    Update failed - not in Paneldue mode
    PanelDue
    • Michael Subergundefined
      Michael Suberg
      Hello everyone, after I was able to bring my board back to life with Bossa and the latest FW 3.4 update is now running, I wanted to update the Paneldue V3 5" last but not least.
      Unfortunately I get the message: M997: Aux Port 0 is not enable or not in Paneldue mode.
      What do I have to do to be able to install the latest update?
        dc42 administrators @Michael Suberg
        @michael-suberg check that your config.g file contains the correct M575 command to support PanelDue.
          The PanelDue firmware may also be too old to allow update from the duet. What version does it show in the settings page? You may need to update it once manually using bossa before you are able to update it directly from the Duet.
          https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
