microstepping and Speed
      M350 X256 Y256 E32 Z256 I0                     ; Configure microstepping with interpolation
      M92 X1280.00 Y1280.00 E800.00 z6400.00         ; Set steps per mm	1.8 motors
      ; Speeds, Acceleration and Jerk
      M566 X300.00 Y300.00 Z60.00 E600.00 P1          ; Set maximum instantaneous speed changes (mm/min)
      M203 X120000.00 Y120000.00 Z4000.00 E1200.00       ; Set maximum speeds (mm/min)
      M201 X9000.00 Y9000.00 Z1600.00 E5000.00        ; Set accelerations (mm/s^2)
      ; Motor currents
      M906 X1200.00 Y1200.00 Z1200.00 E513.757 I60        ; Set motor currents (mA) and motor idle factor in percent
      M84 S600                                     ; Set idle timeout
      ; Endstops for each Axis
      M574 X2 S1 P"!0.io0.in" 					 	; Set X endstop controlled by switch
      M574 Y2 S1 P"!0.io1.in"                      	; Set Y endstop controlled by switch
      M574 Z1 S1 P"0.io3.in"                          ; Set Z endstop
      ; Stallgaurd Sensitivy (maybe use to pause print after crash)
      M915 X S2 F0 H200 R0		                ; Set X axis Sensitivity  1.8 motors
      M915 Y S2 F0 H200 R0		                ; Set y axis Sensitivity  1.8 motors
      ; Mesh Grid
      M557 X5:280 Y30:250 P4                         ;
      ; Z Probe Offset (Probe behind Afterburner)
      G31 P1000 X0 Y25 Z1.367
      M208 X0 Y-2 Z0 S1                             ; set axis minima
      M208 X300 Y301 Z260 S0                       ; set axis maxima
      ; Heatbed Heaters and Thermistor Bed
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out1" T0                           ; create bed heater output on out1 and map it to sensor 0
      M307 H0 B1 S1.00                             ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                      ; map heated bed to heater 0
      M143 H0 S116                                 ; set temperature limit for heater 0 to 115C
      ; Fans Electronic compartment & Exhaust
      ; M950 F1 C"out3" Q100				    ; Creates Case Fan 1
      ; M106 P1 T40 S150 H0                 ; Case Fan 1 Settings (Turns on at 60°C tool temp) at low speed
      ; M950 F2 C"out4" Q100				    ; Creates Case Fan 2
      ; M106 P2 T40 S150 H0                  ; Case Fan 2 Settings (Turns on at 60°C tool temp) at low speed
      ; M950 F5 C"out2" Q100				    ; Creates Case Fan 2
      ; M106 P5 T95 S50 H0                  ; Exhaust fan
      ; Filament Runout sensor
      ;M950 J4 C"io5.in"               ; Input 4 filament sensor
      ;M581 P4 T2 S1 R1                ; Filament Sensor P4 triggers  inactive-to-active edge (S1) tigger2.g (T2) only when printing (R1)
      ;M591 D0 P1 C"io5.in" S1			; Filament Sensor
      ; Tool 0
      ; HotEnd Heaters and Thermistor HotEnd
      M308 S1 P"121.temp0" Y"pt1000"               ; define E0 temperature sensor
      M950 H1 C"121.out0" T1 Q100					                            ; Create HotEnd Heater
      M307 H1 B0 R2.310 C158.7:115.4 D5.24 S1.00 V24.5					; PID
      M143 H1 S315                                                    	; Set temperature limit for heater 1 to 285C HotEnd
      M302 S185 R185
      ; Select inductive probe, OMRON TL-Q5MC2-Z
      ; P4:       connected to Zmin SIG and GND
      ; I0:       P4 expects NC, TL-Q5MC2-Z is also NC
      ; T18000:   Move to probe points at 300mm/s
      ; F1200:    Probing Speed: 20mm/s
      ; H5:       Dive height: 5mm
      ; A5 S0.01: Perform up to 5 touches until change is below 0.01mm
      ; B1:       Turn off heaters while probing
      M400
      M98 P"/macros/Home/use_z_probe.g"
      G31 T8 P500 X0 Y25 Z3.45 ; inductive probe offset, not critical, only used for coarse homing
      G4 P200
      ; Accelerometer
      M955 P121.0 I20
      ; Fans Hotend + Part
      M950 F1 C"121.out1" Q100				; Creates HOTEND Fan
      M106 P1 T45 S0.8 H1                 ; HOTEND Fan Settings
      M950 F0 C"121.out2" Q100				; Creates PARTS COOLING FAN
      M106 P0 H-1                         ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off PARTS COOLING FAN
      M563 P0 S"Tool 0" D0 H1 F0                            ; Define tool 0
      G10 P0 X0 Y0 Z0                             ; Set tool 0 axis offsets
      G10 P0 R0 S0                                ; Set initial tool 0 active and standby temperatures to 0C
      M501										; Load overrides
        A Former User
        I had the same problem... after a while it was gone without changing something.
        don´t know what was wrong there..
        I also have the problem that I have no temperatur on heater 0 after switching can adress. It´s the second time in 1 month. Have you something similar?
        EDIT:
        minutes after I wrote you, this happened and destroyed my print. help to duet!!!! pleaase answer this time 2ff2aadf-9e0c-4032-8b5b-5f13267b98bd-image.png
        kdekid23undefined 1 Reply Last reply Reply Quote 0
        • kdekid23undefined
          kdekid23 @A Former User
          @gruna-studio Not sure if it helps - everything is okay in RRF 3.3. So I just revert the firmware on both boards back to 3.3 then it runs well.
