Error: failed to enable endstops
I have a router which does not have endstops. In my config.g file generator I had selected no endstops. Now when I upload a gcode file in Jobs it gives out an error 'Failed to enable endstops'.I want to use duet 3 without endstops how can I do it.....
heres my config file:
; Configuration file for Duet 3 (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Apr 29 2022 11:01:24 GMT+0200 (Central European Summer Time); General preferences
M550 P"Duet 3" ; set printer name; Drives
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E305.00 ; set steps per mm
M208 X-150 Y-150 Z0 S1 ; set axis minima
M208 X150 Y150 Z200 S0 ; set axis maxima*********; Endstops
; WARNING: No endstops configured; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X-135:135 Y-135:135 S20 ; define mesh grid*********; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
@piyush-panse you'd basically need G92 X0 etc in each homing file.
but questions such as are you going to leave the motors a X0 etc before you power down? or will you be needing to jog them into position before setting 0?
You could always echo their location into a file before powerdown to enable you to reinstate that position at power up but obviously things such as an emergency stop would affect that. motors can also jump up to 4 full steps when energised.
Ultimately, when the motors aren't energised, RRF has no way of knowing where those motors are -
@piyush-panse I expect the uploaded gcode has a command to home the axes, ie G28. I guess you are setting the router position with G92, but the homing command is overriding this, and calling home[axis/all].g, which is then (in its default form) not finding any endstops to home against, and generating the error.
EDIT: Ideally, remove any G28 homing command from the gcode. You should be able to do this in the software that is generating the gcode; there's usually a 'start gcode' (and 'end gcode') section that gets inserted into the generated gcode file.
You could change homeall.g (and the other homing macros) to pick up the current value of X, Y and Z and set it again.
