J type thermocouple syntax error
Gcode meta commands
    aronmeszaros
    Hello, I would like to configure a J type thermocouple with the following command: M308 S8 P"1.spi.cs0" Y"thermocouple-max31856" T"J" A"Nozzle" . It throws the following error: M308: expected number after 'T'
    Type K works just fine I have 3 of them working. The TC boards are on an expansion board thats why the 1.spi
    Im running: RepRapFirmware for Duet 3 MB6HC version 3.4.0beta6 (2021-11-06 11:38:57) running on Duet 3 MB6HC v1.01 or later (standalone mode)
    Im afraid to upgrade because there were a lot of things that were not working after this update and this version had the combination where it all did
    undefined 1 Reply Last reply 2 May 2022, 18:22 Reply Quote 0
      aronmeszaros @aronmeszaros
      @aronmeszaros is there something wrong with my syntax or it could be because of the firmware version?
      undefined undefined 2 Replies Last reply 2 May 2022, 18:55 Reply Quote 0
        jay_s_uk @aronmeszaros
        @aronmeszaros upgrade to 3.4 stable
          dc42 administrators @aronmeszaros
          @aronmeszaros there was an error in the documentation. The thermistor type letter parameter is K not T. I have corrected the documentation.
          However, you should upgrade to 3.4.0 stable.
          undefined 2 Replies Last reply 3 May 2022, 07:16 Reply Quote 1
            aronmeszaros @dc42
            @dc42 thank you, I’ll give it a try today
              aronmeszaros @dc42
              @dc42 Thank you! The K"J" parameter did the trick, it works prefectly 😄
              I saw it was also changed in the documentation 🙂
              I noticed one more place (in the new docs) where it could be changed, Im sending the picture and link: https://docs.duet3d.com/User_manual/Connecting_hardware/Temperature_connecting_thermocouples
              Otherwise we can mark this topic as solved
              Thank you again
              undefined 1 Reply Last reply 4 May 2022, 07:21 Reply Quote 1
                @aronmeszaros thanks for pointing that out. I've corrected it.
                • undefined dc42 marked this topic as a question 4 May 2022, 07:21
                • undefined dc42 has marked this topic as solved 4 May 2022, 07:21
                6 out of 7