            A Former User @kdekid23
            @kdekid23
            ok thanks for your reply!
            Are there some known issues?
            My fault came mid-print and when I change the tool can , it stays with the same toolboard.
            Thanks
            gloomyandyundefined 1 Reply Last reply Reply Quote 0
            • gloomyandyundefined
              gloomyandy @A Former User
              @gruna-studio It would probably help DC42 if you provide more information for him to work with. I think the following would be of help...
              1. Your config.g file
              2. The output from M122 when everything is OK and ideally again when your PT1000 is not working and the same for M122 B<xxx> but replace <xxx> with the CAN board number for your toolboard.
                3 Can you provide more details of what you mean by "when I change the tool can , it stays with the same toolboard" what did you change, what happened and what did you expect to happen?
              3. It looks like you have multiple tools? Are both tools using a toolboard? Do they both have a PT1000? Do you have problems on both boards or just on one?
              4. Can you provide more details about the problem you describe as "I also have the problem that I have no temperatur on heater 0 after switching can adress". It looks like heater 0 is your bed heater, did that really stop working when you changed the CAN address of your toolboard? Can you provide details of what exactly you did and what heppened?
              • kdekid23undefined
                kdekid23
                I just want to report that when I flash the firmware again on both boards, everything seems normal now. I will update here again if I see anything out of order.
                Just in case you need my M122:
                m122
                RepRapFirmware for Duet 3 MB6HC version 3.4.0rc2 (2022-02-22 17:04:17) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                Board ID: 08DJM-956BA-NA3TJ-6JTDD-3SD6L-KA9UT
                Used output buffers: 1 of 40 (26 max)
                Static ram: 150984
                Dynamic ram: 96080 of which 140 recycled
                Never used RAM 100468, free system stack 129 words
                Tasks: NETWORK(ready,23.9%,207) ETHERNET(notifyWait,0.2%,168) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,269) CanReceiv(notifyWait,0.0%,793) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,339) TMC(notifyWait,9.7%,58) MAIN(running,66.1%,925) IDLE(ready,0.0%,30), total 100.0%
                Owned mutexes:
                Last reset 00:03:14 ago, cause: software
                Last software reset at 2022-03-10 10:17, reason: User, GCodes spinning, available RAM 103468, slot 2
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                Error status: 0x00
                Step timer max interval 138
                MCU temperature: min 47.7, current 48.5, max 48.5
                Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/700/690, gc cycles 0
                Events: 0 queued, 0 completed
                Driver 0: pos 384000, standstill, SG min 0, mspos 74, reads 40263, writes 15 timeouts 0
                Driver 1: pos 0, standstill, SG min 0, mspos 808, reads 40263, writes 15 timeouts 0
                Driver 2: pos 64000, standstill, SG min 0, mspos 568, reads 40263, writes 15 timeouts 0
                Driver 3: pos 0, standstill, SG min 0, mspos 401, reads 40264, writes 15 timeouts 0
                Driver 4: pos 0, standstill, SG min 0, mspos 618, reads 40276, writes 3 timeouts 0
                Driver 5: pos 0, standstill, SG min 0, mspos 947, reads 40275, writes 3 timeouts 0
                Date/time: 2022-03-10 10:20:51
                Slowest loop: 11.28ms; fastest: 0.05ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 2.1ms, write time 0.0ms, max retries 0
                DMs created 125, segments created 6, maxWait 81202ms, bed compensation in use: none, comp offset 0.000
                === MainDDARing ===
                Scheduled moves 91, completed 91, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                === AuxDDARing ===
                Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is idle in state(s) 0
                Aux2 is idle in state(s) 0
                Code queue is empty
                === CAN ===
                Messages queued 1227, received 3694, lost 0, boc 0
                Longest wait 2ms for reply type 6013, peak Tx sync delay 18, free buffers 50 (min 49), ts 635/635/0
                Tx timeouts 0,0,0,0,0,0
                === Network ===
                Slowest loop: 24.33ms; fastest: 0.02ms
                HTTP sessions: 1 of 8
                - Ethernet -
                State: active
                Error counts: 0 0 0 0 0
                Socket states: 5 2 2 2 2 2 0 0
                M122 B121
                m122 b121
                Diagnostics for board 121:
                Duet TOOL1LC rev 1.1 or later firmware version 3.4.0rc2 (2022-02-22 10:15:02)
                Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
                All averaging filters OK
                Never used RAM 2624, free system stack 62 words
                Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,59) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,3.0%,57) MAIN(running,91.9%,335) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0%
                Last reset 00:03:48 ago, cause: software
                Last software reset data not available
                Driver 0: pos 0, 800.0 steps/mm,standstill, SG min 6, read errors 0, write errors 1, ifcnt 232, reads 48769, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
                Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                Peak sync jitter 3/7, peak Rx sync delay 213, resyncs 0/0, no step interrupt scheduled
                VIN voltage: min 23.9, current 23.9, max 23.9
                MCU temperature: min 43.7C, current 43.8C, max 44.2C
                Last sensors broadcast 0x00000002 found 1 172 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 4723, send timeouts 0, received 2159, lost 0, free buffers 37, min 37, error reg 0
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                Accelerometer: LIS3DH, status: 00
                I2C bus errors 0, naks 3, other errors 0
