    CONSTANT AJAX disconnect errors
    307
    55.3k
    • KeeganBundefined
      KeeganB
      @Dougal1957:
      I have started to run into the dreaded AJAX Disconnect prob but have tracked it down to the router (Netgear D6400).
      It would disconnect after anything from 2-5 hours or so not actually timed it but seems like that Router is only 8 feet max away from the Duet and only Chipboard/plasterboard between them.
      Have plugged in my TP-Link TL720N in as an AP Extender and all is now good S I am now suspecting that some of the issues may well be the AP's in use but can't categorically confirm this.
      Duet is on 1.20A7
      Incidentally spent a few hours yesterday and Friday evening trying to get a friend of mine's Replikeo supplied Duet0.6 working and it came out the his Virgin Hub would not communicate with it at all plug it thru a TP-Link router that he had lying around and it came straight up again telling me that there are some flaky network routers out there.
      Just thoughts
      Doug
      Your thought on the APs is interesting. Currently I am running 1 Airport Extreme Base Station and 3 Airport expresses. 2 are set to extend the network, and the 3rd is just set to join the network (it handles a POE switch in my attic for security system).
      Tomorrow my new router will be here (Tenda AC18) and I will do away with all of the previous network hardware (except the attic stuff) and start the network from scratch.
      Artemis
      Rostock Max v2
      Orion
      • Jareryundefined
        Jarery
        I continue to have wifi connection issues.
        Disconnects mid print
        Disconnects when sitting idle
        Disconnects part way through a G32 calibrate routine.
        On a possibly related note. I happened to be watching the print screen right at the time prior to a disconnect.
        The temperature/time graph, which has a very straight line for temp, was suddenly going very jittery, such that the right side 1/4 of the line was suddenly 1/4" high of very compact squiggles as temp was read high/low.
        I was about to take a screenshot when it disconnected, and of course the histogram disappears…....
        I'm using a PT100 on a smart effector system. The temp line, when I'm actually connected and can see it, is typically very straight, maybe a minor bump every now and then. This was a solid couple of min (1/4 of the time line) where it was extremely erratic temp readings. Then a disconnect.
        May be related, maybe not, as it also disconnects in a calibration or idle when there is no temp.
          I'm sorry to hear that you are still having problems. See https://duet3d.com/wiki/WiFi_disconnections_and_AJAX_timeout_errors.
          The fluctuating temperature readings could indicate interference, or a power supply issue. Check that the VIN terminal block screws are tight (check the bed heater output terminals too).
          • Jareryundefined
            Jarery
            I have done everything in the wiki page linked
            My RSS is at -38, its not a wifi strength issue.
            I have now commissioned two printers, each with duet wifi. This issue is the same on both.
            Right now i would not recommend this board to anyone as its disconnection issue makes its use beyond frustrating and many of the "features" are missing if you only have connection through the PanelDue and not the browser.
            I would exchange them both for ethernet versions where I could hook them up to a router acting as a bridge, or a $20 travel router which is actually able to keep a connection.
              I'm sorry to hear that you are still having problems with staying connected. Are you running the latest stable version (1.19.2) of both DuetWiFiFirmware and DuetWiFiServer? Look on the Settings/General tabe of DWC to check.
              If you are running the latest versions, then it would be helpful for me to know the following:
              1. Does it disconnect when the printer is idle, or only when printing?
              2. When connection from the browser is lost, are you able to reconnect by pressing the Connect button?
              3. If you are not able to reconnect by pressing the Connect button, please send M552 or M122 from USB and let us know whether it says the wifi module is connected to the access point, or is idle.
              4. If it disconnects only during printing, please run M122 after a print and report the MaxReps value it prints. Note that MaxReps is cleared every time you run M122, so only the first time you run it after completing a print has any meaning.
              5. What do you have the Max Retries set to in DWC?
              • Jareryundefined
                Jarery
                Firmware Version: 1.19 (2017-08-14)
                WiFi Server Version: 1.19
                Web Interface Version: 1.19
                I've gone through all these with you previously in this or other threads..
                1. Disconnects when idle also
                2. Reconnect via "connect" button happens is 50/50. Never reconnects if pressed immediately. Sometimes if i let it print 5-10 min it will reconnect vie connect button. Majority of time it does not
                3. Will check this next time i try a print . (unable to currently due to odd probing behaviour, separate thread in smart effector section)
                4. I've posted the maxreps previously, i recall it was single digits, 5 or so.
                50 max retries is set to 3. Ive also tried 5 and 10.
                  Please upgrade to firmware 1.19.2 (both DuetWiFiFirmware and DuetWiFiServer). The WiFi module should have reconnected automatically if connection to the access point it lost, because that's what the manufacturer's firmware is configured to do. But during testing, I found it unreliable. So our own firmware now does a separate reconnect if that one fails.
