DUEX 0.11 FAN 5
@paolozampini1973 backups are always a good idea. I have my configurations under version control and stored on github for easy reference and to make sure that in the case of local catastrophe I have a copy available elsewhere.
@oliof said in DUEX 0.11 FAN 5:
I'll probably do this upgrade tomorrow as temperatures and speeds improve what your opinion is ?
I am running my printers very conservatively, so I do not go for maximum speed.
I believe that a printer once that makes 70 - 80 mm is more than enough important to have the accuracy is the quality
Ultimaker Cura Enterprise 4.10.0 I don't know if you've ever tried it but the prints are much higher quality and the processing takes about 20% less
@oliof I wanted to ask you but there is an algorithmic auto for temperatures because I don't like the one I have at all I would like that there would be an algorithmic auto that, based on the temperature that rises and falls, the rule automatically
I don't fully understand your request. Is this still about the fan to cool the stepper, or some other issue?
M307 H1 R2.300 C135.000:111.161 D12.60 S1.00 V25.0 B0 I0
I do not speak the regulation of the nozzle temperature I now have an algorithm that I created that is stable but when I suddenly increase the speed the temperature drops by 2 degrees even by degrees -
@oliof temperature excursion exceeded 15.0°C this parameter can be changed instead of 15 degrees to have 20 degrees ?
@paolozampini1973 after you update to 3.4, you can try heater feedforward https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m309-set-or-report-heater-feedforward which raises the heater power for higher speed prints.
Alternately you can adjust the heater fault detection using M570 https://docs.duet3d.com/User_manual/Reference/Gcodes#m570-configure-heater-fault-detection but since this is a critical safety feature I would only use this as a last resort. It does allow you to adjust the excursion limit as you requested. -
Alternately you can adjust the heater fault detection using M570 https://docs.duet3d.com/User_manual/Reference/Gcodes#m570-configure-heater-fault-detection but since this is a critical safety feature I would only use this as a last resort. It does allow you to adjust the excursion limit as you requested.Thanks for the very kind reply
