    Issues with the BLTouch
    2.0k
    • Biggsisundefined
      Biggsis
      So I have an original BLTouch connected to my Wifi for some weeks now, the BLTouch is used as the Z-Endstop too.
      It is basically working, but a lot of times when Z homing in the beginning if a print job, the BLTouch pin is just not lowering, but instead the BLTouch goes into error condition and is blinking.
      I reset the BLTouch then and try again, but same thing, it goes into error conditon. If I move the pin by hand a couple of times up and down and then give the M401 / M402 command manually a couple of times, then the Z Homing is working. That is very annoying, so maybe somebody knows a solution too this?
      I have the latest BLTouch with serial number on it, so no resistor needed and I cut the bridge on the logic board of the BLTouch like stated in the Antlabs manual. The BLTouch is connected as Heater 3 to the Duet
      My config.g for the BLTouch is this:
      [[language]]
      ;Heater
      M307 H3 A-1 C-1 D-1 ; Heater 3 reserved for BLTouch
      ;Lines for BLTouch
      M558 P5 X0 Y0 Z1 H5 F120 T2000
      G31 X40 Y5 Z0.68 P25
      and my homez.g is this:
      [[language]]
      G91
      G1 Z5 F200
      G90
      G1 X141 Y100 F2000
      M400
      M401 ;Deploy probe
      G30 ;Find Z
      M402 ;Retract probe
      G1 Z5 F200
      I am using M280 P3 S10 I1 for deployprobe.g and M280 P3 S90 I1 for retractprobe.g. I think i did all things according to the Wiki connecting a Z-probe to the Duet. Still have this annoying problem.
      Thanks for your time…
      Hypercube Evolution User Group : https://www.facebook.com/groups/Hypercubeevolution/
      Kossel Delta XL / XXL User Group : [https://www.facebook.com/groups/KosselXXL/]
        What does the bltouch manual say are the causes of it going into an error condition?
        • Jareryundefined
          Jarery
          I have a BLTouch that exhibits the exact same behaviour. I have to pull the pin out at least once before it will start to act correctly.
          Never found a solution.
          • cooliceundefined
            coolice
            Hey guys.
            Just an idea, but have you taken the grub screw out the back and checked/cleaned the pin?
            I didn't have this issue with mine, but had to check and reset the bltouch this way as I was convinced it wasn't retracting quite far enough to stay retracted at times.
            So far so good since I took it apart, but mine is a clone so probably not made the best.
            It could be there is some debris in there maybe stopping the pin working smoothly, or the heat shrinked section at the back is catching. As it relies on a magnetic field to move the touch pin in and out, any increased friction won't help it work smoothly. But also from what I'd read, the rear portion needs to be within the right band for the magnetic field to work properly at extending and retracting the pin.
            • Biggsisundefined
              Biggsis
              David, the BLTouch "Manual" is a 2 page PDF that does not say anything about any error conditions.
              https://docs.wixstatic.com/ugd/f5a1c8_6f2b1ea5daf74a3c85967f2be7848cf0.pdf is pretty much it.
              The BLTouch just starts to blink, if something is wrong, but does not say why.
              • Biggsisundefined
                Biggsis
                And coolice, my BLTouch is brand new, I inspected it, there is no dirt or whatsoever in it, it CAN move freely, just doesnt.
                • Jareryundefined
                  Jarery
                  There is an adjustment, that's supposed to factory set at 0.3 mm, but can still be user changed. Its the height of the grub screw. Changing it will vary the amount of magnetic force applied to the core.
                  https://docs.wixstatic.com/ugd/f5a1c8_dfdac6d7ab1745f78320953d662cc0f6.pdf
                  Dimension should be at 0.3mm. It will be my next action to fix it, just have not had time.
                  • Forgvn77undefined
                    Forgvn77
                    Yup, I have the exact same problem. I move the pin manually up and down a few times and it's fixed… until it happens again. I will have to see about the grub screw.
                    Velleman K8200, Geeetech G2S Pro (x2), Geeetech Rostock 301 retrofitted with Duet
                    Make A Difference!
                    • cooliceundefined
                      coolice
                      @Biggsis:
                      Ah cool. Well as I mentioned and with the link posted above, it might be worth checking the grub screw height/set point.
                      I'm sure mine wasn't set correctly so the magnetic field wasn't driving the pin correctly.
                      • greecherundefined
                        greecher
                        I've had the occasional problem with this also, but for me, I put them mostly on the duet misbehaving, or me,as it only seemed to happen when I turned on the machine, and a clean power cycle cleaned it up. I really haven't had an issue since I finished up my wiring, and I've never seen it fault through multiple prints.
