    web interface won't connect
    Duet Web Control
    • didizundefined
      didiz
      I have 4 Duet 2 wifi and 3 of them connect to Wi fi without problem by the time I turn on the printers. One of them seems to be connected from the routers application but when I try to connect to web interface by putting the IP on the browser, it just does not connect saying this site can't be reached because it doesn't send any date.
      I rebooted the router and other ones connect with no issue.
      I had over voltage problem on the same duet before very randomly in the middle of a long print which did not repeat itself.
      didizundefined 1 Reply Last reply Reply Quote 0
      • didizundefined
        didiz @didiz
        @didiz just for info, after 20 minutes or so routers changes the IP and it is possible to connect. Each time it is the same.
          Are you using DHCP to give the Duets an IP address?
          Do you have a reservation set for each on the router so the address does not change?
          @didiz said in web interface won't connect:
          What exactly do you mean by this?
          • didizundefined
            didiz @Phaedrux
            @phaedrux yeah it is dynamic IP.
            No I do not have a reservation set however, I can see from my router software which IP address it gave to each printer.
            After 20 minutes or so, the IP address changes on the router software so probably there is a communication issue somewhere and with the new IP address I can connect to the printer.
            However, the problem occurs on one of the duets and always the same one.
              It sounds like there may be a DHCP collision. I suggest setting a reservation.
              If that doesn't resolve it, please provide a M122 from the Duet that is having trouble.
              • didizundefined
                didiz @Phaedrux
                @phaedrux Thanks a lot. I will do that.
