    Filament Sensor Error reported while not printing from SD
    Using Duet Controllers
    • floblerundefined
      flobler
      Hi all,
      I have a filament sensor configured for my Prusa Bear MK3s (Duet 3 Mini 5+; RRF 3.4.0; DWC 3.4.0):
      M591 D0 P2 C"io3.in" S1                    ; configure filament sensor for extruder drive 0 on pin io3.in and turn it on
      Here is my config.g:
      ; config.g
      ; Duet 3 Mini 5+
      ; RRF Version BUILD_VARIABLE_RRF_VERSION
      ; Bear Configuration BUILD_VARIABLE_BEAR_CONFIG_VERSION
      ; Description:
      ;  	- main configuration file
      ;	- executed on start-up
      ; General Preferences
      G90                                        ; absolute positioning
      M83                                        ; extruder relative positioning
      M550 P"duet-bear"                          ; set printer name
      if {network.interfaces[0].type = "ethernet"} ; network type = ethernet
          M552 P0.0.0.0 S1                         ; enable network and acquire dynamic address via DHCP
      else                                         ; network type = wifi
          M552 S1                                  ; enable network
      M569 P0.0 D3 V10 S0                        ; physical drive 0.0 goes backwards / Z-left  / reduced V parameter to enable stealthChop
      M569 P0.1 D3 V10 S0                        ; physical drive 0.1 goes backwards / Z-right / reduced V parameter to enable stealthChop
      M569 P0.2 D3 S1                            ; physical drive 0.2 goes forwards  / Y
      M569 P0.3 D3 S0                            ; physical drive 0.3 goes backwards / X
      M569 P0.4 D3 S1                            ; physical drive 0.4 goes forwards  / E
      M584 X0.3 Y0.2 Z0.0:0.1 E0.4               ; set drive mapping
      M671 X-36.5:293.5 Y0:0                     ; define lead screw positions
      M350 X32 Y32 Z32 E64 I1                    ; configure microstepping with interpolation
      M92 X200.00 Y200.00 Z800.00 E1660.00       ; set steps per mm
      M566 X480.00 Y480.00 Z48.00 E300.00        ; set maximum instantaneous speed changes (mm/min)
      M203 X24000.00 Y24000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X4000.00 Y4000.00 Z1000.00 E1500.00   ; set accelerations (mm/s^2)
      M906 X490 Y490 Z490 E400 I40               ; set motor currents (mA) and motor idle factor in per cent
      M84 S60                                    ; set idle timeout
      M564 H0 S1                                 ; allow unhomed movement and forbid axis movement outside defined limits
      M208 X0 Y-4 Z0 S1                          ; set axis minima
      M208 X250 Y212.5 Z210 S0                   ; set axis maxima
      M574 X1 S3                                 ; configure sensorless endstop for low end on X
      M574 Y1 S3                                 ; configure sensorless endstop for low end on Y
      M915 X S3 F0 H200 R0                       ; set the X axis sensitivity
      M915 Y S3 F0 H200 R0                       ; set the Y axis sensitivity
      M558 P5 C"^io2.in" H5 F500 T10000 A1       ; set Z probe type to switch on pin io2.in, dive height + speed, travel speeds and number of probes
      G31 P1000 X23 Y5 Z0                        ; set Z probe trigger value, offset and trigger height
      M557 X24:228 Y6:208 P7:7                   ; define mesh grid
      ; Bed Heater
      M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 A"Bed"    ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" Q50 T0                                          ; create bed heater output on out0 and map it to sensor 0, PWM frequency 50Hz
      M307 H0 B0 S1.00                                                ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                         ; map heated bed to heater 0
      M143 H0 S110                                                    ; set temperature limit for heater 0 to 110°C
      ; Hotend Heater
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 A"Nozzle" ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                              ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                                                ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S300                                                    ; set temperature limit for heater 1 to 300°C
      ; PID Parameters (replaced by parameters stored in config-override.g once auto-tuning has been completed)
      M307 H0 R0.272 C450.420:450.420 D11.34 S1.00 V24 B0 I0          ; default heater model parameters bed
      M307 H1 R4.253 C178.556:93.430 D2.87 S1.00 V24 B0 I0            ; default heater model parameters hotend
      ; Part Cooling Fan
      M950 F0 C"out5" Q500                       ; create fan 0 on pin out5 and set its frequency
      M106 P0 C"Part Cooling" S0 H-1             ; set fan 0 name and value. Thermostatic control is turned off
      ; Hotend Fan
      M950 F1 C"out3" Q500                       ; create fan 1 on pin !out3 and set its frequency
      M106 P1 C"Hotend" S1 H1 T50                ; set fan 1 name and value, thermostatic control is turned on
      ; Case Fan
      M950 F2 C"out6" Q500                       ; create fan 2 on pin out6 and set its frequency
      M106 P2 C"Case" S1 H1 T50                  ; set fan 2 name and value, thermostatic control is turned on
      M563 P0 D0 H1 F0                           ; define tool 0
      G10 P0 X0 Y0 Z0                            ; set tool 0 axis offsets
      G10 P0 R0 S0                               ; set initial tool 0 active and standby temperatures to 0°C
      M302 S180 R180                             ; allow extrusion and retraction starting at 180°C
      ; Global Variables
      ; Filament Temperatures
      global abs_hotend_temp = 240               ; global ABS hotend temperature variable
      global abs_bed_temp = 110                  ; global ABS bed temperature variable
      global greentecpro_hotend_temp = 230       ; global GreenTec Pro hotend temperature variable
      global greentecpro_bed_temp = 60           ; GreenTec Pro bed temperature
      global pc_hotend_temp = 270                ; global GreenTec Pro hotend temperature variable
      global pc_bed_temp = 110                   ; global GreenTec Pro bed temperature variable
      global petg_hotend_temp = 235              ; global PETG hotend temperature variable
      global petg_bed_temp = 80                  ; global PETG bed temperature variable
      global pla_hotend_temp = 210               ; global PLA hotend temperature variable
      global pla_bed_temp = 60                   ; global PLA bed temperature variable
      global tpu_hotend_temp = 230               ; global TPU hotend temperature variable
      global tpu_bed_temp = 60                   ; global TPU bed temperature variable
      M575 P1 S1 B57600                          ; enable support for PanelDue
      M501                                       ; load saved parameters from non-volatile memory
      T0                                         ; select tool 0
      The problem I am facing right now is that I get a filament error reported even when I am not printing from SD card. So when I power up the printer and no filament is loaded, I get the following message:
      Error: Filament error on extruder 0: noFilament
      The message alone would not be a big problem (still feels misplaced though) but I have some macros where I am unloading filament first (like for PID tuning). Once I unloaded the filament, I get the above error and the macro is interrupted and won't continue without manually triggering it again.