                  The M122 report includes the number of reconnections done.
                  • Jareryundefined
                    Jarery
                    Downloaded files from here :
                    https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-WiFi/Stable
                    Location is from the wiki page..
                    Uploaded. Both report the exact same as before…
                    Are these 1.19.2 files hidden somewhere ?
                    Found them after searching the forum for the link
                    https://github.com/dc42/RepRapFirmware/releases/tag/v1.19.2
                    Maybe update the wiki page to the link, right now it goes to 1.19
                      Latest stable releases are now always at https://github.com/dc42/RepRapFirmware/releases. Which wiki page links to 1.19 ?
                      • Jareryundefined
                        Jarery
                        https://duet3d.com/wiki/Updating_main_firmware
                        Check you have [downloaded the correct firmware](downloaded the correct firmware) before installing it. The DuetWiFiFirmware.bin file should be the same size as shown on the github (currently about 300 KB in size).
                        Installed 19.2
                        ran a print, 5 min in it disconnected:
                        Didn't reconnect on its own but did with a repress of "connect button"
                        MaxReps: 5, StepErrors: 0, FreeDm: 123, MinFreeDm 120, MaxWait: 9ms, Underruns: 0, 0
                        Scheduled moves: 25067, completed moves: 25037
                        Bed compensation in use: mesh
                        Network state is running
                        WiFi firmware version 1.19.2
                        WiFi MAC address a0:20:a6:10:55:89
                        WiFi Vcc 3.17, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 39000
                        WiFi IP address 192.168.2.32
                        WiFi signal strength -52dBm
                        Reconnections 0
                        HTTP sessions: 1 of 8
                        Socket states: 2 0 0 0 0 0 0 0
                        Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                        • Jareryundefined
                          Jarery
                          Mid print, system has disconnected for second time.
                          M155 from PanelDue states:
                          "WIFI module is connected to access point xxxxxx, ip address 192.168.2.32"
                            Are you still able to ping the IP address of the Duet? If not, are you able to confirm on the status page of your router that the router agrees that the Duet is still connected?
                            • Jareryundefined
                              Jarery
                              PING 192.168.2.32 (192.168.2.32): 56 data bytes
                              –- 192.168.2.32 ping statistics ---
                              5 packets transmitted, 0 packets received, 100% packet loss
                              M552 on panel shows as still connected to access point.
                              So it disconnects from router but thinks its still connected
                                Thanks. Does your router still think it is connected, or not? You will need to login to the admin page of your router from your browser to find out.
                                • Jareryundefined
                                  Jarery
                                  Router believes its dropped and no longer shows it on the client list.
                                  M552 shows it still connected
                                  • KeeganBundefined
                                    KeeganB
                                    This looks like good info Jarery. Thanks!
                                    I just finished configuring my new router, so now I am testing the first print on a completely new network. (I started from scratch)
                                    Artemis
                                    Rostock Max v2
                                    Orion
                                    • KeeganBundefined
                                      KeeganB
                                      Dare I say it?
                                      24mins into a print and no disconnects, this is a record for me.
                                      Ill be kicking myself if it was some network quirk on my network.
                                      Artemis
                                      Rostock Max v2
                                      Orion
                                      • JohnOCFIIundefined
                                        JohnOCFII
                                        @KeeganB:
                                        Dare I say it?
                                        Hopefully it'll fix things for you. If it does, though, that begs the question of what is different about the WiFi board on the Duet Wifi (or it's firmware) in comparison to the other devices on your WiFi network that (I assume) continued to work well when the DuetWiFi was having issues.
                                        I haven't yet upgraded past 1.18.2 yet. I used to have regular timeouts when I connected to the printer via it's DNS entry. Someone here suggested I connect to it via IP address, and it has been much more stable for me that way. I do still get the occasional disconnect, usually after a print has been completed and the system has been idle for 10 or more minutes.
                                        John
                                        • KeeganBundefined
                                          KeeganB
                                          Yeah, that will be the odd part. All my other devices have been perfectly fine. This includes several devices set up for remote access, via ports and etc, wireless printers, mobile devices, airplay stuff, etc…
                                          My network hardware was getting pretty old, and I had been considering an upgrade so this was as good a time as any.
                                          Print finished in 50 mins and I'm still connected. 2 hours of connection: 50mins print, and 70 mins idle. This is feeling pretty good.
                                          Artemis
                                          Rostock Max v2
                                          Orion
                                            @Jarery:
                                            Thanks, that's very useful information. It sounds like we can't trust the status call of the ESP8266 SDK to tell us whether the WiFi is still connected to the AP. This is going to be a problem for us because the SDK is closed source. We may need to ping the router regularly to determine whether the connection is still alive.
                                            Please confirm that you are running version 1.19.2 of both DuetWiFiFirmware and DuetWiFiServer, by looking at the Settings/General tab in DWC.
