Duet 2 Thermistor shows 2000 dagrees
My current Temperature is at Tool 0 (Hotend) and Bed on 2000 dagrees. I already switch the wires but it still not work. What can i do?
Hotend is an "3DFreunde V6 Clone)
And Bed is an SiliconeAnd where i can changes the points of probe with BLTOUCH original? in the Firmware
here is my config.g
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Apr 04 2022 20:14:28 GMT+0200 (Mitteleuropäische Sommerzeit); General preferences
M550 P"My Printer" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M201 X800.00 Y800.00 Z800.00 E500.00 ; set accelerations (mm/s^2)
M208 X300 Y300 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F300 T6000 ; set Z probe type to bltouch and the dive height + speeds
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0CM307 H3 A-1 C-1 D-1
M558 P9 H5 F100 T2000
G31 X19 Y0 Z0 P25; Custom settings are not definedM950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H1 F1000 T9000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X45 Y0 Z2.399 ; set Z probe trigger value, offset and trigger height -
@robiiinx said in Duet 2 Thermistor shows 2000 dagrees:
Can you be more specific in what you want to do?
Are both bed and hotend temps showing 2000c?
How are the connected? Can you show a photo? Are you sure they are thermistors?