      Am I doing something wrong? My understanding is that the error should only be reported/or interrupt when the printer is actually printing from SD card.
      floblerundefined Stephen6309undefined 2 Replies Last reply Reply Quote 0
      • floblerundefined
        flobler @flobler
        Here is the PID tuning macro I am currently using for the nozzle as example:
        ; PID Nozzle
        ; Description:
        ; 	- macro file
        ; 	- PID tuning routine for the nozzle
        ; 	- unloads filament before PID tuning
        ; 	- PID tuning will approx. take 5 minutes
        ; 	- do not leave printer unattended
        ; Preparation
        M291 P"PID tuning the NOZZLE will take approx. 5 minutes!" S2 R"PID NOZZLE"                    ; requires user acknowledgement
        M291 P"Do NOT leave the printer unattended during the calibration procedure!" S2 R"PID NOZZLE" ; requires user acknowledgement
        M702        ; unloads currently assigned filament
        if heat.heaters[1].current > 50                 ; if hotend temperature is > 50°C
        	M568 S0                                     ; turn off hotend heater
        	M140 S0                                     ; turn off bed heater
        	M106 S1                                     ; turn on part cooling fan at 100%
        	M291 P"Cooling HOTEND to below 50°C!" S1 T0 ; message to inform that hotend is cooling down
        while heat.heaters[1].current > 50              ; as long as hotend temperature is > 50°C
        	G4 S3                                       ; wait 3 seconds, then read hotend temperature again, repeats until hotend temperature is =< 50°C
        M107                                            ; turn off part cooling fan
        ; PID Nozzle
        ; Touning Routine
        M291 P"Do you want to start the PID tuning routine for the NOZZLE at 230°C?" S3 R"PID NOZZLE" ; requires user input
        if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed                          ; if not all axes are homed
          G28        ; home all axes
        G1 X{move.axes[0].max/2} Y{move.axes[1].max/2} Z50                                            ; move X and Y axis to their center, lift Z axis 50mm above the bed
        M303 T0 S230        ; perform PID tuning routine for tool 0 at 230°C
        while heat.heaters[1].state = "tuning"                                                        ; while the tuning procedure is active
        	M291 P"Tuning..." S1 T0 R"PID NOZZLE"                                                     ; message confirming that tuning is in progress
        	G4 S15        ; wait for 15 seconds, then check for tuning status again until tuning procedure is finished
        ; Storing Results
        M307 H1        ; report PID tuning values for the hotend heater
        M500 P31        ; save results to config-override.g
        M104 S0        ; turn off hotend heater
        M291 P"PID tuning for the NOZZLE complete! Values are saved." S2 R"PID NOZZLE"                ; requires user acknowledgement
        The error appears after the M702 in line 19 and the macro does not continue after
        • Stephen6309undefined
          Stephen6309 @flobler
          @flobler Activate the filament sensor only when printing.
          One way to do it:
          Configure it using S0, I have it in the config.g. In your start .g use M591 S1, and in cancel.g and stop.g use M591 S0.
          floblerundefined 1 Reply Last reply Reply Quote 1
          • floblerundefined
            flobler @Stephen6309
            @stephen6309 Thank you, I will try this!
            But in the end, should it not only report errors while printing anyway? I thought S1 would configure it for that according to: https://docs.duet3d.com/User_manual/Reference/Gcodes#m591-configure-filament-sensing
            Stephen6309undefined 1 Reply Last reply Reply Quote 0
              @flobler When running a gcode file on the sd, it's processing, which is the same as printing.
              • floblerundefined
                @stephen6309 that makes sense, I assumed there would be a different between the status "printing" and other things the printer is busy with.
                Thank you for your help, I assume what you suggested will solve my problem but I'll still update here once Itested this 🙂
                • floblerundefined
                  flobler
                  This fixed my issue, thank you for your help @Stephen6309!
                  • dc42undefined dc42 marked this topic as a question
                  • dc42undefined dc42 has marked this topic as solved
