Solved Duet 3 Mini 5+ Wifi problem
@asimitabi you need
M552 S0
before you try and send wifi details -
@jay_s_uk thanks for the fast reply!
I now did:
M552 S0 M587 S"WLAN-NAME" P"WLAN-PASSWORD" I192.168.1.15 M552 S1 P"WLAN-NAME"
but if I put in the IP in my browser nothing happens...
@asimitabi why not just send it over USB to get going?
@jay_s_uk The computer is a bit away from the machine and the machine is very heavy as its 500x500x750mm with enclosure. I cant bring them together here.
I thought this must work or do I need a specific IP?
@asimitabi Is the board actually on that IP address? Use an IP scanner to see, I use the free Advanced IP Scanner in Windows.
@stephen6309 Thank you I now tried to remove the IP-adress so it will find its own but it seems like the board is not connected to the wifi as the IP-scanner cant find the board
@asimitabi In YAT, sending M587 with no parameters shows the saved wifi networks in the wifi chip.
This has info on connecting wifi:
https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet -
@stephen6309 yes I know but I cant connect the computer right now via cable as its too far away...
If there isnt another option I will drive home and pick up my laptop to do it via cable. I just thought this must work normally
@asimitabi If you have a paneldue, it can be done via it's console.
I dont have the paneldue here but it works now, I took my laptop from home and made it normally via YAT.
Thank you guys for the fast answers!
Regards
