Bltouch z height offset problem
Hello
i am following this forum since long time but first time i open a treat.
i builded my own 3d printer and i am trying to make it run for the first time. (its very similar like CREALITY CR-10 S4)
i have installed bltouch and its working fine.
my only problem is i am trying to set z height offset but what ever i enter it dosent change anything and nozzle is always on the air.
This treat may be opened before but i couldnt find itbelow is my config file and bedg file
; Configuration file for Duet WiFi (firmware version 1.17)
; generated by RepRapFirmware Configuration Tool on Sun Oct 01 2017 12:43:57 GMT+0300 (Turkey Standard Time); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
G90 ; Send absolute coordinates…
M555 P2 ; Set firmware compatibility to look like Marlin
M208 X380 Y380 Z470 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S0 ; Define active high microswitches
M557 X50:330 Y50:330 S40 ; Define mesh grid; BL-Touch
M307 H3 A-1 C-1 D-1 ; reserve pin 21 for M42 or servo use
M558 P4 X0 Y0 Z1 H3 F200 T5000
G31 P25 X35 Y0 Z3.5 ; Set Z probe trigger value, offset and trigger height; Drives
M569 P0 S0 ; Drive 0 goes forwards
M569 P1 S0 ; Drive 1 goes forwards
M350 X32 Y32 Z32 E32 I1 ; Configure microstepping with interpolation
M92 X199 Y160 Z3197 E860 ; Set steps per mm
M566 X900 Y900 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
M203 X13500 Y13500 Z180 E2400 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z100 E1000 ; Set accelerations (mm/s^2)
M906 X1800 Y1800 Z1500 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M143 S260 ; Set maximum heater temperature to 260C
M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 1; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 PTEVO ; Set machine name
M551 Pakrepakrep ; Set password
M552 S1 ; Enable network
M587 SBosas-Laboratuvar P"B0s4A4s1234" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T50 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Custom settings are not configured
M501 ; Load saved parameters from non-volatile memoryBED G
; bed.g
; generated by RepRapFirmware Configuration Tool on Sun Oct 01 2017 12:43:04 GMT+0300 (Turkey Standard Time); Clear any bed transform
M561; Home all axes
G28; Deploy the mechanical Z probe
M98 Pdeployprobe.g; Probe the bed at 5 points
G30 P0 X50 Y50 H0 Z-99999
G30 P1 X50 Y330 H0 Z-99999
G30 P2 X330 Y330 H0 Z-99999
G30 P3 X330 Y50 H0 Z-99999
G30 P4 X190 Y190 H0 Z-99999 S
; Retract the mechanical Z probe
M98 Pretractprobe.g -
Use the Z parameter in the G31 command to set trigger height; but don't forget that if there is an M501 command in config.g then the value in config-override.g overrides the one in config.g. You can update the one in config-override.g by sending the appropriate G31 command (e.g. G31 Z3.0) followed by M500.
İ just adjusted and its working. İ just wonder can you check my firmware to see if there is a mistake. Mainly i need help in termistor section!
