    1HCL basic tuning fails
    Beta Firmware
    • wiegoundefined
      wiego
      I have a rotary axis with a Nema 17 stepper motor with a 500 cpr differential encoder with zero impulse (but as suggested only a+,b+ and power connected). Firmware is 3.4.1 rc1.
      Unfortunately I do not even pass basic tuning with this setup, but the motor moves apparently as expected (have seen this manoveur already on working motor). Might be something with the encoder? Cables are long (2m), but shielded and grounded at supply side.
      The error message is:
      Warning: Driver 123.0 warning: tuning failed
      Warning: Driver 123.0 new tuning error(s): The measured motion was inconsistent.
      Can you see what the problem is ?
      Thanks,
      wiego
      config.g:
      G90                                          ; send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M550 P"ClosedLoopTest"                   ; set device name
      ; Wait a moment for the CAN expansion boards to start
      G4 S2
      M552 P192.168.1.177 S1      ; enable network and set IP address
      M553 P255.255.255.0         ; set netmask
      M586 P0 S1               	; enable HTTP
      ; closed loop
      M569.1 P123.0 T2 C2.5 R100 I0 D0
      M569 P123.0 S1 D2
      M584 A123.0					; set drive mapping
      M917 A0
      M350 A16 I0  				; configure microstepping without interpolation
      M92 A3200				; set steps per mm
      M566 A1000 					; set maximum instantaneous speed changes (mm/min)
      M203 A1500 					; set maximum speeds (mm/min)
      M201 A1000 					; set accelerations (mm/s^2)
      M906 A1000 I30 				; set motor currents (mA) and motor idle factor in per cent
      M84 S30                     ; Set idle timeout
      M208 A0 S1					; set axis minima
      M208 A1000 S0 				; set axis maxima
      homea.g
      ; homea.g
      ;setup
      M569 P123.0 D2
      G91               ; relative positioning
      ;G1 A360 F2000
      G90
      M400
      M569 P123.0 D4 S0 ; Configure the motor on the 1HCL at can address 50 as being in closed-loop drive mode (D4) and not reversed (S1)
      M569.6 P123.0 V31
      ;G1 A0
      ;cleanup
      G92 A0			  ; set zero coordinate system for this axis
      M122 for 1HCL:
      Diagnostics for board 123:
      Duet EXP1HCL firmware version 3.4.1rc1 (2022-05-03 09:32:27)
      Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10)
      All averaging filters OK
      Never used RAM 52288, free system stack 178 words
      Tasks: Move(notifyWait,0.0%,152) HEAT(notifyWait,0.0%,78) CanAsync(notifyWait,0.0%,70) CanRecv(notifyWait,0.0%,79) CanClock(notifyWait,0.0%,70) TMC(notifyWait,34.2%,358) CLSend(notifyWait,0.0%,132) MAIN(running,64.0%,407) IDLE(ready,0.0%,30) AIN(notifyWait,1.7%,265), total 100.0%
      Last reset 01:11:31 ago, cause: power up
      Last software reset data not available
      Closed loop enabled: yes, pre-error threshold: 0.00, error threshold: 0.00, encoder type rotaryQuadrature, reverse polarity: no, position 6960, raw count = 7410, tuning mode: 0, tuning error: 0x10, collecting data: no
      Control loop runtime (ms): min=0.003, max=0.029, frequency (Hz): min=11538, max=17442
      Driver 0: pos 0, 3200.0 steps/mm,tuning failed, SG min 0, mspos 8, reads 36336, writes 55440 timeouts 0, steps req 0 done 0
      Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter -10/10, peak Rx sync delay 195, resyncs 0/0, no step interrupt scheduled
      VIN voltage: min 12.2, current 24.2, max 24.3
      V12 voltage: min 10.4, current 12.1, max 12.1
      MCU temperature: min 32.8C, current 33.4C, max 33.9C
      Last sensors broadcast 0x00000000 found 0 218 ticks ago, 0 ordering errs, loop time 0
      CAN messages queued 69642, send timeouts 0, received 21697, lost 0, free buffers 37, min 37, error reg 0
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
        dc42 administrators @wiego
        @wiego said in 1HCL basic tuning fails:
        By "power", please confirm that you mean +5V and ground.
        Is the working motor of exactly the same type?
        I'm confused by your first image because I can only see the green line for measured motor steps, but there should also be a black line for raw encoder reading.
        Which version of the closed loop tuning plugin are you using?
        wiegoundefined 1 Reply Last reply Reply Quote 0
        • wiegoundefined
          wiego @dc42
          @dc42 said in 1HCL basic tuning fails:
          yes, from the eight differential wires of the eoncoder (A,/A,B,/B,Z,/Z,5V,GND) only A,B,5V,GND are connected to the Quadrature Input of 1HCL. 24V as board supply on VIN.
          No, unfortunately the motor that has been working is another type with TTL encoder.
          In the first picture both lines exactly on top of eachother, that is the reason why the black is hardly visible.
          3.4-b1
          • wiegoundefined
            wiego @wiego
            i just found out that cpr can have two meanings 😓 :
            • counts per revolution (=4xPPR)
            • cycles per revolution (=1xPPR)
            so my encoder has actually 500 cycles per revolution means 2000 counts per revolution.
            I change that to M569.1 P123.0 T2 C10 R100 I0 D0
            but recordings look still quite similar:
              @wiego are you sure the encoder isn't higher resolution than that? It looks like the measured motor steps is too high.
              Do you get any other messages when the tuning fails? RRF normally reports its estimate of the measured CPR.
