    Inquiry about board version (M32 error message)
    Duet Web Control
    450
    • geon han_Kangundefined
      geon han_Kang
      Hello.
      I am a user who is using duet 3d 6HC.
      While making a 3D printer this time, one board was upgraded from 3.3 to 3.4.
      Other 3D printers worked well in 3.3 versions
      The 3.4 version does not upload g-code files. With an M32 error message.
        It looks like the file you are trying to upload is the same name as a file that is currently being processed. Try a different name or stop the print?
        geon han_Kangundefined 1 Reply Last reply Reply Quote 0
          geon han_Kang @Phaedrux
          @phaedrux
          Thank you. 🙂
          Renamed and executed, but the same result.
          I think we need to downgrade the board to 3.3
          Do you know how to do it?
          • Macgyverundefined
            Macgyver
            wonder if there is a temp file or Cache that has not cleared itself correctly?
              Are you using standalone or with a RPi?
                @phaedrux this is RPI
                  geon han_Kang @Macgyver
                  @macgyver
                  Immediately after uploading the board firmware.(Cache, no temporary files) );
                    dc42 administrators @geon han_Kang
                    @geon-han_kang it may be that you are still running the 3.3 version of Duet Software Framework on the Pi. How did you do the firmware update?
                      Can you send M122 in the gcode console and post the results here?
                      Updating the firmware when using the Pi requires you to use sudo apt update sudo apt upgrade from the pi console.
                        geon han_Kang @dc42
                        did not upgrade);
                        After receiving the board, it was 3.4 as a result.
                        I think I received the upgraded version.
                          @phaedrux
                          what means 'sudo apt update'?
                            Phaedrux Moderator @geon han_Kang
                            @geon-han_kang said in Inquiry about board version (M32 error message):
                            These are the commands used on a raspberry pi operating system to update the software on it. It will also update the duet software and firmware.
                            Can you please send M122 and M98 P"config.g" in the gcode console and copy and paste the text results here?
