    MotionWebcamServer plugin - Missing library
    Beta Firmware
    1.8k
    • adammhaileundefined
      adammhaile @adammhaile
      @chrishamm
      So I found where that library lives:
      pi@rancor:~ $ ldconfig -p | grep libvchiq_arm
              libvchiq_arm.so (libc6,hard-float) => /opt/vc/lib/libvchiq_arm.so
      And I attempted to add that directory to my LD path for the dsf user:
      dsf@rancor:~ $ echo $LD_LIBRARY_PATH
      :/opt/vc/lib/
      But the plugin still fails with the same error - so seems to not care about LD_LIBRARY_PATH. Is there another way I can set the path for where to find libvchiq_arm for the plugin?
        adammhaile @chrishamm
        @chrishamm Is the actual source code for this plugin somwhere?
        All I can find is the binaries on Github: https://github.com/Duet3D/DSF-Plugins/tree/dev/MotionWebcamServer/dsf/arm
        Would love to dig into it more but hard to without the source.
        • chrishammundefined
          chrishamm administrators @adammhaile
          @adammhaile Do you mean this? https://github.com/Motion-Project/motion It's linked in the MotionWebcamServer README file.
          Duet software engineer
          adammhaileundefined 1 Reply Last reply Reply Quote 0
            @chrishamm Ah - sorry. I missed that it was really just as simple as you running a pre-existing thing.
            I'll look into it more from there - thanks!
            • luckyflyerundefined
              luckyflyer
              @adammhaile @chrishamm Any follow up on this? I've installed the plugin on 3.4 final with the same results that you had.
                adammhaile
                @luckyflyer Unfortunately, no - I have not been able to solve the problem.
                But glad it's not just me at least?
                Granted, I've also downloaded motion separately and was unable to get it to work... so it seems to be something wrong with the plugin per-se.
                I wonder if the DuetPi base image was updated recently and made incompatible with motion
                chrishammundefined 1 Reply Last reply Reply Quote -1
                  @adammhaile @luckyflyer Very odd, it looks like something changed because this definitely worked for me before on another image. The problem is indeed that motion cannot open /opt/vc/lib/libvchiq_arm.so. To fix this, you can edit /etc/apparmor.d/dsf.MotionWebcamServer and insert a new line below /usr/local/lib...:
                    /opt/vc/lib/** rm,
                  Then reboot the Pi or run sudo apparmor_parser -r /etc/apparmor.d/dsf.MotionWebcamServer and you should be able to start the plugin from DWC.
                    luckyflyer
                    @chrishamm I ssh into my pi and copy/paste
                    I get a permission denied message.
                      @luckyflyer you'll need to use sudo to edit the file.
                      sudo nano /etc/apparmor.d/dsf.MotionWebcamServer
                      Ctrl+O to save, Ctrl+X to exit once saved
                        luckyflyer
                        @adammhaile Thanks, I tried sudo but without nano but of course that didn't work either.
                          @luckyflyer why are you trying it without nano?
                          As @chrishamm said:
                          @chrishamm said in MotionWebcamServer plugin - Missing library:
                          This means you need to edit the file which is what nano does... you can't just "run" that file.
                            luckyflyer
                            I have the plugin running and have a grey screen that has a message in the top left corner "unable to open video device". I tried a different (known to work camera) with the same results. I ran lsusb and the ports see the camera. I'm using http://192.168.0.181:8081/0/stream Any ideas? Thanks
                              luckyflyer
                              Any ideas why the grey screen?
                                chrishamm administrators @luckyflyer
                                @luckyflyer Your error message says "Unable to open video device" so your webcam is probably not recognized by the Pi or you don't have access to it. Can you check if /dev/video0 exists? That's the default in the motion settings (see motion.conf in the System Files directory).
                                Please run sudo gpasswd -a dsf video and reboot your Pi. That should fix it.
                                MintyTreborundefined 1 Reply Last reply Reply Quote 0
                                • MintyTreborundefined
                                  MintyTrebor @chrishamm
                                  @chrishamm I have just enabled this plugin on a brand new clean duet image install on a pi4 with v3.4. The permissions issues described above were present on the included version of the plugin, and the fix previously posted did indeed work to enable the plugin to start.
                                  However the permissions issues seem to be deeper within the operations of the plugin.
                                  By default the plugin cannot access /dev/video*, neither can it create a log entry in the default logging folder set in the config file (when enabled). I changed the log folder to the tmp directory and I was able to see in the logs that motion was complaining it cannot access the video* device, which results in the grey screen shown in @luckyflyer post.
                                  To prove this is a permissions problem I changed the permissions of /dev/video0 in the terminal (chmod), and the plugin was able to start with video working correctly. I looked at
                                  and I can see there is an entry to set the access permissions to /dev/video* in the file, but this does not seem to be working as expected.
                                  --edit - I see you have updated your post since I started this one. I will try the proposed additional command....
                                  -- Update 2 - Additional command worked. Also I found adding the following line to the Live Stream Configuration Parameters section in motion.conf, improved the output framerate significantly :
                                  stream_maxrate 50
                                  NodeDSF - Native Node-Red integration with Duet boards.
                                  BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
                                  ReleaseMgr - Duet update info inside DWC.
                                  Repo
                                  MintyTreborundefined 1 Reply Last reply Reply Quote 1
                                    MintyTrebor @MintyTrebor
                                    If anyone is interested you can show the motion "control" web page inside DWC to allow you access / change some advanced video values (brightness, size etc) in a simple gui provided by motion:
                                    (you will need BtnCmd Plugin to do this)
                                    Set your motion config like below:
                                    & restart the plugin
                                    In BtnCmd add a remote source panel:
                                    And set the URL to http://[pi ip]:8080/ eg:
                                    Then resize to fit your screen and save the layout.
                                    Repo
                                    chrishammundefined adammhaileundefined 2 Replies Last reply Reply Quote 2
                                      chrishamm administrators @MintyTrebor
                                      @mintytrebor DWC lets you show the same content on the Jobs -> Webcam page if you check Embed webcam image in an iframe on the Settings -> General page and change the config + URL accordingly.
                                      PS: I'm rebuilding DuetPi to make the required changes from above obsolete. The next DSF version will fix it, too.
                                        Great. Thanks @chrishamm
                                        Repo
                                          luckyflyer
                                          @chrishamm, @MintyTrebor Thanks
                                            luckyflyer
                                            @chrishamm @MintyTrebor I would like to increase the frame rate. Could you help a Linux dummy out and give me the exact command to enter to change the frame rate. Thanks
