    1XDs- Expansion boards not functioning
    Purchasing
    452
    • user M_123undefined
      user M_123
      hey,
      During SW flash, it was found that 2 of the 1XDs- Expansion boards are not functioning.
      1) The Red - status LED does not glow at all, on providing power and CAN signals.image006.jpg
      2) does not communicate at all at default 122- CAN address.
      & i also try with B120 ,B121 but its not working.
      @dc42 @T3P3Tony can you replace the boards?
        And you found that the same wiring, etc was working correctly with other boards?
        When and where did you purchase them?
        user M_123undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          user M_123 @Phaedrux
          @phaedrux said in 1XDs- Expansion boards not functioning:
          yes
          around one & half month ago.
          From Duet3d.
            Phaedrux Moderator @Phaedrux
            This post is deleted!
              Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
              user M_123undefined 1 Reply Last reply Reply Quote 0
                dc42 administrators @user M_123
                For future reference: if the Status LED on a 1XD board or older revision tool board doesn't flash at all, this usually means that the bootloader has failed to start up. Sometimes it will start up and communicate if it is left powered up and connected for long enough; then the bootloader can be updated to fix the problem.
                The other way to fix the problem is to upgrade the bootloader using a Atmel ICE. This is not something we would expect our end users to have, however some of our resellers may have one.
                  user M_123
                  @dc42 I did as mentioned in this link but it doesn't work.
                  https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_bootloader
                    @phaedrux okay thank you.
