    Formbot 400
    Firmware installation
    849
      You need a corresponding M950 command to create the pin that the M42 command then controls.
      An example of such a combinations from your config is the fans
      ; --- Case Fan ---
      M950 P5 C"duex.fan7"
      M42 P5 S0.0 ;
      What is your air filtration macro actually controlling?
      UnknowXundefined 1 Reply Last reply Reply Quote 0
      • UnknowXundefined
        UnknowX @Phaedrux
        @phaedrux said in Formbot 400:
        command
        It's controlling a huge fan at the back of the printer to filter air with different spin percentages from 20% to 50% to 80 to 100.
          Seems weird to use a fan with M42 instead of M106. I'm not sure what the reason to do that would be.
          At any rate, you'd still need an M950 command that creates the pin for M42 to use.
          What port is the fan actually connected to on the board?
          • UnknowXundefined
            UnknowX @Phaedrux
            @phaedrux well I don't know but I have the settings that worked with reprap 2.0 below it shows what pin it is connected to but how can I configure this in my macro settings just copy and past from 2.0 to 3.0
            ;; Convenience macro to make this script be a button on the UI,
            ;; for cases when the built-in filament load/unload UI won't work.
            ;; NOTE you still need to have the tool selected before running this macro
            ;; or you'll get errors.
            M42 P5 S1.0
              Phaedrux Moderator @UnknowX
              @unknowx said in Formbot 400:
              well I don't know
              You don't know where it's physically plugged into the board?
              • UnknowXundefined
                UnknowX @Phaedrux
                @phaedrux well no because I didn't open to see the board but the old macro config that worked fine states p5 so it must be port 5
                  Is it this one?
                  ; --- Case Fan ---
                  M42 P5 S0.0 ;
                  If that's where it's physically connected then your air filter macro needs to change to 5.
                  Either way, we need a pin name, like this C"duex.fan7"
                  • UnknowXundefined
                    UnknowX @Phaedrux
                    @phaedrux well below is the config for reprap 2.0 which was working fine and the fan name and pin is the same but for reprap 3.0 it's not working see below
                    Phaedruxundefined UnknowXundefined 2 Replies Last reply Reply Quote 0
                      And if you were using a normal Duet board I might be able to guess what it is.
                      • UnknowXundefined
                        UnknowX @UnknowX
                        @unknowx I think I know what the issue is if you agree with me I think I have to remove the semi colon to activate it right?
                          which semi colon?
                          • UnknowXundefined
                            UnknowX @Phaedrux
                            @phaedrux this one I'll market it before the command if you see the first config attached for reprap 2.0 the semicolons are removed to activate the command but the second config for reprap 3.0 the semicolons are there not removed.
                            • UnknowXundefined
                              UnknowX @UnknowX
                              @unknowx actually I am wrong g sorry the case fan is different t from controller fan my bad anyways still don't know why
                                Well we just need to know where the cable is physically connected. Perhaps it's labeled or next to a port that's already in use and configured and we can suss out the pin name that way.
                                The semi colon blocks out everything after it only.
