    Duet 2 Wifi + 24V Laser
    Laser Cutters
    • knicklichtundefined
      knicklicht
      Hello all,
      I have long been an avid Duet3d user. The documentation is great and as such I rarely had any issues with my 3d printer. I am using a 24V power supply and want to add a 24V laser module, e.g. https://ortur.net/products/ortur-lu2-4-lf-laser-module-24v-2a-for-laser-master-2-pro-aufero-laser-1. I found the documentation on "Laser PWM control" (https://duet3d.dozuki.com/Wiki/Laser_PWM_control). I have a Duet 2 Wifi and will need to build the PWM circuit, however it assumes a 12V laser. Is the design also compatible with a 24V laser module? I would think so since the 12V input is only routed to the laser module itself, but I want to be sure.
      Thanks
        droftarts administrators @knicklicht
        @knicklicht Looking at the page about the laser, I'm pretty sure you supply 24V to it, and then control it with a PWM signal. However, there's no manual or details on the page what the control signal is. Email them for more details.
        • chimaeraghundefined
          chimaeragh
          Did you make any progress with this? I am getting a 24v laser diode too and was wondering if it was possible.
          Duet 2 Wifi, Ooznest Workbee CNC 1510
