    Duet 2 Wifi heat till 195 dagrees then nothing
    483
    • RobiiinXundefined
      RobiiinX
      Hello, I buy a 24v heater for my hotend. I dont change anything in my conifg. All of my components are 24v components. It heats only till 195 dagrees and then it says temperature target not reached.
      Here is my config. I have an 3D Freunde 24V Hotend and an 100k Thermistor:
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Apr 04 2022 20:14:28 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"My Printer" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P2 S0 ; physical drive 2 goes backwards
      M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
      M201 X800.00 Y800.00 Z800.00 E500.00 ; set accelerations (mm/s^2)
      M84 S30 ; Set idle timeout
      M208 X300 Y300 Z300 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F300 T6000 ; set Z probe type to bltouch and the dive height + speeds
      M557 X15:300 Y15:300 S20 ; define mesh grid
      M308 S1 P"e0temp" Y"thermistor" T1000 B3950 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      ;THERMISTORS
      M305 P0 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
      M305 P1 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set first nozzle thermistor ADC correction
      M305 P2 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set 2nd nozzle thermistor ADC correction
      ;BLTOUCH
      M307 H3 A-1 C-1 D-1
      M558 P9 H5 F100 T2000
      G31 X19 Y0 Z0 P25; Custom settings are not defined
      Stephen6309undefined RobiiinXundefined 2 Replies Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @RobiiinX
        @robiiinx You need to run a PID tuning for the heater as a tool.
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Heaters_tuning
        Add M501 to the end of config.g, and after the tuning, do a M500 to save it.
        • RobiiinXundefined
          RobiiinX @RobiiinX
          @Stephen6309 I make a PID tuning. I write
          "M303 H1 S240". At 198 dagrees it says "Auto tune cancelled because target temperature was not reached"
          In your Link they say i must write "M303 T0 S205" but it says "Heater 1 tuning failed"
          I dont know what i should do.
          I make a PID tuning at 190 dagrees. And I saved it. After that I try to heat on 205 but it says "heating fault on heater 1, temperature rising much more slowly than the expected 1.0°c/sec"
            @robiiinx Is is actually getting 24v and the heater has the correct resistance for 24v.
            Using T0 for the pid, takes the parts cooling fan into acount for heating and H1 is the heater for T0.
            Typical heater resistance;
            12V 20W -> ~ 7.2 Ω
            12V 30W -> ~ 4.8 Ω
            12V 40W -> ~ 3.6 Ω
            24V 20W -> ~ 28.8 Ω
            24V 30W -> ~ 19.2 Ω
            24V 40W -> ~ 14.4 Ω
            • RobiiinXundefined
              RobiiinX @RobiiinX
              @Stephen6309 Where i have to write that on my config.g?
                @robiiinx Write what? Those resistances are used with a multimeter to verify the that heater core is what it says it is.
                • RobiiinXundefined
                  RobiiinX @RobiiinX
                  @Stephen6309 it says 14,4 Ω
                  Stephen6309undefined dc42undefined 2 Replies Last reply Reply Quote 0
                    @robiiinx Check the voltage when the heater is on, it should be 24v. Otherwise, I don't know what's going on.
                      dc42 administrators @RobiiinX
                      @robiiinx what type of hot end is it? If it's an E3Dv6 or similar, check that there is a gap between the heater block and the heatsink.
                      RobiiinXundefined 1 Reply Last reply Reply Quote 0
                      • RobiiinXundefined
                        RobiiinX @dc42
                        @dc42 its an e3dv6 clone from „3DFreunde“
                          Photo of the hotend?
                          • silver1882undefined
                            silver1882
                            Also you may check that the fan you are using for you heatsink isn't blowing to hard, I was having that problem with my dual head setup. Slowed the fan down and then redid the pid tunning and now both heads work fine.
