    Duet 2 Maestro No Ethernet After Fault
    721
    • oracledudeundefined
      oracledude
      No activity lights, tried multiple cables. Set the IP via "M552 S1 P192.168.1.50" and I can't ping it, but on the PanelDue the M552 says network is enabled and the ip is the same.
        oracledude
        Here's something interesting I discovered while serial debugging....
        Anything in ***** is my comment
        With mains power...
        M115
        FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.4.0rc2 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2022-02-22 17:06:07
        ok
        M552
        Network is enabled, configured IP address: 192.168.1.50, actual IP address: 192.168.1.50
        ok
        M552 S0
        ***** App hung here for a second*****
        ***** USB dropped and reconnected *****
        M552
        M552
        M552
        ***** I had to disconnect and reconnect terminal to get any response*****
        M552 S1
        ok
        M552
        ok
        when it's powered just by USB...
        M115
        ok
        M552
        ok
        M552 S0
        M552   ***** No response *****
        M552
        M552 S1
        ***** terminal disconnects here, but allows reconnection ******
        M115
        ok
        M552
        ok
          oracledude
          Think I might be hosed and will need to use DSF with a Pi?
            Can you post some photos of the board? Is there any visible damage?
            Especially around the ethernet port?
            @oracledude said in Duet 2 Maestro No Ethernet After Fault:
            That's not really an option with a Maestro. Duet 3 only.
              oracledude
              This post is deleted!
                oracledude
                  dc42 administrators @oracledude
                  @oracledude most likely the W5500 Ethernet chip has failed. When there is a transient that causes the 3.3V rail to exceed its normal voltage, the first components to fail are usually the SD card and the W5500 chip.
                  The W5500 chip can be replaced, but it's not easy without the right equipment.
                  oracledudeundefined 1 Reply Last reply Reply Quote 0
                    oracledude @dc42
                    @dc42 No big deal, I've worked with smaller SMD packages before. WizNet W5500, 48LQFP. $4 at DigiKey. Beats having to buy another board, even if the Duet 3 Mini 5 looks really good.
                      oracledude
                      The IC should be here in the next few days. I'll let you know how it goes.
                        oracledude
                        So i soldered in a new W5500. Boots up fine, panelDue communicates fine with the board, but ethernet still is non-functional.
                        m552 s0
                        Network stopped<LF>ok<LF>
                        m552 s1
                        ok
                        m552
                        Network is enabled, configured IP address: 192.168.1.50, actual IP address: 192.168.1.50<LF>ok<LF>
                        m115
                        ok
                        There is no visible damage to anything on the board. I looked at it under magnification and nothing was burnt, cracked, or popped.
                        It's been sitting around for 4+ years with very sporadic use. Could just be "old". Maybe the head crash pushed some amps into the Atmel? I'm at a loss at this point.
                          That's too bad. Maybe @dc42 has some other ideas.
                            @oracledude if you set the M552 IP address to 0.0.0.0 does it succeed in acquiring an IP address via DHCP?
                              oracledude
                              Nope. No ethernet lights on the card or the network port.
                              Network is enabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
                                oracledude
                                @dc42 - any ideas? or just toast?
